Anyone running the Vled Vtails tail light conversion kit?
Discussion in 'Lighting' started by Bubba503, Jan 25, 2023.
  1. Mar 20, 2023 at 11:23 AM
    #81
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Took advantage of the 15% off deal and ordered the basic kit along with the VLED resistors today. $182 all-in. Apparently the red LEDs are out of stock so will delay shipping until the end of the month.
    Thanks to all for the great advice! :thumbsup:
  2. Mar 20, 2023 at 8:34 PM
    #82
    patos tacoma
    patos tacoma Well-Known Member
    Why would you shift into reverse with turn signal on?
  3. Mar 20, 2023 at 8:39 PM
    #83
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Parallel parking.
    Kolache007, Speedfreak and TRDRed like this.
  4. Mar 20, 2023 at 10:58 PM
    #84
    MGMDesertTaco
    I don't, but I bought the vlr15's anyway. :cookiemonster:
    Speedfreak, T378 and TRDRed like this.
  5. Mar 24, 2023 at 6:51 PM
    #85
    T378
    T378 Member
    22 AG Tacoma
    Which kit did you buy stage 1?
    TRDRed likes this.
  6. Mar 24, 2023 at 7:39 PM
    #86
    MGMDesertTaco
    @T378
    Just get the stage 1, it's plenty bright.
  7. Mar 24, 2023 at 7:52 PM
    #87
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I agree. The Stage 1 are an excellent upgrade!
    TRDRed likes this.
  8. Mar 24, 2023 at 8:15 PM
    #88
    DD619
    DD619 Active Member
    Don
    San Diego, CA
    2020 White TRD OR
    I was going to buy morimotos Meso tails because I have oem chromes but I’m going with these. Anyone have oem’s with black housing for sale? Thanks fellas
    TRDRed likes this.
  9. Mar 24, 2023 at 10:25 PM
    #89
    TRDRed
    That’s what I was thinking. The black housings pop up now and then. Looking forward to getting the kit either way.
    DD619[QUOTED] likes this.
  10. Mar 25, 2023 at 8:33 AM
    #90
    wayne0
    wayne0 Well-Known Member
    Just ordered mine! Love the amber turns.
  11. Mar 25, 2023 at 9:27 AM
    #91
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    Anyone know why some trucks need resistors and some do not?
  12. Mar 25, 2023 at 9:50 AM
    #92
    Bubba503
    Bubba503 [OP] Well-Known Member
    PNW
    2022 Tacoma TRD ORP Lunar Rock
    I imagine it depends on what stock lighting the truck has. I ordered and installed them just for the piece of mind. Easy install and mounting so it’s work the extra money if you ever have to parallel park!
    TRDRed likes this.
  13. Mar 25, 2023 at 5:26 PM
    #93
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Differences in load of the signal circuit within factory tolerances or aftermarket modifications to other signal lights in the system changing the total load. So variables ( lower resistance ) in the signal lamp circuit cause the issue.
    Generally, cheaper LED bulbs have less resistance than equivalent incandescent bulbs. This load ( lower resistance ) increases current. The higher current then causes the flasher to heat up quicker causing the bimetal relay to cycle faster. The resistors return the current to a normal level making the bimetal relay flash normally. The down side is with the extra resistance and low impedance bulbs, is you may not know you have a bulb out through the hyperflash mode.
    Edit: the 3rd gen Tacoma does not appear to use a bimetal relay. The signal is generated in the instrument cluster and is most likely done electronically.
    ceh527 and TRDRed like this.
  14. Mar 25, 2023 at 10:14 PM
    #94
    caribe makaira
    Caribbean, Puerto Rico
    Love to see this bi-metal flash relay in the 3rd Gen...:burp:
  15. Mar 26, 2023 at 2:37 AM
    #95
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Ordered mine Friday, called them with a question and the awesome service I received was the best. The lights are in stock and my order will be here Monday.
    Stevie17 and TRDRed like this.
  16. Mar 26, 2023 at 4:06 AM
    #96
    BLtheP
    Plano, TX
    It’s not that some need them and some don’t. It’s that some people don’t care about the issues that happen when you don’t have them. Any TRD will not hyperflash during normal turning so long as something is plugged in at each location (meaning swapping from incandescent to LED at all locations is no issue). Where resistors are needed on TRD trims is at the new VLEDS/Meso switchback. That is because of how a switchback is designed. They are computer controlled in their circuitry. When in reverse, the bulb id in its “constant” mode. When that is interrupted with a turn signal (parallel parking), the bulb sees that blinking input from the truck, shuts off the white, and blinks the amber until it no longer sees the input from the truck, then it switches back to white. The only logical explanation on a TRD hyperflashing in that situation is that for whatever reason, the switchback chooses to power the turn signal off of the reverse light (constant) power, which causes the truck to see no load on the rear turn signals, causing hyperflash. So, you need resistors unless you don’t care about hyperflashing in a parallel parking situation. They’re so cheap, you really have no reason to throw them in the cart. Get the 15 ohm, they’re plug and play with the kit.
    On an SR/SR5 trim, which never came factory with LED headlights, the setup is more traditional. You end up needing typical larger resistors (25W 6 ohm) which are sized to replace an incandescent bulb with an LED. The SR/5 trims are not happy with just seeing come current at each bulb location, so LEDs installed are not happy. So SR/SR5 trucks will need larger resistors pretty much no matter what.
    The TRDs all have the option of factory headlights, so Toyota needed a solution on being able to ship some trucks with LEDs and not have issues. That seems to be why the TRD trims are not picky about what type of current draw is at each location. I’m also pretty certain that even though the LEDs started in 2020 models, Toyota probably knew they were going to release those headlights back in 2015 when the 2016 model launched. So they were able to ship all the TRDs back then this way still, preparing for the future option of LED headlights.
  17. Mar 26, 2023 at 4:06 AM
    #97
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    It would appear that the signal generator is in the instrument cluster. I don't have a schematics for the cluster though... is it done electronically or mechanically in the cluster? Regardless it is still load dependant.
    TRDRed likes this.
  18. Mar 26, 2023 at 8:50 AM
    #98
    TRDRed
    Interesting. When I placed an order on the 20th they noted that they were out of stock and it wouldn't ship until the end of the month. Still says that on their website. Hopefully they've been replenished. Let us know how it goes!
    Stevie17 likes this.
  19. Mar 26, 2023 at 9:17 AM
    #99
    Grantamaire
    Grantamaire Member
    Grant
    I was curious about this with the newer TRD trims supporting the OEM LED headlights. I recently did the VLEDS stage 1 tail conversion and love it. Slowly upgrading everything else to LED on my 22 AC TRD OR… I was curious if the front turn signals would require resistors when switching to LED from halogen, since the rears do not (except in reverse with the switchback).
    TRDRed likes this.
  20. Mar 26, 2023 at 9:34 AM
    #100
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    We will have stock of the red bulbs near the end of next week
    MGMDesertTaco and TRDRed[QUOTED] like this.
