Anyone running the Vled Vtails tail light conversion kit?
Discussion in 'Lighting' started by Bubba503, Jan 25, 2023.
  1. Apr 9, 2023 at 8:54 AM
    #141
    vinyl
    vinyl Let's go for a drive!
    NC
    2023 Magnetic Gray Metallic Tacoma SR 2.7L/AC 4x4 6ft Bed
    OEM LED Headlights, VLEDS Tail light kit, TRD Step bar, V1 Blendmount, Wireless AA, SCS SR8 17x8.5
    Just installed the VLEDS tail light kit for my Tacoma SR.. I am honestly shocked Toyota went with their original design when this is so much better. It makes no sense to split the "C" red shape into two when you can use it in its entirety for much better illumination at night. The ambers sharing the white reverse light was an awesome touch and I keep everything factory untouched.
    The only thing I can hope for is that these LED "bulbs" last at least a year. I am thinking of buying some spares just in case. I have not had good luck with aftermarket LEDs.
  2. Apr 9, 2023 at 9:11 AM
    #142
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    VLEDS is the only brand of LEDs I’ve ever seen with pretty much rare to no failures. You should get at least a year.
    I bought spare switchbacks and I keep a box of incandescents for the brake lights.
  3. Apr 9, 2023 at 10:42 AM
    #143
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    I also have the VLED backup light strip that fits on the license plate
    TRDRed likes this.
  4. Apr 9, 2023 at 4:17 PM
    #144
    vinyl
    NC
    So it looks like with the VLEDs I needed to add resistors on both sides. Front and back. Prior to the tail lights modified, I didn't need resistors in either locations. Only after each side had a resistor installed did the car finally calm down. What's funny is it happened at random. Sometimes it was normal, sometimes it would blink fast. I didn't get to test it for long but I am hoping this puts an end to my panic blinkers lol
    Stevie17 likes this.
  5. Apr 9, 2023 at 5:22 PM
    #145
    BLtheP
    Plano, TX
    SR/SR5 need them. TRDs and Limiteds don’t, except to prevent hyperflash in reverse (parallel parking scenario basically).
    Also, to reliably determine whether resistors are needed, the engine needs to be running. The higher voltage from the alternator lessens the amp draw from the bulbs which then makes you more likely to need resistors. So since engine on is the normal scenario, it needs to be running for testing.
    Speedfreak, Stevie17 and TRDRed like this.
  6. Apr 9, 2023 at 9:39 PM
    #146
    scouterjan
    Jan
    I just purchased the resistors from VLED when I ordered the kit, they were simple plug and play
  7. Apr 10, 2023 at 6:02 AM
    #147
    vinyl
    NC
    Even with the engine running things worked fine. It would happen at random. That's why it caught me by surprise. I did a quick test drive around the neighborhood and then the last turn my left decided to rapidly blink. What's funny is the new LED OEM headlights didn't need the resistors. It wasn't until I swapped the taillights that it started happening.
    Either way, both kits shipped with resistors and now that both resistors are installed the problem seems to have gone away.
    scouterjan and TRDRed like this.
  8. Apr 21, 2023 at 3:44 PM
    #148
    TRAIL23
    TRAIL23 Member
    Nick
    2023 Trail Edition Lunar Rock
    Just installed the VLED tails on my 2023 LR Trail and love them. Anyone have an idea of the lifespan of the led bulbs and when they need to be replaced? Might buy a backup set in case
    TRDRed likes this.
  9. Jul 16, 2023 at 12:37 PM
    #149
    thelostground
    thelostground Member
    East Bay, CA
    2021 DCLB OR
    Too many to list...
    Installed the Vtails kit this weekend on my '21 OR. So much better! Didn't end up needing the resistors, even in reverse. I'm also curious about bulb lifespan.
    TRDRed and kmorgan3 like this.
  10. Jul 16, 2023 at 12:45 PM
    #150
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Bulbs have a 3 year warranty as long as there isn’t some sort of water intrusion or mis-use that leads to premature failure. With that said, these bulbs are built to pretty strict tolerances — especially the V6’s. Plenty of trucks out there with bulbs that are several years old.
    TRDRed and thelostground[QUOTED] like this.
  11. Sep 18, 2023 at 10:39 PM
    #151
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Just installed these today; anyone else have an issue with the way the VLED reverse/directional switchback bulbs fit in the tail lights? They have two tabs on them, vs the stock bulb socket having three, and they don’t tighten and stop at a quarter turn like the stock socket does, they will tighten past the point of them being “tight.” I have them both in, and turned til they were tight, but I’m worried about them not sealing and opening the tail light up to moisture issues…
  12. Sep 19, 2023 at 9:27 AM
    #152
    wayne0
    wayne0 Well-Known Member
    I installed these about 8 months ago (love them) and on getting my oil changed, the guy told me that the left bottom wasn't working. Got kinda' pissed, as they were pretty new. I puled the tail light and found that the "bulb" come loose and just needed to be re-seated.:bananadance:
    TRDRed likes this.
  13. Sep 19, 2023 at 12:07 PM
    #153
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have them, no issues so far. Now I got to go check mine.
    TRDRed likes this.
  14. Sep 19, 2023 at 2:01 PM
    #154
    scouterjan
    Jan
    Had mine installed for a year, never had a problem with them
    TRDRed and 650H1 like this.
  15. Feb 18, 2024 at 10:17 AM
    #155
    Robskino
    Robskino Well-Known Member
    Robert
    23 MGM sport
    Question for the resistors i am reading about and where to place them if they were needed. I have a 23 trdsport, with the led headlights. Do i need the resistors for the tail lights. And then an extra set for the ones up front as someone mentioned above? Or did i understand that incorrectly. Willing to pull the trigger on these, but want to make 1 purchase and be done with it. Also dont want to install something if it isnt necessary..
  16. Feb 18, 2024 at 6:54 PM
    #156
    MGMDesertTaco
    The resistors are only for the led tail light kit. What happens is when you shift into reverse with your signal on the signal begins blinking super fast (hyper flashing). Not really an issue unless you were trying to reverse parallel park or something like that. It won't hurt anything not to have them, but it appears they're now included when you buy the tail light conversion kit.
    You can mount them directly behind the tail light in the bed. Mine are off to the side behind the tail lights.
    scouterjan and Robskino[QUOTED] like this.
  17. Feb 18, 2024 at 7:19 PM
    #157
    datil_d
    datil_d Member
    Derek
    McDonough, GA
    '23 SR V6 Access Cab
    I installed the V6 Triton tail light conversion kit on my SR. The resistors are for the switchback turn signals and reverse lights. The resistors are heavy duty and heatsinked with an adhesive pad that is placed on the inside of the tail light area. The kit was an easy install and the brightness and functionality is excellent.
  18. Feb 19, 2024 at 2:51 AM
    #158
    Robskino
    Robert
    23 MGM sport
    Thank both of you for your answers. I bought the v6 extremes and cannot wait to put them in. Then in the next week ill be getting the pro housing for them. Super anxious to see hownit turns out!!
  19. Feb 19, 2024 at 5:21 AM
    #159
    datil_d
    datil_d Member
    Derek
    McDonough, GA
    You'll be impressed. With the V6 Extremes being brighter than the V6 Triton kit, people behind you will need sunglasses. My turn signals and brake lights illuminate everything behind me. I wanted bright because of the number of inattentive drivers more interested in their phone than the back of my truck.
    Robskino[QUOTED] likes this.
  20. Feb 19, 2024 at 6:36 AM
    #160
    Robskino
    Robert
    23 MGM sport
    Thats exactly what i wanted. Peoples attention to not hit my $50k baby. I want the entire ass end to be illuminated for half a mile down the road hahaha
    datil_d[QUOTED] likes this.
