Anyone running these beefy CV axles?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ForestRunnerFrank99, Feb 7, 2021.
  1. Feb 7, 2021 at 11:37 AM
    ForestRunnerFrank99
    ForestRunnerFrank99 [OP] Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    Found these guys on Orielly's website as well as RockAutos (though they seem to be gone from there as of posting this). I've never seen them before. Wondering if anyone is running them and if so how do they work? I know most of the problem with CV's is the joint, not the shaft, it's hard to tell if the joint is any more skookum. I'm pretty tempted by these guys but want some input 1st. Thanks!
    whatstcp likes this.
  2. Feb 7, 2021 at 12:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There are threads about these axles, but I'll entertain you.
    I bought a pair to replace my own cv axles as the inner boots on both tore up after some wheeling.
    I do run 2" of lift so it was inevitable. Below you can see what I mean -
    Seeing as how OEM remans are getting harder to find, not to mention being expensive, I opted to try these bad boys out -
    I had heard about them not only on some forums but found a guy or two I follow that wheel pretty hard with their 4R that run these. I figured, if it's good enough for them with larger tires than mine (I run 33's), then they'll definitely work for me.
    Here they are installed -
    And how the truck sits -
  3. Feb 7, 2021 at 1:40 PM
    ForestRunnerFrank99
    Josh
    Very cool! Who are the guys you follow? I've seen your rig before but couldn't find any one else with them.
    Kwikvette[QUOTED] likes this.
  4. Feb 7, 2021 at 1:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Too many to list :bananadead:
  5. Feb 7, 2021 at 2:52 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    You have my attention, ive blown through multiple cv boots and cv joints in the last 5 years and again have to do another one soon. If these are as good as the look im going to get a pair.
  6. Feb 7, 2021 at 3:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If you're running OEM axles, I'd suggest you get those high angle inner cv boots.
  7. Feb 7, 2021 at 3:07 PM
    mlcc
    Oregon
    Drivers side is the original axle that has had multiple boots tore and the other is an aftermarket shaft because the original one had a cv fail under... harsh circumstances.
  8. Feb 24, 2021 at 9:29 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @ForestRunnerFrank99
    Just wanted to give you an update after having these CV axles on both sides for a few months -
    I've been on a few wheeling trips from Hollister Hills to Bald Mountain in Shaver and in between.
    Now, the above pic is what I found yesterday when I reinstalled my factory skid plates. The scratch looks a bit old, but I don't know if it correlates at all with my last alignment versus the new alignment I received about a month ago since a neighbor hit my truck while it was parked and knocked my alignment off.
    I say this, because it was the passenger side's wheel that got the alignment knocked since the neighbor crashed into my passenger side only.
    Anyway, it's only the passenger side that rubbed and now I check it often and it shows no new rubbing at all. Seems it happened at some point where there was a lot of compression and I was climbing something? Hard to say.
  9. Feb 24, 2021 at 9:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    For a few months now.
    But I think the only interference I've run into was due to my 4R getting hit at the parking lot a few weeks ago.
    It was parked and just hard enough at the right angle to knock my alignment off.
    Pretty sure that's when my CV axle rubbed until I got the 4R aligned again days later.
    01x4[QUOTED] likes this.
  10. Feb 24, 2021 at 9:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Like I told someone else the other day, I was going faster through the whoops that I care to admit...been great.
  11. Feb 24, 2021 at 9:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Could be that I've got 3 OEM ADD axles at home that I'm not too worried if I broke one of these.
    That and they have lifetime warranty.
    y=mx+b and 01x4 like this.
  12. Feb 24, 2021 at 9:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You can just run OEM for life then :rofl:
  13. Feb 24, 2021 at 9:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Jaxon posted this in the other thread about these CV axles -
  14. Feb 24, 2021 at 9:57 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's right, forgot you're getting lifted and getting adult-sized tires :rofl:
    jbrandt and 01x4[QUOTED] like this.
  15. Feb 24, 2021 at 10:02 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Damn thats a pretty cool design. Wonder why regular splines wouldnt work though. The roller spline seems excessive in terms of complication and weight (and cost probably)
  16. Feb 24, 2021 at 10:13 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    @Kwikvette so they rubed your upper control arms?
  17. Feb 24, 2021 at 10:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What?
    No...dude uppers are tooooo far from any CV axle :rofl:
    Rubbed the coil at compression when my alignment got knocked out after a small fender bender.
  18. Feb 24, 2021 at 10:16 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    rubbed the coil on the Kings on the pass side
    SR-71A and Kwikvette like this.
  19. Feb 24, 2021 at 10:16 AM
    eon_blue
    Azusa, CA
    damnit jinx
  20. Feb 24, 2021 at 10:17 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You pretty much owe me Taco Bell at this point :burp:
    eon_blue[QUOTED] likes this.
