Anyone running these LED tail lights for feedback? Anzo,Updated, bought a set
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Dec 17, 2020.
  1. Feb 8, 2021 at 6:23 PM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
    So how are you liking these after having them in for a while? Any issues? Also, yours are the non-smoked version, correct? I think I asked before but couldn't find if that was answered somewhere. I'm pretty sure I can tell from the photo but wanted to verify.
  2. Feb 8, 2021 at 7:28 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Little off topic sorry but are those aftermarket bed rails?
  3. Feb 8, 2021 at 9:12 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    No, that’s the sprayed in bed lining
  4. Feb 8, 2021 at 9:38 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Damn
  5. Feb 22, 2021 at 1:46 PM
    Ceetaco
    Ceetaco Member
    01 Tacoma Double Cab
    I installed mine over the weekend. Everything works but the running light does not illuminate on the right/passenger side does not illuminate. Plugged it into the left/drivers side to make sure it’s not the light itself. I checked fuses and voltage. Am I missing something??? I thought these were just plug and play!
  6. Feb 22, 2021 at 1:55 PM
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
    not for 01-04, you’ll need to modify your harness
  7. Feb 22, 2021 at 2:04 PM
    Ceetaco
    Ceetaco Member
    Modify???
  8. Feb 22, 2021 at 2:10 PM
    Ceetaco
    Ceetaco Member
    Do I need to put a load resistor for the running light?
  9. Feb 22, 2021 at 2:22 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I'm looking at these too. That price = might have to pick up some security headed screws too
  10. Feb 22, 2021 at 2:23 PM
    Ceetaco
    Ceetaco Member
    It works with the stock tail light connected to left/drivers side. Which makes me think it’s a voltage issue.
  11. Feb 22, 2021 at 2:24 PM
    Ceetaco
    Ceetaco Member
    Not a bad idea if I can get them to work properly.
  12. Feb 22, 2021 at 2:27 PM
    Ceetaco
    Ceetaco Member
    I called Anzo and they didn’t have a fix or solution. They told me to return them.
  13. Feb 22, 2021 at 2:27 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    If anyone else ends up getting these to replace your stock tail lights let me know I’ll buy your stock tail lights.
    treyus30 likes this.
  14. Feb 22, 2021 at 2:28 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    How much?
  15. Feb 22, 2021 at 2:30 PM
    #35
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    Compared to OEM prices, why not?
  16. Feb 22, 2021 at 3:25 PM
    #36
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Depends on condition
    1997tacomav6[OP] likes this.
  17. Feb 22, 2021 at 11:06 PM
    #37
    1997tacomav6
    Denver
    So much better than OEM
  18. Feb 23, 2021 at 2:47 PM
    #38
    slodoug
    slodoug Well-Known Member
    Mine came with what looks like a little ballast attached to the harness. Has sticky tape on it and a removable clip. I assume its necessary even if I have an LED blinker relay?
  19. Feb 23, 2021 at 3:37 PM
    #39
    slodoug
    my passenger side taillight harness has a short, where can i find a pinout?
  20. Feb 23, 2021 at 4:24 PM
    #40
    Ceetaco
    Ceetaco Member
    The ballast is actually a load resistor for the turn signal
    1997tacomav6[OP] and slodoug like this.
