Anyone running these wheels yet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davidf, May 16, 2018.
  1. May 16, 2018 at 10:17 AM
    davidf
    davidf [OP] Well-Known Member
    David
    Texas
    Currently in the market.
  2. May 16, 2018 at 10:19 AM
    EatSleepTacos
    EatSleepTacos MOBTOWN OFFROAD AMBASSADOR
    Randy
    Silver Spring, MD
    4x4 2005 SR5 AC 6MT POOP Edition
    Are you aware that that's a real beadlock? They're a lot of maintenance because you have to regularly check that all the bolts are torqued down.
  3. May 16, 2018 at 10:21 AM
    davidf
    David
    Texas
    So you don't recommend them for the street?
  4. May 16, 2018 at 10:22 AM
    EatSleepTacos
    Randy
    Silver Spring, MD
    No, not unless you’re serious into off-roading. That’s where the benefit lies. If you want the looks of a headlock without the actual maintenance or cost of them, there are plenty of faux beadlock wheels on the market.
  5. May 16, 2018 at 10:25 AM
    davidf
    David
    Texas
    I really appreciate the advice. Thats why your the gurus. What a shame too. Such a good looking wheel.
    EatSleepTacos likes this.
  6. May 16, 2018 at 10:34 AM
    ccal
    ccal Well-Known Member
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    Buy whatever the hell you want, it don't matter if your on the road or off. If you like them wheels, which I personally think are badass and wouldn't hesitate to buy them bead lock or not, I would buy them and enjoy them
  7. May 16, 2018 at 10:39 AM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    And as for the bolts, that's horse shit, put some blue locktite on them and torque them down to whatever it says to , and run em wherever the hell you want. What maintenance could you possibly have unless your rubbing the damn rings off on boulders. Buy what you want , and send me some pictures when you get them on because they will look awesome on a white truck
  8. May 16, 2018 at 10:42 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Seattle
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Sure, if you really want to take your wheels off every couple thousand miles so you can retorque all the bolts holding them together. Or if you want to pay for 4+ hours of labor every time you have to remove a tire. And if you want to take a massive fuel mileage hit because bead lock wheels usually weigh a ton. Oh, and they can be a pain in the ass to balance. Also, they're kinda useless unless you're running at least 35s.
    You should probably know what you're talking about before making generic comments.
    Beadlocks are also technically illegal for road use in most places. But it's doubtful you'd get a ticket for it unless you live somewhere like California.
    blu92in99 and knottyrope like this.
  9. May 16, 2018 at 10:45 AM
    EatSleepTacos
    Randy
    Silver Spring, MD
    Here's Methods guidlines for beadlocks in case you were curious.
    https://cdn.shopify.com/s/files/1/0...23-8984-f03e02bbb925.pdf?10447696810621187145
    @ccal is straight up giving you bad advice. The bolts on a beadlock are what literally hold the tire on the wheel. If they come loose, your tire will come off. This is why it's important to constantly recheck the torque on them so you don't have any failures.
    These are all excellent points OP. Listen to this man.
  10. May 16, 2018 at 10:49 AM
    EatSleepTacos
    Randy
    Silver Spring, MD
  11. May 16, 2018 at 10:49 AM
    Capt. Obvious
    Darrick
    Seattle
    '12 DCLB TRD
  12. May 16, 2018 at 10:49 AM
    jlusmc
    jlusmc Well-Known Member
    James
    Huntsville, TX
    17' Double Cab Long Bed TRD Off Road, Barcelona Red
    TRD PRO - Grille, Cold Air, Cat Back and Gear Shifter Weathertech floor mats and window deflectors Toyota bed mat and door sill protectors OME 888 front and Dakar rear lift SDHQ Hidden winch mount with Warn M8000s Factor 55 ultra hook Cascadia 4x4 flipster LP mount 16x8 SCS Ray 10 wheels in Gunmetal 285/75r16 BFG A/T KO2 Tires Homemade bed bars Tepui Kukenam Ruggedized RTT Kobalt slim lowpro tool box Hypertec speedo calibrator JL Audio HD600.4 and HD1200.1 amps JL Audio 10TW3d4 subs (x2) Focal Access 6.5 components (front and rear)
    Make sure and check if they are DOT approved. If the wheels are not DOT approved then they are illegal for on road use. I know plenty of people run beadlocks approved or not on the street. Just an FYI that you may run into inspection and or law enforcement dilemmas running a non approved wheel. Right now Rock Monster Wheels are one of the few true beadlocks that are approved for on road use. Another tidbit most major tire shops such as Discount, Firestone, NTB ect.... will not mount or balance beadlock wheels due to safety issues.
  13. May 16, 2018 at 1:53 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Fort Collins, CO
    2014 Toyota Tacoma 4x4
    The link for the beadlocks says to call before ordering, probably to tell you exactly what this thread has lol
