Anyone running this setup?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TurfTaco, Oct 28, 2009.
  1. Oct 28, 2009 at 11:07 AM
    TurfTaco
    TurfTaco [OP] Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    I just went out and measured mine the same way and I am at 34.00 inches up front and 36.25" in the rear stock. Seems like quite a difference. So according to your measurements you gained over 4" of lift up front setting your 5100s to 2.5" over my stock height and you gained over 3" of lift in the rear with a 1.5" aal? Just don't seem to add up to me.
  2. Oct 28, 2009 at 12:07 PM
    TurfTaco
    URE
    07 Deer Collector
    So does anyone know how much height they actually gained by installing a 1.5" aal? Measuring from ground up to fender through center of wheel.
  3. Oct 28, 2009 at 12:45 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The difference may be the difference in the OD of our tires. Mine are 31.5". I actually got exactly 1.5 in back with the AAL. It was right at 38 before AAL. It has been on there for nearly 6 months now & still same measurement - 39.50". Front was 35.25 on drvr side & 35.75 on passenger side with taco lean. Added the Toytec 1/4" leveling spacer to drvr side when going with 5100s to even it up. Both sides now 38.25. My beginning measurements were actually with base model tokicos & base model springs(not sure if any different from TRD ones)
  4. Oct 28, 2009 at 7:15 PM
    TurfTaco
    URE
    07 Deer Collector
    Anyone have any other comments?
  5. Oct 28, 2009 at 8:12 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Correct, running stock UCAs. Everything is aligned to "within spec". I did get the spec sheet, and from what others have said, the numbers look OK. The only vibes I had/have are a small shudder during take-off, right around 5mph-7mph. tacomaman06 hooked me up with some carrier bearing spacers, which drastically lessened the shudder, but it is still slightly there.
