Anyone seen a fuse box diagram for 2018s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EddieBro, Jan 9, 2019.
  1. Jan 9, 2019 at 4:59 PM
    EddieBro
    EddieBro [OP] Active Member
    Eddie
    I cannot seem to find a diagram for the 2018 fuse box, not in manual or online. Anyone seen of have one?
  2. Jan 9, 2019 at 5:11 PM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    Look inside the fuse box lid...
    daddy_o, Garyji and shakerhood like this.
  3. Jan 9, 2019 at 6:01 PM
    EddieBro
    Eddie
    Yeah I did, but I don't have the secret decoder ring for the lid fuse descriptions.
    Littletacotruck and Jordan11586 like this.
  4. Jan 9, 2019 at 6:30 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    What fuse are you trying to locate?
  5. Jan 9, 2019 at 7:45 PM
    EddieBro
    Eddie
    interior lighting, dome, vanity, and map lights are down
  6. Jan 9, 2019 at 7:53 PM
    daddy_o
    Bossier City, La
    Dome fuse is in the box under the driver side dash. It is labeled as DOME.
    Pic from another member in a different thread.
  7. Jan 9, 2019 at 8:45 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Welcome to TW. Good etiquette to thank and like the guy who provided the answer.
    foodforbears and pinochle like this.
  8. Jan 10, 2019 at 8:33 AM
    EddieBro
    Eddie
    Yes thank you Daddy_O, very much.
    snickers and daddy_o like this.
  9. Jan 10, 2019 at 8:39 AM
    daddy_o
    Bossier City, La
    No problem at all. Hope that gets you taken care of.
  10. Jan 10, 2019 at 11:32 AM
    EddieBro
    Eddie
    Yeah I was looking under hood and it has some funky abbreviations.
    Littletacotruck likes this.
  11. Jan 11, 2019 at 5:07 PM
    EddieBro
    Eddie
    Fixed thanks Daddy O
    daddy_o likes this.
  12. Jan 11, 2019 at 5:13 PM
    daddy_o
    Bossier City, La
    You're welcome. :thumbsup:
  13. Sep 11, 2019 at 4:01 PM
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    This is a old post but hoping someone had tapped 2 fuses for dash cam. I need constant on and then a accessory. Any particular fuses to use in the box??
  14. Sep 11, 2019 at 4:28 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Use the hazard lites fuse for ALWAYS on..
    Use lighter socket for ACC. (on with ignition)
    Sgt.Tee likes this.
  15. Sep 11, 2019 at 5:21 PM
    daddy_o
    Bossier City, La
    Constant power I know for sure is the empty slot under AM1, and most likely P outlet 1 or 2 are hot with key on and are dead with key off.
    02Duck, Sgt.Tee[QUOTED] and over60 like this.
  16. Sep 12, 2019 at 3:40 AM
    Sgt.Tee
    Pete
    NE Pa
    Thanks guys I will check this out
  17. Sep 12, 2019 at 4:30 AM
    Sgt.Tee
    Pete
    NE Pa
    Why is wipers at 30 amps.? If that was accessory spot I could use it to feed the one half of my Bluesea panel. But I am sure it is 30 amps for a reason and I am not sure the wipers are accessory, off when the key is off
  18. Sep 12, 2019 at 6:50 AM
    Sgt.Tee
    Pete
    NE Pa
    Getting the fuse panel cover off I heard some clicking so I stopped. Should I be concerned and how the hell does it come off. There is a small tab on the side and I was prying that with a small screw driver but it would not come off, then I heard some clicking sounds so I stopped. Does anyone know what it might be?
  19. Sep 12, 2019 at 7:52 AM
    surftaco28
    surftaco28 Active Member
    Delaware
    2017 MGM TRD Sport
    My rear power windows and back slider do not work. The front do work. Any ideas on which fuses to check??
  20. Sep 12, 2019 at 4:52 PM
    over60
    Muskoka, Ontario
    I broke mine the first time I removed it.:eek:
    There is a small tab on the end toward the driver (top end)…. reach up there and feel around. The bottom (towards floor) just has a hole for a tab to sit into.... Remove the top first....Good Luck
    My fuse box lid sits in the console now..:thumbsup:
    Littletacotruck and 02Duck like this.
