Anyone seen stripped cam adjuster gears?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Merctech123, Nov 13, 2022.
  1. Nov 13, 2022 at 6:07 PM
    Merctech123
    Merctech123 [OP] Member
    Kris
    07 Tacoma PreRunner URD MK3 supercharged
    Anyone ever see this kind of thing before? Bought the 07 V6 tacoma new and now has 204xxx miles on it. Went boosted and refreshed the engine with a forged bottom end at 180k miles using a Cloyes timing kit. It's had regular oil changes it's entire life. Wondering if it's just mileage and me driving like a lunatic or if maybe there's a problem with Cloyes products though nothing jumped out when building?
  2. Nov 13, 2022 at 6:19 PM
    Bishop84
    Bishop84 Well-Known Member
    I'd only wager that the tensioner was failing, but beyond that no idea.
    TnShooter and Dm93 like this.
  3. Nov 13, 2022 at 6:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That's a very interesting failure, I haven't seen a timing gear failure like that since the old GM's and Fords that had the nylon teeth on the cam gear that would fail like that. Never seen that in a modern engine though, I wonder if it didn't get heat treated properly at the factory or something.
    SR-71A likes this.
  4. Nov 13, 2022 at 6:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Some of those teeth look more than stripped.
    A few look broken.
    Something isn’t right, bad gears?
    Something pulled those teeth off for sure.
    Where did the pieces go?
  5. Nov 14, 2022 at 4:32 PM
    Merctech123
    Kris
    Not sure what's going. All 3 tensioners seem to move freely with no excess wear on the plastic parts. Bank 2 gear is worn smooth and jumped time. Bank 1 the teeth are worn thin and as pointed out a few are broken. Haven't drained the oil yet so I'll check if they're at the bottom of the pan. With 204000 miles of being driven hard, the last 24000 being boosted wondering if it's wear or if something is up with the timing parts I used? Got another engine in the works so a full tear down is on the near future.
    SR-71A likes this.
  6. Nov 14, 2022 at 4:36 PM
    TnShooter
    Deogee
    STOCK
    @Torspd , you seen anything like this before?
  7. Nov 14, 2022 at 4:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The only time I have seen teeth worn like that was due to a chain with too much tension.
    SR-71A and TnShooter like this.
  8. Nov 14, 2022 at 7:11 PM
    TnShooter
    Deogee
    STOCK
    The more I look at the pictures.
    It looks like the only gears that are wearing are the drive gears on the back of the intake cam.
    I don’t think there is a tensioner for the smaller drive chain is there?
    Therefore, the tension is set. Right?
  9. Nov 14, 2022 at 7:17 PM
    Bishop84
    Tiny tensioner, they tend to fail on the slack side and help create the p0012/16 codes due to slap.
    3 chains, 3 tensioners.
    SR-71A and TnShooter[QUOTED] like this.
  10. Nov 14, 2022 at 7:17 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes there is, I believe it's oil pressure fed.
    TnShooter[QUOTED] likes this.
  11. Nov 14, 2022 at 7:43 PM
    TnShooter
    Deogee
    STOCK
    Thanks guys.
    Now, I wonder if both sides did this or just the one?
    OP didn’t say, (or I missed it one?)
  12. Nov 14, 2022 at 7:48 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Only time I've seen worn gears like that was on my Eurovan. The metal was too soft, there was an updated intermediate sprocket made to address the problem.
    If chain tension wasn't correct I'd expect to see damage to the guides as well.
    Probably a bad sprocket, it was aftermarket after all
    TnShooter likes this.
  13. Nov 15, 2022 at 5:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That Cloyes timing kit came with new intake came gears, as well as chains? Or just chains?
  14. Nov 15, 2022 at 5:27 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Bad heat treatment - made in batches, so there will be more if that is the cause......... Worn teeth are weak and breakage is simply "end of life" failure mode. Is the Cloyes brand being built offshore?
  15. Nov 15, 2022 at 6:23 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    The only time I've ever seen really weird chain and / or sprocket wear was back in my motorcycle days. Chains and sprockets wear as a set. If somebody replaced just a chain or sprocket and left worn components in the rest of the system, strange things usually happened just down the road.
  16. Nov 15, 2022 at 6:28 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    How on earth was that even running?
  17. Nov 15, 2022 at 6:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Looked up available kits. Didn't see one with the intake cam gears. That means those chains would have to be the most likely culprit. Assuming oil changes were regular enough.
  18. Nov 15, 2022 at 6:55 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Wow, thats a lot of metal gone missing. Even the primary teeth look worn
  19. Nov 15, 2022 at 6:57 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    So the top gear in the first photo used to have teeth? If so that gear has worn incredibly smooth by, I assume, the action of the chain against it once the teeth were worn down and broken off. What are the consequences of that gear no longer being turned by the chain? That’s a pretty serious FOD concern for some combination of fine metal shavings and larger teeth chunks…how that hasn’t bit the engine is impressive, but I’m not well versed enough to picture where these gears lie and where that FOD might go.
  20. Nov 15, 2022 at 9:16 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I would put that motor completely apart before running it anymore. all the metal went right into the engine.
