anyone slammin? who has some subs?
Discussion in 'Audio & Video' started by tommelleo22, Feb 21, 2011.
  1. Jun 21, 2011 at 6:52 PM
    #241
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Yes it is but I emailed the guy who makes them and asked if there was a way for him to cut it the extra 9/16 because they are only 8's, they may surprise me, but I wouldn't think that they would hit hard enough to blow the wood in the back out.
  2. Jun 21, 2011 at 8:20 PM
    #242
    Warhorseforever
    Will
    Sand Lapper
    That's a no-go now I'm thinking of Polk Audio MM480.
  3. Jun 21, 2011 at 8:29 PM
    #243
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Got 2 Rockford Fosgate Punch's P2's (10in) with a 1000watt Rockford Fosgate amp.
  4. Jun 21, 2011 at 8:52 PM
    #244
    Warhorseforever
    Will
    Sand Lapper
    So could I add a port to that box by just 18Lx2W pvc in it then sealed the edges? I'm looking to squeeze every ounce of pressure level out of these subs.
  5. Jun 21, 2011 at 8:59 PM
    #245
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I have that exact same amp. Love it.
  6. Jun 22, 2011 at 5:44 AM
    #246
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    Yes, but if you go ported, keep in mind the box tuning frequency and make sure you have a filter on to protect the sub if you're going to be going for max SPL.
  7. Jun 22, 2011 at 7:16 AM
    #247
    pinktaco808
    pinktaco808 Hot Steppa
    what size is that box and cu ft space
  8. Jun 22, 2011 at 11:04 AM
    #248
    Tacomanator
    Clam Slammer
    Southern Cali
    That looks like a big box for such a small sub. Did you make it yourself?
  9. Jun 22, 2011 at 11:21 AM
    #249
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Ported boxes use more space, have to subtract out the port area.
    Looks like about 6" deep, about 12" tall, and about 24" wide (give or take some numbers). If those guesses are accurate, and he used 3/4" MDF, he is looking around .6 - .7 cubes (less port), which is about where most 8" subs like to be, ported.
  10. Jun 22, 2011 at 11:27 AM
    #250
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    Not sure, bought it off a guy
    nope, but it sounds great!
  11. Jun 22, 2011 at 6:48 PM
    #251
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    was rockin two 10" hifonics zeus hz 10 subs till my DHD amp went and took a poop on me a couple ago :(
  12. Jun 23, 2011 at 4:21 PM
    #252
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Just got mine it and LOVING it!
    It's a 1400 watt 12" Pioneer powered by a 1000 watt Crunch amp. Not the best stuff but I picked it up pretty cheap and I love how the amp lights up. The little V on it pulses... so sweet.
  13. Jun 23, 2011 at 4:55 PM
    #253
    twistax
    twistax Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
    Finaly got some pics up... excuse the box its 2 weeks old and i havent bought carpet LOL Excuse the dirty truck lol
    Kenwood KDC-X895
    Older Kenwood 2 channel 450w Amp (not mounted yet)
    Kicker 10" Shallow mount sub and the new box, I left room on the left side for another sub at some point.
  14. Jun 24, 2011 at 7:07 AM
    #254
    pinktaco808
    small yeah the box?
  15. Jun 24, 2011 at 10:08 PM
    #255
    07TacoRidah
    Pioneer DEH-P5000UB H.U.
    was using a DHD 1600w amp but it's out of commission at the moment
    two 10" Zues HZ 10's
  16. Dec 3, 2014 at 10:13 AM
    #256
    Turttle98
    Turttle98 Active Member
    Abel
    California
    06 trd sport dbl cab 8.5 inch lift diamond whit
    8.5" lift kit with fox coilovers and double rear 2.5 fox shocks with bypass reservoirs on each side Kenwood ktv-516 indash kit Kenwood door speaker Kenwood tweeters 10" kenwood sub
    On your old setup how did you get set it up with the seat bracket they're like how did you do it with the box there
  17. Dec 3, 2014 at 11:04 AM
    #257
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Ill try dig up some old vids and pics.
    First i had 2 dd9515G on 6.5 kw rms in a 9 CF tuned 33hz with seats removed.
    Then i swapped out the DDs for DC xl's for the new coil config. I was able to run my amps at .33 ohms for Bass race and burps. Gained 2.7 db on this alone.
    Wasn't happy so i walled my truck with 4 Fi neo N3 15s on 2 Soundigital 12kw.
    Didn't get to complete the project but did 156.6db at a show and bass raced an easy 150db.
    Then stripped that out, sold it all. New project is basically as much as i can fit within a 9cf L shaped box. Custom removable infinity G35 seats for when i go wheeling/ camping and need to take my engel fridge freezer with. Most likely go with 4 12s on 6kw with a massive forward firing kelf'd port
  18. Dec 3, 2014 at 11:07 AM
    #258
    Aw9d
    Aw9d That one guy
    holy thread revival batman!
  19. Dec 4, 2014 at 9:48 AM
    #259
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    Lol.
    Although I would like to know more about Turttle's blow-through
