Anyone steam clean your engine?
Discussion in 'Detailing' started by nextfriday, Nov 6, 2013.
  1. Nov 6, 2013 at 6:08 PM
    nextfriday
    nextfriday [OP] Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    I've never done it on any vehicle I've ever owned. It showed. A buddy of mine cleans all his vehicle motors yearly, with a power washer using hot water. His Motors with 100,000 miles look spotless. Wondered if anyone hit the 4.0 liter with water and what your results were? I always cringe when I think of wires and water.
  2. Nov 6, 2013 at 6:11 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Done it with warm water and simple green but never "steam" cleaned an engine compartment.
  3. Nov 6, 2013 at 6:18 PM
    AR15xAR10
    Just be careful not to let degreaser eat into the plastics and dis-color them.
  4. Nov 7, 2013 at 9:16 AM
    Mr. Sparkle
    Mr. Sparkle Well-Known Member
    Bryan
    Long Island, NY
    Silver 09 TRD Sport
    Leer Cap Subfloor, water pump, marine battery, 45 gal water tank & plumbing to wash cars anywhere
    not something I do all that often. But if you cover some of the electrical components and alternator with foil or baggies - and use lower pressure (garden hose - no pressure washer) then you will likely be fine
    the pressure washer under the hood makes me nervous because although the engine bay can get wet, you're forcing moisture into some tight spots with the pressure washer
  5. Jan 4, 2014 at 6:37 PM
    StormRunner
    StormRunner Well-Known Member
    Josh
    Austin, TX
    08 Tacoma white "n" black SR5
    I steam clean mine about once a month and I like the out come. As far as water and electrical goes don't worry about it. Never had an issue, all your connectors are a sure seal or amp seal connection which has a couple gasket like rubber on each end of the connector.
