Anyone super experienced with BHLM???
Discussion in 'Southern California' started by Taco-Dazed, Apr 22, 2014.
  1. Apr 22, 2014 at 4:20 PM
    Taco-Dazed
    Taco-Dazed [OP] Well-Known Member
    California
    '08 Tacoma 4x4 TRD
    I don't have my stock headlights, and I have had a couple of ebay BHLM headlights. They all seem to fog up at some point, the newest set just fogged up again! And I am looking to see if anyone has experience sealing them up, to make sure they don't leak. I am willing to compensate you for your time
    Just want some damn headlights that don't fog up every time I go to the car wash lol
    PM me
    Thanks
  2. May 5, 2014 at 6:47 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    just pop them open and clean the inside out and use some clear caulk between gap of where the lens meets the housing. when i did he BHLM thats what i did and no fogging or moisture. i put them back together with the factory sealant and then just caulked over it. just make sure you follow the how to thread on the BHLM to make sure you take them apart correctly.i followed it to a T and it worked fine. the only thing that i had to change was the time in the oven. i set the oven to 310 then turned it OFF and THEN set the Light in the oven for 12 minutes.
    you wan to make sure you do one light at a time and make sure that the oven is OFF when you put the light in. if its still on you will melt the lens and you will hate me for trying to convince you to do this lol
