Anyone swapped in a 302 into a 1992 or earlier tacoma ,what headers were used?
Discussion in 'Performance and Tuning' started by williet57, Sep 15, 2012.
  1. Sep 15, 2012 at 4:26 PM
    williet57
    williet57 [OP] New Member
    I am looking at a 92 tacoma 2wd with a 302 and c4 transmission. the owner said they do not make headers for this swap.He cam up with what looks like the headers are up flow and bend toward the front of the truck then they go down and under to the exhaust.They are wrapped but I think there should be another opyion. Any Ideas?
  2. Sep 16, 2012 at 9:48 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    They didnt make Tacomas in 1992..
    So must just be a standard Toyota P/U.
    What are you asking? They dont make headers your going to have to either modify some headers or make your own, those are your options. . just run what it has, that obviously easiest
  3. Sep 16, 2012 at 9:54 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    How much issue you buying it for and like the post above says you gotta do custom in a situation like this
  4. Sep 16, 2012 at 5:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Sep 16, 2012 at 5:54 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  6. Sep 16, 2012 at 11:13 PM
    BAMFTACO
    Juan
    Kings bruh
