Anyone switched to synthetic and wish they hadn't?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sulaco, Sep 11, 2017.
  1. Sep 11, 2017 at 7:59 AM
    sulaco
    sulaco [OP] Active Member
    Lexington, SC
    2002 and 2014 Tacoma Access Cab TRD 4WD's
    '02 - OME/Billy's, BFG MT's '14 Mostly stock
    My 2014 has about 35k and it due for an oil change. I've always used Castrol GTX 5W-30 and the previous owner (just a couple of oil changes) had it done at the dealer, so whatever they use, Castrol bulk 5W-30 I think
    Anyway, my wife drives a 2016 Mazda CX-5 and it calls for a moly synthetic 0W-20 oil. I see Pennzoil makes one that meets these specs and was wondering if it would be a problem to use in my Tacoma?
    Anyone else running thinner synthetic oil? I still plan to change it every 5k, but it sure would be nice to just have to buy one oil vs two.
  2. Sep 11, 2017 at 8:03 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Syn, dino, good, cheap oil. It all works. Just is how long do you want to go between changes. Switch between, or do what ever you want. I have a fleet of cars and trucks. Run what is on sale, many have over 100K with no problems.
  3. Sep 11, 2017 at 8:07 AM
    sulaco
    Lexington, SC
    I guess I'm more interested in changing viscosity/weight and the added moly. Just a lot of changes all at once vs just using whatever.
  4. Sep 11, 2017 at 8:17 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Agreed. Oil is oil is oil. Pick one and use it.
    Mully[QUOTED] likes this.
  5. Sep 11, 2017 at 8:19 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Im not going to lie in the old days I put 300,000 miles on a truck and maybe changed the oil seven times. Do what you like (I thought it was 70,000 between oil changes )
    Bebop, JoefromPTC and Mully like this.
  6. Sep 11, 2017 at 8:28 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP what ever you do, stick with an oil that Xw-30 for your v6, its designed around an oil that 30 weight at operating temperature. so 0w-30 5w-30 or 10w-30 will all work fine, preferably if you are using synthetic run a 0w-30 cus you can (regardless of climate) as it will offer the best startup protection. FYI a 0w-30 oil is still to THICK at 100*F ambient temps on a "cold" motor to properly lube compared to its 30 weight property at operating temperature. That stated, its MUCH thinner than a 5w-30 or 10w-30 so it will lube much better till the motor warms up.
    NAAC3TACO likes this.
  7. Sep 11, 2017 at 8:34 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I would stick with something that has a "hot" rating of 30. The VVT in the trucks is set to work on oil pressure and a thinner oil might change its behaviour. Or possibly not.
    5w-30 for normal conditions. If you're in Alaska or somewhere very cold you could try 0w-30 so the oil stays thin on start up.
  8. Sep 11, 2017 at 8:43 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Check the manual for the CX-5, it may allow you to use a thicker oil in a warm climate.
  9. Sep 11, 2017 at 8:50 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    MQ oil should not be run in engines that do not need it, as it could wreck your emissions sensors and cat
    SkyActiv engines require 0W20-MQ. The MQ oil has Moly added to reduce friction.
    I have no idea if tacoma emissions systems can handle added Moly, but since all that crap
    costs thousands to replace, and a ghost fart can kill them....I'd keep MQ oil out if it
    synthetic hell yeah use synthetic...but with Moly ? not sure and no clear answers
    other than.... MQ is out of spec as far as the Manual goes....it is not mentioned, therefore roll the dice. I don't like to play dice with this motor...no MQ for me but always Mobil 1
    DanoDavis and JoefromPTC like this.
  10. Sep 11, 2017 at 8:51 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If you still plan on changing your oil every 5k its a waste of money to run synthetic. The point of synthetic is to increase your oil change interval.
    Nothing bad will happen when switching to synthetic. The claims if leaks are okd wives tales.
  11. Sep 11, 2017 at 9:10 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Then get rid of your truck which calls for 5W-30 and buy a vehicle that calls for 0W-20.
    Oreo Cat likes this.
  12. Sep 11, 2017 at 9:18 AM
    el_smurfo
    el_smurfo Well-Known Member
    Syn, no syn, doesn't matter. The viscosity is important and I would not run 20 weight in a truck designed for 30.
    Lester Lugnut and PackCon like this.
  13. Sep 11, 2017 at 9:24 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    * Use the weight of oil the owners manual calls for.
    * Regular oil works, but synthetic works better. That has been proven beyond any doubt.
    * Synthetic not only works better, it can go longer between oil changes and will cost less in the long run. Lots of guys with 300,000+ miles with 10,000 mile oil change intervals with synthetic. If you insist on 5000 mile oil changes then you are wasting your money on synthetic.
    I've never understood that logic. I buy oil in 5 qt jugs. Two jugs of 5W30 oil costs exactly the same as one jug of 5W30 and one jug of 5W20.
  14. Sep 11, 2017 at 10:27 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    I use Mobil 1 synthetic and change every 10k miles. You'll waste more money doing 5k changes, the oil still looks decent at 10k. If you want added insurance cheap, just change the filter every 5k and the oil every 10k. Filter costs $6 + a quart to refill what's in there.
    You can flip flop synthetics and regular as much as you want, it's pretty well documented that doesn't actually hurt anything.
    In my diffs and transfer case, I run regular 80w-90 non-synthetic because I plan to change it every 10k - 15k miles, mainly due to water driving, towing, and offroading. No sense wasting money on expensive stuff I change out all the time.
    For engine, I use Mobil1 0W-20 Syth because I like it. But I have a 3rd Gen. Use what the engine was designed for, in your case 5w-30 or at least xW-30.
    Basically as long as you are monitoring the situation you really can't go wrong. Super short intervals are fine if you want to spend the $$, if you gives you the peace of mind you're looking for. I'd imagine I could take my motor oil to 20k if I changed the filter a few times, but why bother, I can buy 5 quarts of m1 0w-20 syth for $22 at walmart.
  15. Sep 11, 2017 at 10:32 AM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    It is nice that 3rd Gen Taco and 5th Gen 4Runner use same 0w-20. However, still use different filters, so to the OP, unless you buy two of the same engines you're gonna still have some things to "manage."
    When my oil filters come in I take a sharpie and write T4R and Taco on them so I know which one it is without needing to remember part numbers. Buy sharpie, write on Jugs, problem solved :)
  16. Sep 11, 2017 at 10:54 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Good information above on watching your oil weights. I like synthetics but I dont always use them. They are great oil in in gear box/differentials. Uniformed molecular structure gives them great longevity in areas that you don't change oil frequently. I have good luck with the Redline product line reducing friction loss in the drive line but in the engine when the change interval is done more frequently- you wont regret using the synthetic however there is a argument the cost does not off set the negligible benefits over straight oil or a blend. I usually buy a name brand product that is on sale and bounce between synthetic or blends.
  17. Sep 11, 2017 at 12:55 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
  18. Sep 11, 2017 at 1:03 PM
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    Your 14 and my 15 are the same. I use M1 5w-30 and a toyota filter at 5k intervals. The oil is good for 10k but I
    don't like to push it. All oil is NOT the same. Use good oil and the engine will last a very long time. Except for the Gen 3 trucks. They suck.
  19. Sep 11, 2017 at 1:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    You ask 3 questions. Syn vs dino, syn vs moly syn, and viscosity change.
    To answer your post title, no.
    Run correct viscosity, run correct SAE rating.
    Don't bother running syn unless you are severe duty or are willing to change your OCIs to 10k. Otherwise you waste $ and resources.
    Lester Lugnut likes this.
  20. Sep 11, 2017 at 1:18 PM
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    Spoken like a future Gen 3 owner hating on 4th Gens in 10 years :) The cycle of life continues.
    They might be underpowered but so was the 22RE and that turd of an engine wouldn't die.
    DanoDavis and BillsSR5 like this.
