Anyone tried this brand of seat heater?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MightyYota, Jan 8, 2015.
  1. Jan 9, 2015 at 2:49 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've had my seat heaters installed since 2007. They're underneath the factory clothe (as seen in the writeup http://www.lieblweb.com/heatedseat.html) and I also have seat covers.
    In 7 years, I haven't noticed any issues.
  2. Jan 9, 2015 at 2:57 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    I actually couldn't agree more. Looked way to hard for me. Had them professional installed here in KS at a place called Chux Trux. Took them about 3 hours and $199 per seat. I love them. Super warm under cloth seats.
  3. Jan 9, 2015 at 3:08 PM
    MightyYota
    MightyYota [OP] Well-Known Member
    Jeff
    Galactic Sector ZZ9 Plural Z Alpha
    SR5 Texas Edition 4x4
    ARE CX Camper
    Thanks to everyone who has contributed! Keep 'em rolling in :D
  4. Jan 9, 2015 at 3:09 PM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    In for a warm buttocks
  5. Jan 9, 2015 at 7:46 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    SO what's the verdict? Which heaters work well? I am interested in this mod but bewildered by the choices listed here.
    What's the best recommendation? I have the TRD sport seats, will keep them cloth.
    Where did you get the power? Lots of questions... this sounds like a good mod.
  6. Jan 12, 2015 at 3:14 PM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    I have these http://www.cobraheat.com/WarmSeats-Seat-Heater_p_8.html in my Cobra and will be installing them in my truck next week. I plan to document so I'll remember to post here when done. These work very well. I'm also having my Cobra seats re-upholstered and will be putting new ones in. I've had them for eight years without a problem but the wife's behind is not getting warm anymore (or so she says) so in go a new pair.
  7. Jan 23, 2015 at 9:24 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Finally installed the heated seats from www.cobraheat.com What a difference and what a job, as others have stated on the forum.
    Would I do it again? Yes!! In a heartbeat. I have the same ones installed in my Cobra and they're great! Truck has cloth and Cobra vinyl and no issues with either of them.
    I’d first like to thank the following forum people who did alot of work prior to my installation and provided a wealth of information to those looking to do this.
    B737and his post on the Katzkin seat covers and seat heaters http://www.tacomaworld.com/forum/technical-chat/239372-2012-access-cab-katzkin-leather-installation-pix-heavy.html
    HomerTaco and his post on seat cover replacement http://www.tacomaworld.com/forum/technical-chat/89333-diy-leather-interior.html
    BenWA and his post on seat cover replacement http://www.tacomaworld.com/forum/group-buys/140277-katzkin-leather-seat-group-buy-19.html#post3078322
    My installation was just to install heated seats. I have the factory 2014 TRD cloth seats and wanted to keep them that way.
    One difference I found was both the lower cover and top cover have seams in slightly different spots on year models. I only had to make the two cutouts in the lower seat heater pad and none in the back seat heater pad. This will be something you have to evaluate when doing the installation.
    To save some forum space and the fact of going through pictures that have been posted many times before, I made a .pdf document that can be downloaded from my website and attached at the end of this post. I think between using this and the above posts, as well as this one will help you do the job. I have documented some of my install pictures below.
    The following two pictures show the bottom cushion with the seat heater pad being positioned. Notice where I put my two cutouts on the bottom cushion to miss the hog ring area. Also, put the lead-in seam just at the back edge of the cushion so you don’t feel it when sitting. The upper seat fits over this area.
    The next two pictures show the ground circuit connected to a bolt in the center console area and the power lead connection at the inside fuse panel. I used the rear power window circuit just as B737 did because I have an Access Cab.
    The next few pictures show the modifications to the switch blanks and panel that have to be modified to fit the seat heater switch assembly. I can’t stress enough how important it is to take your time and be careful. Mark the center of the switch blank and drill a small pilot hole. Then you can use your step drill to finish.
    You will need to cut the webbing out of the back of the blank to allow the switch to fit. You’ll also need to trim the panel opening to fit the new switch. I cut out the middle two side edges to make room for the new switch. Leave the top and bottom of the switch blank to allow it to fit firmly back into the panel.
    Then next two pictures show the upper seat cushion with the heater pad being applied.I was able to put the end of the heat pad edge just below the upper cross seam on the cushion and the bottom (with the lead-in) fit perfectly under the upper cushion. I did not have to cut this pad at all.
    Picture of what my dash now looks like with the switches installed.
    If I had to make a choice of what was harder, the heated seat pad or the switch install, it would definitely be the switch install. Although it takes a lot of time, it is much more tedious than you think. Trying to keep the same switch blank intact is indeed a challenge all by itself. However, I love to take on a challenge and the final product has "warm" results. :)
    TacoTuesday!! likes this.
  8. Jan 23, 2015 at 9:33 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Or put your switches here.
  9. Jan 23, 2015 at 10:36 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Thought about it, but didn't want to look down to see if they were on, plus my wife likes to put her purse there. This way, I can look at the dash and see them just fine. A little more work yes, but worth it in the end.
    I know I could always feel if they were on because that's how I have them in my Cobra. You can't even see them in that car.
  10. Jan 24, 2015 at 9:02 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    http://www.amazon.com/gp/aw/d/B00NH...SY165_QL70&dpPl=1&dpID=518-+q4R1QL&ref=plSrch
    I use these they are designed specifically for toyota vehicles and in the Tacoma the switch snaps right in to the knockouts in the dash, I get them from a wholesale distributor but have ordered these if I run out of stock they are exactly things same and work great. Perfect factory look. They are fairly reliable I have installed hundreds and only seen 2 or 3 go bad.
  11. Jan 24, 2015 at 9:37 PM
    DannyD
    DannyD Well-Known Member
    Dan
    BC Canada
    2021 DCLB
    I got the same setup. Kit from Heatedseatkits.com It comes with tools needed and its not that hard. Couple hours and your good to go. 2 years of running them everyday its not hot out and no problems. Just make sure you run it into something that doesnt run with the key in acc. Will kill your battery quick.
  12. Jan 29, 2015 at 9:43 PM
    dglove
    dglove Weekend Warrior
    Dan
    Denver, Colorado
    2013 TRD Sport 4x4 DCSB - Nautical Blue
    Toytec Boss 3" lift (LR UCA's, OME Dakars), FJ Trail team wheels, Duratracs, BAMF sliders, Camper shell, sleeping platform, Weathertecs, Pop n Lock
    Sub'd. Would love these during ski season.
  13. Jan 30, 2015 at 4:30 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Finished my console last night for front and rear heated seats.
  14. Jan 30, 2015 at 12:25 PM
    bbdmac
    bbdmac Well-Known Member
    Leominster, MA
    2013 TRD Sport Double Cab
    I purchased the Wet Okole seat covers and before I installed them I added the seat heaters (from Ebay) right on top of my existing cloth TRD seat covers. Then I put the Wet Okole's on top of everything. This eliminates having another layer of material between my ass and the heaters. Works great! The Wet Okole seat covers are very thick so it takes a few minutes to heat them up but then they work very well. I normally have to turn them down to low after 15 minutes or so.
  15. Jan 30, 2015 at 8:19 PM
    #35
    Anzy
    Anzy Well-Known Member
    Eric
    Pennsylvania
    That looks like it came from the factory like that. Good job! And great idea. I miss having a vehicle with heated seats. Especially with the cold ass PA winters
  16. Feb 1, 2015 at 3:55 PM
    #36
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
  17. Feb 1, 2015 at 7:01 PM
    #37
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    im doing this
  18. Feb 1, 2015 at 7:43 PM
    #38
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    #38
  19. Feb 1, 2015 at 7:45 PM
    #39
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
  20. Feb 1, 2015 at 7:47 PM
    #40
    SteveO86
    SteveO86 Well-Known Member
    South Korea
    2013 Super White TRD Sport DCSB 4x4 (Sold)
    BHLM w/ Retrofit, Window Tint, xB LED Fogs, Rigid Dually D2s w/ Amber Covers, Matt123 Skid & Tow Hook, Cobra 75 CB w/ 3' Firestik on BAMF mount, N-Fab Steps, Tonneau, Scangauge II, AVID Light Bar, Katzkin Seats, Remote Starter
    #40
