Anyone try auto Snow Socks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Jul 17, 2022.
  1. Jul 17, 2022 at 10:30 AM
    OnHartung'sRoad
    OnHartung'sRoad [OP] -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Wondering if these may work on my front wheels for 4wd in deep snow while using regular chains on the rear since the stupid Toyota engineers designed our front control arms so that we can’t put chains up front… anyone try these yet?
    If they work well, may also be a good lightweight emergency traction aid to just keep in the truck during winter. (I’m not sure if they are Highway Patrol/DOT approved for regular use on the rears for chain control requirements)
    AUTOSOCK 685 - Snow Socks for Car, SUV, & Pickup - Easy to Use Tire Chains Alternative (Pack of 2) https://www.amazon.com/dp/B001MS96FY
  2. Jul 17, 2022 at 10:42 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    doesnt look like it would work with any of the "normal" tire sizes ran by tacomas.
    nhpoke likes this.
  3. Jul 17, 2022 at 11:17 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    ^^- This was my observation as well.
  4. Jul 17, 2022 at 1:56 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    what kind of snow are we talking? there's about a hundred different types.
    high mountain cold snow with the upper crust, i think airing down is more effective to distribute vehicle weight.
    lower region high temp muck--slush/snow, they'd probably work better in scenarios where tread clearing is the main problem to moving forward
  5. Jul 17, 2022 at 2:04 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I’ve seen some Porsches wearing those to better manage icy slopes.
    they seem intended for mild use…
    ORtoCOTaco likes this.
  6. Jul 17, 2022 at 2:06 PM
    bush rat
    bush rat Well-Known Member
    BC
    2022 6MT Access Cab
    i wouldn’t bother with the socks.
  7. Jul 17, 2022 at 5:13 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Better off with better tires.
    ORtoCOTaco, bush rat, vicali and 3 others like this.
  8. Jul 18, 2022 at 10:28 AM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    What if we get a negative offset wheels? Just enough offset to clear the UCA?
    Silentshredr likes this.
  9. Jul 18, 2022 at 12:57 PM
    OnHartung'sRoad
    That would be a lot of offset to fit chains on there.
  10. Jul 18, 2022 at 1:26 PM
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I’m wondering how other company can do it but Toyota can’t. Maybe aftermarket UCA? How much is a lot or too much offset? I’m asking too much questions lol. Hopefully someone from Toyota or someone know a way around it.
    My 2017 sienna has about the same clearance from the tires to the UCA and the manual say to chain the front (fwd).
  11. Jul 18, 2022 at 2:56 PM
    T-Dogg's Taco
    T-Dogg's Taco New Member
    Terry
    2015 Silver Sky TRD Sport
    The socks I have seen in use have a very short life to them. (Think emergency use only). They tend to be most effective in 'wet' snow conditions. (Think PNW) compact wet snow with water running over. They won't work with dry powdery snow very well at all. And they WILL NOT hold up for any kind of distance driven on them...
    They might get you out of a jam, but they won't help you reach your destination. I wouldn't waste money on them, even if they do make a size that fits.
    erwigg likes this.
  12. Jul 18, 2022 at 3:01 PM
    saint277
    saint277 Vigilo Confido
    not suppose to put chains on your front tires per the manual, I have used chains on the rear to great effect.
  13. Jul 18, 2022 at 3:06 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Those look like something someone from the desert thought up..
    Get real snow tires. Leave the chains behind.
  14. Jul 18, 2022 at 3:14 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It’s not likely that chains or socks are going to help in non-hardpacked snow provided you have decent tires. They are more for icey conditions. DISCLAIMER: I’ve never used chains, studs, or socks on a automobile except when I made DIY studded tires with junk yard tires, nuts and bolts, and tubes.
    Studded bicycle tires are a game changer in icey conditions. You can ride on stuff you cannot walk on.
    grogie likes this.
  15. Jul 18, 2022 at 3:25 PM
    erwigg
    erwigg Well-Known Member
    Eric
    Oregon Coast
    2022 Tacoma access cab SR
    Siennas are front wheel drive.... although I should assume you knew that already. ( please don't beat me... at least not too hard)
  16. Jul 18, 2022 at 3:27 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Chains suck to put on, they're loud, and they beat the crap out of your truck. We used them to get through 2ft of unplowed forestry roads doing culvert surveys. Nobody is going to actually want to put them on a Tacoma, and if you ever did put them up front you would likely tear out your suspension.
    Studded tires or modern studless like Blizzaks do everything you need on a road, and if the snow is deep you'll want flotation and paddles like an MT. If you are in CA get some cables.
    Only people who have never used them drool about how great they are..
    JGO likes this.
  17. Jul 18, 2022 at 4:02 PM
    OnHartung'sRoad
    Cables are horrid, they’re only about half as effective as chains... and I’m quoting a CHP test report. I resort to using my double lug chains when things get bad, and yes I’m in Southern California. We only get a week or so of bad roads, especially on the back roads when it ices up when it actually does snow here, otherwise standard mud and snow tires are enough. There are some areas where we get several feet of snow on unplowed roads I have to go, and I used to be able to put chains on the front too but not anymore so I either had to walk or use a different vehicle in winter for work.
  18. Jul 18, 2022 at 4:14 PM
    gudujarlson
    Minnesota
    I live in an area that has snow 6 months of the year and I’ve never seen an automobile with chains, socks, or studs (illegal in my state). If you are worried about getting stuck, upgrade your skills, tires, shovel, and traction boards. The best things about snow are that you can dig yourself to solid ground and it doesn’t get your truck dirty.
    vicali likes this.
  19. Jul 18, 2022 at 4:43 PM
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I know and I did read the manual. Now I know the reason why. We might not need it, but was just wondering if there’s a way around it.
    No one is gonna beat you lol. I know they are front wheel drive. I did put them in parentheses in my post (fwd). The only reason I’m bringing up the sienna is because it’s made by Toyota as well and you can put chain in the front where the Tacoma and 4Runner, you can’t.
  20. Jul 18, 2022 at 4:52 PM
    saint277
    Most manufactures recommend chains be put on the main drive wheels weather they are front or back, but I don't recommend tire chains on the front for any vehicle. The steering knuckle to frame brake flex line is just to exposed on the front tire, on the rear its a hardline farther in along the axle making it much harder to damage if the chain fails.
    edit: also not every truck is 4x4 and the manual doesn't differentiate, imagine you put tire chains on the front in 2x4, so they say rear to save use from the idiots.
