anyone upgrade to a heavier rear spring?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodchip, Jun 16, 2013.
  1. Jun 16, 2013 at 10:27 PM
    woodchip
    woodchip [OP] Well-Known Member
    calgary,ab
    2013 taco 4x4 v6 manual
    firestone ride-rites
    anyone upgrade to a heavier rear spring?I had 1000 lbs of gravel on my new taco and it sat on the frame bumpers.one dealers aftermarket dept has a heavier rear spring for $750 installed.no lift but stiffer.complete replacement set.
    sound alright?any potential problems?I just know when I go camping between my trailer tongue weight and camping gear I'm at at least 1000 lbs and I still want some suspension travel left.I know the empty ride will be stiffer but I think I'm alright with that.
    Any thoughts?
  2. Jun 16, 2013 at 10:38 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I just switched to an allpro expedition pack. So far it has been excellent. rides pretty firm until you get a few hundred pounds in the bed but it's a truck so it's fine by me. Check out OME Dakar packs as well. Dealer option is a bit expensive but if they install it for that it might not be a bad deal unless you could do it yourself.
    Edit: also with the expedition pack and Dakar pack you will see upwards of 3" lift.
  3. Jun 16, 2013 at 10:39 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Love my Dakars
    These are good if you wanna stay close to stock height
  4. Jun 16, 2013 at 10:41 PM
    SconnieHailer
    Marc
    ^ yea for a spring pack that can handle some weight, the Dakar or Expo would be your best proven by TW picks.
  5. Jun 16, 2013 at 10:49 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    1000lbs of gravel plus driver has got to be close to its limits already, pls use caution if exceeding the total payload.
  6. Jun 17, 2013 at 5:26 PM
    woodchip
    calgary,ab
    my dodge had a payload limit close to the Tacoma.took 2500 lbs to bottom it out.I think the only thing lacking is a beefier spring set.
    not that I want to overload the truck...but
    truck cap 100 lbs
    tongue weight 250 lbs
    passengers 300 lbs
    kayaks 100 lbs
    luggage 100 lbs
    that's 850 lbs before tents,propane,stove,barbque, and the rest of my camping gear.I just don't want to be dragging my butt on the ground when driving 600 km each way when going to the mountains.
    I see you can buy three different truck campers for the short box Tacoma from 850 to 1100 lbs.how is a person suppost to use that on a truck with a 1050 lbs payload capacity?
  7. Jun 17, 2013 at 5:47 PM
    SconnieHailer
    Marc
    lol! The All-Pro Expeditions should be good enough for you. i'd recommend them. Anyone have experience with OME Dakar pack max weight characteristics vs the AP Expo max weight characteristics? I'm not sure which on handles weight like that better...? I'm guessing maybe the pack with overloads would be better? OME Dakar then?
    Also woodchip, if you are running max payload often you should probably look into a bumpstop like the timbren or an air bag setup to keep you from getting squirmy with all that weight.
  8. Jun 17, 2013 at 5:58 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think air bags are a better way to go for load support and no lift.
  9. Jun 17, 2013 at 5:59 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    x2. im a happy wheelers customer but I just run the 3 leaf aal. I don't often run weight in this truck, but the aal helped a great deal in handling my boat and hauled a co-worker's much heavier boat very well.
    they don't make these springs in their backyard, they are made by a reputable spring company, Alcan would be my guess
  10. Jul 21, 2013 at 10:33 AM
    Ray07tacoma
    Ray07tacoma Well-Known Member
    Ray
    Phoenix
    07 Tacoma access 4x4
    turbo KN Filter 3" Lift Kit Rock Sliders TRD Skid plate ProComp 285/75R16, Removed. FJ Wheels w/ 265/70R17 Delay wiper switch 168xxx miles, engine lost compression at cyl 1. Replaced with pulled engine with 63k miles (non Turbo).
    I bought Skyjackers leaf springs. So far, very happy about ride and carrying load.
    Drove from Las Vegas to Phoenix with 1700lbs in bed + 300lbs (tools+ Driver) without any issue
