Anyone use 0W-20 oil ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KJaikaran, Feb 23, 2013.
  1. Feb 23, 2013 at 9:14 PM
    KJaikaran
    KJaikaran [OP] Well-Known Member
    Orlando FL
    2011 Tacoma DCSB TRD Sport
    URD intake/maf calibrator, Icon extended travel coilovers, Icon UCA, OME Dakar leaf packs, Bilstein extended rear shocks, 3 degree axle shims, Carrier bearing drop bracket, DS2 retro, 5k HID bulds top and bottom
    Went to the Toyota dealership today and they had this sticker on every vehicle on the lot. I have been using 5W-30, so I might make the switch.
  2. Feb 24, 2013 at 2:25 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I wouldn't feel safe using an oil that thin. It says right on the sticker that the reason for the switch is for MPG and emissions reasons, not for engine protection reasons.
  3. Feb 24, 2013 at 2:30 AM
    03f5sp
    Bill
    Wisconsin
    The fact that it's a thinner oil and they say you can go longer between oil changes also really scares me.
  4. Feb 24, 2013 at 3:31 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I have been using 0-20 oil in my Prius for 3 years now. 0-20 only comes in synthetic. Use it only if it is recomended for your specific engine. I would not change to 0-20 if 5-30 is recommended. My 13' Taco recommends 0-20. With the tighter clearances in the new engines, thinner oil is not going to harm them. It will let them run more efficiently.
    Pros:
    *Longer time between oil changes ( Although 10k is the recommended milage between oil changes, I change it every 5k).
    *Great gas milage ( I get 55 mpg in my Prius. I have not had my Taco long enough to see any difference between my old '03 2.7l and my new '13 2.7l).
    *better starting in very cold weather
    Cons:
    *Expensive ( although I have found 0-20 more expensive than 5-30 synthetic, the price difference has been getting smaller).
  5. Feb 24, 2013 at 4:35 AM
    tacomarandy
    tacomarandy Well-Known Member
    Central FL
    '13 Prerunner SR5
    2013 V6 Tacomas still have 5w-30 in them. The 4 cyl ones come with synthetic.
  6. Feb 24, 2013 at 4:58 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2015 DCSB OR Auto Silver Sky 4x4 / 2017 4Runner Premium
    Use ot all the time in the wife's Sienna. Thats what it calls for. Buy it at Wally-World.
  7. Feb 24, 2013 at 5:33 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Op, as mentioned follow your manual recommendations. Since I have a 2.7L, 0-20W is a option which I use.
  8. Feb 24, 2013 at 5:37 AM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Been using 0W-20 since I went to synthetic Mobil 1. No issues and my user manual says I can use it.
  9. Feb 24, 2013 at 5:40 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    4cyl has 0W-20
    6cyl has 5W-30
    That's that...nothing new...OP has a V6...he should stick to 5W-30, and if he hasn't done so, switch to synthetic (use Mobil 1) 5W-30.
  10. Feb 24, 2013 at 6:09 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    I used Mobil 1 0W-30 the oil change before this most recent one and there honestly wasn't a fuel mileage difference. I track every fill up with Fuelly. While using it, the engine stumbled more and generally felt less refined than it does now with Mobil 1 10W-30. I did also go 15K miles with it kind of by accident (thought I was only at 10K) and it looked fine when I pulled it. I wouldn't hesitate to use it in a engine that calls for it.
  11. Feb 24, 2013 at 6:47 AM
    KJaikaran
    Orlando FL
    I have been using 5W-30 Mobil 1 synthetic since I got the truck. My manual says 5W-30 for the 4.0 V6, but I thought it was interesting that they had these stickers on the 2013 model Tacoma even though its the same engine.
  12. Feb 24, 2013 at 6:59 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    I use what is recommended by the manufacture for my year, make, and model.
    For distances between oil changes, I usually go in the middle of the oil manufacture and car manufacture. Right now I change at 5K.
  13. Feb 24, 2013 at 7:34 AM
    TexasCub
    TexasCub Well-Known Member
    2013 PreRunner
    I used it when I lived in interior Alaska because of the extreme cold temps, but living in a place where 100 degrees is quite common that thin of oil kinda makes me apprehensive to use it. But my Tundra called for 5w20 so who knows.
  14. Feb 24, 2013 at 9:44 AM
    ssault
    ssault Daniel
    They're either lying or going against what Toyota tells them to put in the V6
    Either is pretty likely....
  15. Feb 24, 2013 at 10:17 AM
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    My Lexus LS460 specifies this oil...over 9 quarts of it!
  16. Feb 24, 2013 at 10:54 AM
    sde780
    sde780 Well-Known Member
    That's because 0w-30 and 10w-30 are the same viscosity when your car is warmed up! :p
  17. Feb 24, 2013 at 11:29 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Or the Lot Boy just putting stickers on all the vehicles, not just the models recently approved for use of 0-20W :D
  18. Feb 24, 2013 at 12:00 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    I have always used the 0w-20, Mobil 1.....108,000 + miles on my truck now!
  19. Feb 24, 2013 at 12:12 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    It is fine.
    I use it in my other truck and when I run out of the old stuff I have I will start it in the Tacoma.
  20. Mar 16, 2015 at 3:11 AM
    Mongo1958
    Mongo1958 Well-Known Member
    Van
    Newnan, GA
    2015 Bright White Access Cab
    Carbon filter removal, Intermittent Wiper Stalk installation, Cruise Control installation
    My 2015 has 0w20 but the book call for a change at 5k.
