Anyone use 0W-30 oil in the winter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gun guy, Aug 9, 2017.
  1. Aug 9, 2017 at 7:57 PM
    Gun guy
    Gun guy [OP] Tacoma Fanboy
    05 Trd Off road AC MT & 08 Tacoma 2.7 AC MT
    We have super cold winters here, constantly below freezing for months at a time.
    So I've been thinking maybe I should start using thinner oil in the winter to be nicer to my Truck.
    Any thoughts on the subject?
  2. Aug 9, 2017 at 8:12 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I use 0w-30 year round and there is no reason anyone running synthetic shouldnt regardless of ambient temps (im here in so cal). FYI 0w at 100*f ambient is STILL thicker than the 30weight property at a fully warmed up oil temp... that is to say even the "thin" 0w when cold is still too thick to properly lube a motor... but its MUUUUUUUCH thinner than a 5w or 10w cold.
    Norton and Clearwater Bill like this.
  3. Aug 9, 2017 at 8:17 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I run what the manual says to run. But with Mobile One Full Synthetic.
  4. Aug 9, 2017 at 8:17 PM
    Gun guy
    Ya, I've never really had an issue in the winter, however after doing some research I think it would be beneficial to switch to a thinner oil for those cold starts in the winter. It gets well below freezing here. I just didn't know if it would be OK to run a 0w30 in my 2008 2.7 MT 4x4. Never done it before, and I think the manual suggest a 5w20, however I think I've been using 5w30, or vise versa can't remember ( conventional ).
    :anonymous:
  5. Aug 9, 2017 at 8:21 PM
    Gun guy
    BTW with a few different cars I would notice certain sounds my engine made after starting up in the winter, didn't think much of it until just now after doing some research. I guess those engine sounds were from thick oil cold start problems, or maybe the internet is playing with my head.. IDK, all I know is I want to make this taco last as long as possible.
  6. Aug 9, 2017 at 8:37 PM
    nd4spdbh
    SoCal
    fyi the 2.7L after i think 2010 calls for 0w-20 to help with mpg 's .... Id run 0w-20 without any issue or hesitation in the 2.7
  7. Aug 9, 2017 at 8:39 PM
    Gun guy
    Interesting, that's great to know. Now I won't feel so hesitant. Might switch to 0w-20 this weekend then :D
  8. Aug 9, 2017 at 9:15 PM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
  9. Aug 10, 2017 at 8:48 AM
    Pigpen
    Dan
    Northwest Montana
    I run Mobil 1 0w-30 year rounding my V6. I didn't use my block heater last winter due to the location of my parking spot at the place I was renting. I feel like it started much better (easier and less of the sketchy cold weather start noises) than in the past when I was running the recommended oil weight in the same temps - minus 20F starts were pretty common last winter.
  10. Aug 11, 2017 at 10:16 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1.
  11. Aug 12, 2017 at 1:32 AM
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    I run 0W-30 synthetic year round. Like was said before the 0 weight at 100F is still thicker than is needed to properly lubricate. At operating temp they all end up at a 30 weight (which is quite a bit thinner than the 0 was at 100F). You end up at the proper viscosity faster because the oil starts out thinner. The faster you get to a viscosity that will properly lubricate the engine the less wear you ultimately have.
    It does help tremendously in cold weather though!
    I have oil pressure and temp gauges. With 5W-30 synthetic at startup I would peg out my 100 psi gauge if the temp got into the single digits (lowest I saw running that weight). With 0W-30 I started on the coldest day we have had around here in a long time, -22F! This time oil pressure was right at 90 psi on initial startup.
    Warmed up though, the pressure was the same.
    Norton likes this.
  12. Aug 12, 2017 at 4:04 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I have not, and I live in the Mid West. I just run the weight recommended on the cap. But if I lived in a colder climate like Minnesota or Michigan or especially Canada, I'd probably go for the thinner stuff for better protection.
  13. Aug 12, 2017 at 4:06 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I live in a northern state with below freezing temps for months. I've always used 5W-30 M1.
    Plain Jane Taco likes this.
  14. Aug 12, 2017 at 7:52 AM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    0w30 amsoil year round
    Norton likes this.
  15. Aug 12, 2017 at 7:59 AM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    I've ran 0w20 the past several years, 2 of those years I lived in nothern CO. Most all Toyotas and Lexus call for it now.
  16. Aug 12, 2017 at 6:16 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Sig45 likes this.
