Anyone use Ceratec?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by doru, Nov 25, 2023.
  1. Nov 26, 2023 at 6:12 PM
    #61
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    there are also a good number of different reasonings for "the best", all of which are different criteria for different people.
    for instance, my brz, a low rolling resistance tire was specifically selected both for CAFE standards, but also for it's grip characteristics to compliment and enhance the characteristics of the vehicle. replacements were $400 each, and they were summer-only tires. my replacements run $130 each, are all-season, have better grip characteristics, but also dull the characteristics of the vehicle somewhat at the same time.
  2. Nov 26, 2023 at 6:23 PM
    #62
    Clearwater Bill
    Billy
    Largo Florida
    I got your grip right here pal. :D
    soundman98[QUOTED] likes this.
  3. Nov 27, 2023 at 5:04 AM
    #63
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    a discussion of best. Anything opens up so many variables it is nearly insane. One must also remember that the manufacturer is in the business to make money, not give you the absolute best product available.
    If everyone was willing to pay $150,000 for a new Tacoma, I’m sure her manufacturer could make these with the best products available.
    soundman98 likes this.
  4. Nov 27, 2023 at 5:38 AM
    #64
    mit88
    mit88 Well-Known Member
    Planet earth
    You just did :D
  5. Nov 27, 2023 at 6:17 AM
    #65
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    But the cylinders are not yet worn - so IF the product works it couldn’t fill any of the wear anyway right?
  6. Nov 27, 2023 at 10:50 AM
    #66
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    I see no claims of repairing/reconditioning existing wear.
    https://pim.liqui-moly.de/pdf/en_US/liqui/51/P000017
    Description:
    High-tech anti-wear additive, suitable for most 4- stroke engines as well as manual transmissions and compressors. Reduces friction and wear thanks to a unique combination of ceramic compounds and chemical anti-wear agents. It will prevent direct metal-to-metal contact and reduce friction to increase engine life and efficiency in gasoline and diesel engines.
    Properties:
    - reduces frictional losses - use with diesel particulate filters - miscible with all commercially available motor oils - increases smooth operation - highest thermal stability - excellent high and low temperature behavior - ideal with turbochargers and catalytic converters - stable under extreme pressures - compatible with fine filters - no deposits - long engine service life - chemically inert - reduces fuel consumption
    Though they do proudly proclaim that it "increases smooth operation" whatever in the fcuk that means. :rofl:
    And, of course, they insert weasel language to avoid any actual obligation for the product to actually meet their totally-amorphous claims.
    "Our information is based on thorough research and may be considered reliable, although not legally binding."
    D.A.S. Taco and musicisevil like this.
  7. Nov 27, 2023 at 10:52 AM
    #67
    ace_10
    Rural NoVA
    If A mazon existed in the 1970's, STP would have had a 6 out of 5 star rating.
    BMH[QUOTED], soundman98 and MannyS like this.
  8. Nov 27, 2023 at 6:22 PM
    #68
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    You know, the only reason Mario Andretti won the 69' Indy 500 was because he was running pure STP.
    Say some people....
    ace_10[QUOTED] likes this.
  9. Nov 27, 2023 at 9:28 PM
    #69
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Lube-Gard in my transmission? Sure. Even guys on here with shops recommend it ie @gearcruncher
    This whatever it is in my engine… I need more proof or recommendations from actual mechanics with knowledge before I use something like this.
    auskip07 likes this.
  10. Dec 11, 2023 at 9:59 AM
    #70
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    So how many bottle do you use? If it's 6.2qts total for the oil change, do you use one or two of these?
  11. Dec 11, 2023 at 10:01 AM
    #71
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    One and a half. Shake well before application with fresh oil. Takes upwards of 500 miles to realize the full benefits as the binding process takes some time and I believe it’s heat activated.
    TS4x4[QUOTED] likes this.
  12. Dec 11, 2023 at 10:05 AM
    #72
    PTSDTherapy
    22 SR5 DCSB
    You say shake well…does this have solids in it?
    musicisevil likes this.
  13. Dec 11, 2023 at 10:07 AM
    #73
    lavrishevo
    2023 Trail Edition
    https://www.liqui-moly.com/fileadmi...a_Tec_Additive_EN_1802_view_M014152_53095.pdf
    TECHNICAL DATA
    Base: BN Mikrokeramik / BN micro ceramic
    Colour / appearance: beige
    Particle size: Mehrheit < 0,5 / Majority < 0.5 μm
    Temperature stability of the ceramic particles: bis +1200 / up to 1200 °C
    Density at 20 °C: 0,893 g/cm3 DIN 51757
    Viscosity at 20 °C: ~250 mPas DIN 51398
    Flash point: >100 °C DIN ISO 2592
    Pour point: -20 °C DIN ISO 3016
    Form: flüssig / liquid
    Odor: charakteristisch / characteristic
  14. Dec 11, 2023 at 10:11 AM
    #74
    TS4x4
    2018 TRD Offroad
    Cool, thanks. Just hit 90k and want to keep my engine running smooth, especially with winter about to hit and parking outside. Not uncommon for it to be 30°F or less when I leave for work in the morning.
    So about 5.9qts of oil in addition to the 500ml of ceratec?
    lavrishevo[QUOTED] likes this.
  15. Dec 11, 2023 at 10:17 AM
    #75
    lavrishevo
    2023 Trail Edition
    I do 1.5 bottles, a little over is not going to hurt anything.
  16. Dec 12, 2023 at 5:29 AM
    #76
    TS4x4
    2018 TRD Offroad
  17. Dec 12, 2023 at 5:57 AM
    #77
    BillyE
    BillyE Well-Known Member
    Why Cera Tec when you can Slick50?
  18. Dec 12, 2023 at 5:15 PM
    #78
    soundman98
    NW Indiana
    if this stuff works so good, why even use oil to begin with?
    Chew, BillyE, MannyS and 1 other person like this.
  19. Dec 13, 2023 at 4:31 AM
    #79
    JackSparrah
    JackSparrah Well-Known Member
    1999 SR5
    If this stuff isn't relevant to you, why troll people to begin with?
    TCoop13, s0dhi and TS4x4 like this.
  20. Dec 13, 2023 at 6:16 PM
    #80
    soundman98
    NW Indiana
    b_r_o likes this.
