Anyone use Ceratec?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by doru, Nov 25, 2023.
  1. Dec 15, 2023 at 5:06 AM
    #121
    BillyE
    BillyE Well-Known Member
    Interesting he also found buildup in the engine--there might be something to the fouled spark plug comments on BITOG. I think I'll stick with Mobil1.
    TS4x4[QUOTED] likes this.
  2. Dec 15, 2023 at 6:16 AM
    #122
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Yeah I saw that as well. He did say he ran 5 tanks through it, and we are looking at a (2 stroke?) lawn mower not a truck. The self cleaning systems could be different. I would be curious to see what the build up looks like without ceratec since an old little push mower like that probably doesn't have any sort of built in self cleaning mechanism such as port injectors and the heat burnoff cycle that a modern vehicle does.
    e6400ultra and D.A.S. Taco like this.
  3. Dec 15, 2023 at 2:51 PM
    #123
    TacoTuesday1
    SD CA
    PCV makes sense. Collected matter either gets sent back to oil circuit, or through intake tract dirtying the manifold, or both.
    Or hopefully not at all if running a catch can.
    or if rings have some blowby
    I have a cheap catch can that does collect some stuff over time and just empty it out every oil change
    D.A.S. Taco and TS4x4 like this.
  4. Dec 15, 2023 at 9:04 PM
    #124
    doru
    doru [OP] Member
    I am the OP.
    I used Ceratec in 2 BMW engines: an N52 (naturally aspirated 6 cyl inline) and in an N54 (turbocharged 6 cyl inline). The turbo engine also used to consume oil (a BMW thing) at a rate of about 1/2qt every 3000 miles or so.
    I also added only 1 can in a little over 6.5 qt of oil (6 cyl BMW engines use about 7qt). It was a bit below what Ceratec recommends. Anyway, this stuff was added when both cars had about 100,000 Km (60k miles). So I had a pretty good idea of mpg and oil consumption. Yes, I have no proof. My only proof is my word. And one of the main reasons I used it was because especially the n/a engine (X3 F25) I used in winter. The cold starts were much better. Also, both cars quieted down pretty good, and I mean all the clatter of valve lifters and other components. And also, because apparently the "coating" lasts for an extended period of time, one would add the can every 3d oil change. I started this in 2012 or so (the Ceratec additive). In my experience it worked OK. It's not a "spectacular" change, but for me, stopping the oil consumption, much less engine noise, especially at cold start, and a slight improvement of mpg is worth it. We are close to ending 2023, and both my BMW's I mentioned run extremely well. If that product would grenade the engine, I think I would have witnessed it already. It's been quite a few years. Was curious if any of the Taco community has tried it and if also slight mpg improvement, cold start noise etc is any better. That's all.
    I think I will try it on my Taco on the next oil change, then every 3d after that.
    TS4x4 and D.A.S. Taco like this.
  5. Dec 15, 2023 at 9:49 PM
    #125
    TacoTuesday1
    SD CA
    well I guess we’ll have to wait and see if folks try it on their Tacoma and if it makes a difference, and what engine. If it’s an engine that should even exist, ie 22R, 22RE, 1GR-FE, and not 3.5L, etc
    as the above doesn’t really apply
    German car clattering on cold start from oil CCT, burning oil, valve seals leak, etc? Sure
    Tacomas, not really
    if the only difference is going from 12.0 to 12.3mpg it’s probably not worth it and attributed to other factors
    BG MOA is not a bad additive. It’s also cheaper and more readily available.
  6. Jan 3, 2024 at 7:22 AM
    #126
    TS4x4
    2018 TRD Offroad
    I now have about 1,000 miles on my most recent oil change which included a bottle of ceratec liquid molly.
    Here's what I've found:
    - The engine is running noticeably quieter at start up in sub-freezing temps, which is what I wanted from it. I figure a quieter engine with less clatter means less wear and tear. I didn't tell my wife that I used ceratec in my last oil change and unprompted she commented that the truck sounded quieter and asked if I changed something on it.
    - Slightly less gear hunting especially on hilly drives which is a welcome surprise.
    - Gas mileage: TBD. I think it's too early to tell but haven't noticed any meaningful increase or decrease in MPG. Winter gas is garbage for fuel economy to begin with so I may see if it changes once they stations switch back over to the summer stuff.
    D.A.S. Taco likes this.
  7. Jan 3, 2024 at 10:36 AM
    #127
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    I put it in at my break in oil change. 23 taco, first oil change at 2300mi. Now let me first say I’m not a believer in additives, conditioners, or any other type of snake oils. I’ve never once put any type of product in any of my vehicles, but I thought I’d give ceratec a try from reading here and also on the 5.0 forums with their “ticking” noise which it’s supposed to resolve or lessen. It made a pretty substantial difference in cold start noise on my new truck. I haven’t cared nor will I monitor fuel mileage increases or anything like that, but on my almost new engine it really quieted cold starts down.
  8. Jan 3, 2024 at 11:50 AM
    #128
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    This thread.
    Me in back
  9. Jan 3, 2024 at 11:52 AM
    #129
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    :rofl::rofl::rofl:
    StayinStock likes this.
  10. Jun 15, 2024 at 7:05 PM
    #130
    TacoTuesday1
    SD CA
    reporting in
    used Ceratec
    noticed nothing besides loss of money
  11. Jun 15, 2024 at 7:12 PM
    #131
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
  12. Jun 16, 2024 at 4:34 AM
    #132
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    I'd like to back his statement up. I also noticed a lack of money and no difference.
  13. Jun 16, 2024 at 6:48 AM
    #133
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    Studebaker Tested Products
  14. Jun 16, 2024 at 8:25 AM
    #134
    Volt
    The active ingredient is hexagonal boron nitride. It is similar to graphite but is much more heat resistant. The troubling thing is it settles. Quote from Wikipedia:
    https://en.wikipedia.org/wiki/Boron_nitride
