Anyone Use Covers on Their Seats Like These?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wood714, Jan 15, 2019.
  1. Jan 15, 2019 at 7:16 PM
    wood714
    wood714 [OP] Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
  2. Jan 15, 2019 at 7:26 PM
    ChukarBob
    ChukarBob Well-Known Member
    Bob
    Seattle
    2017 TRD Sport DC LB 4WD AT; preceded by '15 Subaru Outback & 2007 Tacoma SR5 DC LB 4WD AT
    I've got a complete set of 4Knines (Amazon) in my truck. Bought these because I was allowing my new pup, Calli, to ride in the cab when we went hunting. All of her predecessors rode in crates in the bed of the truck. Anyhow these covers are holding up well. Easy on and off. Mostly I just vacuum them in the truck when I need to have humanoids riding with me. So the covers are pretty much a fulltime feature now. Will remove them when I don't see the dog riding along with me in the cab, but that probably won't be often.
    wood714[OP] likes this.
  3. Jan 15, 2019 at 8:00 PM
    Loqu!to
    Loqu!to Somewhat skilled Rookie
    North VA
    2018 Tacoma TRD Sport MT OVTune
    MBRP Dual 409 SS Exhaust, many exterior mods.
    I want the seat covers from leatherseats.com too bad they’re expensive
  4. Jan 16, 2019 at 6:24 AM
    mdub
    mdub Well-Known Member
    Missouri
    2016 Black DBLC TRD Off-Road
    ARE CX
    Yes, I have something similar. It isn't an everyday solution as it moves around (even with the grippy microdots) and needs to be adjusted often over the course of a week. As a one off when you are dirty and wet, then ya, it works. I just got mine a couple weeks ago, so haven't really put them to the test with sweat, dirt, etc. But if you are looking for a permanent solution to save your seats, you may be disappointed.
  5. Jan 16, 2019 at 6:35 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    The problem with something like that as a full time use is over time they will rub your factory material and eventually cause wear. Might not happen right away depending on the cover, but it will happen.
  6. Jan 16, 2019 at 10:58 AM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Not bad for something quick and easy. I would go with the waterproof ones myself as that would be perfect after the gym etc. to keep sweat off your cloth. If you plan on using them more then occasionally I would recommend something more permanent. Check out a set of just the front Clazzio PVC's, with the TacoWorld discount code should be under $200 shipped.
    shane100700 likes this.
  7. Jan 16, 2019 at 11:25 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Get the Aries Seat Defenders. I have a set that is 4 years old and they stay in place just fine. I use a wet cloth to wipe spots off them if I happen to get something on them. You can use a garden hose on them if you want then hang them to dry off. Water sheets off them anyhow so it don't take long to dry.
    Comes in a couple different colors. I have the black ones. And I leave mine on the seats full time.
    https://www.amazon.com/Aries-Automo...47666660&sr=8-1&keywords=aries+seat+defenders
    https://www.youtube.com/watch?v=ErSgvQhQNSQ
    psmura likes this.
