Anyone use 'mini-cat' O2 simulators?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2ndchancetoyotas, Sep 24, 2013.
  1. Sep 24, 2013 at 9:27 AM
    2ndchancetoyotas
    2ndchancetoyotas [OP] Well-Known Member
    Greg
    AZ
    Rebuilt
    My truck is a salvaged fresh water flood truck. (yes I bought it this way) I think I have some semi plugged up cats because my powerband really starts to dump off on the higher end. I have another prerunner I'm comparing the powerband to.
    Aside from all the assumptions people are going to make about water damage.......
    Has anyone used the O2 sims that are a mini-converter? Where did you order them from and how were the results? I live in a no smog area so cats are not an issue. Was considering gutting them if necessary.
    Also, in case my muffler is plugged up too, can anyone suggest a muffler that isn't obnoxious? More stock like? I can buy an aftermarket muffler for less than most people want to sell a stock exhaust.
    thanks
  2. Sep 24, 2013 at 9:34 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If the muffler is clogged I would change that first and then see how the cats act. I had a thrush from Advance on my V6 Ranger. Sounded normal.
  3. Sep 24, 2013 at 10:55 AM
    2ndchancetoyotas
    Greg
    AZ
    Rebuilt
    Ok thanks. I still need to take it apart to visually inspect, but I have my suspicions.
  4. Sep 24, 2013 at 10:58 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    What year is it, 2005+ V6 has 4 cats. Upstream 2 are built into the manifold/header, downstream 2 are bolt on.
    Toyota quoted me $2000+ for 1 new upstream one. hopefully your lucky and it's just the muffler or downstream.
  5. Sep 24, 2013 at 3:49 PM
    2ndchancetoyotas
    Greg
    AZ
    Rebuilt
    So I pulled off one of the secondary cats (the passenger side thats bolted in) and can't really see through it enough to tell if it's plugged. There's a little bit of a bend in the pipe where it goes to the engine so I'm not sure if I just can't see through it because of the bend....or because it's obstructed. I know you can normally see quite a bit of daylight through a normal standalone cat. Odds are slim I would ever take this truck to a smog state/area, but still hate gutting the cat without knowing for sure.
  6. Sep 24, 2013 at 5:48 PM
    2ndchancetoyotas
    Greg
    AZ
    Rebuilt
    Put it back together and did a proper test drive (which i should have done before) and put it in a low gear and it rev'd easily into redline. Guess a lot of worry for nothing.
