Anyone use Shell Rotella T Synthetic
Discussion in 'Technical Chat' started by corrado007, Dec 17, 2009.
  1. Feb 22, 2011 at 8:33 AM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    I am surprised this thread has not had anymore posts?? i would have liked to hear from more Rotella T6 users, if ther are any?? So I am interested now and would love other to chime in whith experience on this thread. Not jacking just reviving ;) i too think it is a great oil and it does cover alot of bases as far as use goes, the CJ-4 really means it is built to handle the $hit that fleets throw at truck and cars, so why would it not excel in other arenas?
  2. Feb 22, 2011 at 8:44 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    its extremely good oil, keeps engine clean inside. However, its cold start sucks a lot (I think formula had changed to fix that) So I would be very careful if you are in cold climate and have new engine. that 5w-40 oil gets so thick when its cold oil pressure goes through the roof, and it won't come down until reaches almost operating temperature.
  3. Feb 22, 2011 at 11:14 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
    I live in the South East so maybe the cold would not hurt it much, I am currently using Royal Purple but the cost is a bit high, and I have heard nothing but good things about the Rotella 5w-40, thats why I am reviving this thread hoping others here can tell me what experience they have had with it in Tacomas, Thanks for the quick reply!
  4. Feb 22, 2011 at 12:24 PM
    BlueT
    NorthEast
    Yep so if you are in South you should be fine. I know Shell changed formula to improve cold start ups so next year I will be running new formula since I used up my oil stash :D Cold startup was the only thing that holded me from running that in 2gen truck. On my LC oil pressure goes sky high if its cold on start up. literally I am at maximum oil pressure at 900 RPMS and my truck has 180K miles. I can imagine if my bypass valve did not open the oil filter would disintegrate pretty much at start up.
    Otherwise yeah this is probably the best oil money can buy. My LC engine inside is pristine clean thanks to that thing. Look at pic I posted.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/58460-best-motor-oil-13.html#post2114282
  5. Feb 22, 2011 at 12:41 PM
    sloppyjoe
    All Over
    Silver and simple
    Non
    Very nice I'm sold!! I cannot wait to spend less money on my oil changes, RP will hurt you, I mean I could have vent shades on my windows if I was using Rotella :p
  6. Feb 23, 2011 at 5:57 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I use the rotella T6 5-40 in everything I own except the transmissions of my motorcycles, I use the 15-40 non synhthetic (T5?) in there so the clutches wont slip and glaze..
    Been using it for quite a while and I drive everything like I stole it and have had no oiling issues whatsoever, as a matter of fact I ran my 98 2.4L Turbocharged Tacoma (20psi) for quite some time, and when I tore the motor down to build it up it had relatively no wear on it, looked like new inside even though I was trying to kill it on a daily basis, lol.
  7. Feb 23, 2011 at 1:58 PM
    sloppyjoe
    All Over
    Silver and simple
    Non
    NOICE! Thats what I was trying to see, people who have run it in Tacomas with good results. I have pretty much decided I am going with it for good on my Tacoma when I do the next oil change. I really like what I have found out about this oil. A good buddy of mine just switched over his truck (Ford F250) and had great results. He swears he could feel an instant difference as the truck felt like it was running softer inside?? Yea, whatever that means, but its good $h!+
  8. Feb 24, 2011 at 6:12 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
    Morning bump, I am surprised there are not more people using this oil, as it is a very good oil. It out performs PAO base stocks in every test. But if this is it this is it, no need to keep it going if there are no more users out there, Thanks for all the replies!
  9. Feb 24, 2011 at 6:17 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    I use the heavy deisel oil in my 650 thumper DS. It stays clean for a long time and doesn't have any molyB additive.
  10. Feb 25, 2011 at 7:29 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I use the Rotella T6 5W-40 in my dirt bikes, my 04 tacoma and a 05 miata. It is API SM which bounds what the owners manual recommends. It is not, as has been mentioned, energy conserving. The 5w rating is for how the oil behaves at low temperature and the 40 is for high temperature.
    I like synthetic oil in cars and trucks because I can run more miles between changes. I run 10,000 miles on a synthetic oil change.
    I also like it because the Miata has a turbo and synthetic does not break down as fast as dino oil in high temps and in transmissions (motorcycles) .
  11. Feb 25, 2011 at 7:43 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2 on the dirtbikes.
  12. Feb 2, 2013 at 4:48 PM
    Oreo5
    Oreo5 Member
    Jersey Shore
    SR5
    Tinting
    Thinking about trying this, any feedback after 2 years of using it??
  13. Feb 2, 2013 at 7:27 PM
    corrado007
    corrado007 [OP] Member
    Justin
    Sacramento, Ca.
    '98 Tacoma 4x4 V6
    I used it in my Honda CBR F4i motorcycle and my wife's Ninja 250 for a few years and it was great for them, no problems at all. Of course that's a very different application but perhaps a more intense one as they rev much higher. In my Tacomas I've always used Mobil1 Synthetic from Wal-mart, it's pretty cheap if you get it there. I tried researching the whole oil topic for some time and found that it's nearly impossible to find the best oil, fact is, most oils will do fine and very few of us will ever notice a difference but I'd guess you'd be fine with Rotella, Mobil1, or any of the other popular ones. Good luck.
  14. Feb 3, 2013 at 2:19 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Walmart has a good price on it in the 5w40.
    http://www.walmart.com/ip/Shell-Rotella-Synthetic-5W-40-Motor-Oil-1-Gal/14958681
  15. Feb 3, 2013 at 5:38 PM
    #35
    Oreo5
    Oreo5 Member
    Jersey Shore
    SR5
    Tinting
    I guess I just feel weird about using 40 instead of 30 like is recommended. I too use Mobil 1 but from Costco because it comes in 6 qts which my 07 prerunner uses 5.5 qts. I've heard that Mobil isn't what they used to be since they switched factories (not sure if this is a rumor) but the same person said that the people that send their oil to labs found that Rotella was better in comparison. Plus its only $20 :eek:
  16. Feb 4, 2013 at 5:05 AM
    #36
    BRP27
    04 4X4 Tacoma SR5
    I am still using Shell Rotella T. But if I can't find it I use Mobil 1( but only in the car/truck not in the dirt bikes)
    The 40 wt vs 30 wt does not bother me. It is very warm around here
  17. Feb 15, 2013 at 6:13 PM
    #37
    Oreo5
    Oreo5 Member
    Jersey Shore
    SR5
    Tinting
    So youve noticed less MPG using it by what you said about it not being energy conserving?
    Is the 40 for operating in even higher temps than 30 would be? It gets to 100 degrees here with very high humidity.
    You said you go 10,000 on your synthetic oil changes, do you change the oil filter every 5,000 though or only at 10,000? On my 07 the oil filter is on the top of the engine so i could do this, not sure about the 04.
    Thanks!
  18. Feb 18, 2013 at 11:44 AM
    #38
    BRP27
    04 4X4 Tacoma SR5
    I have not noticed a change in MPG because it is not energy conserving. 40 is for higher temperatures vs 30wt. I do not change the filter between changes.
  19. May 23, 2013 at 6:08 AM
    #39
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    T6 all the way.
    Shell full synthetic in all my cars & trucks.
    Works great!
    Check shell gas stations & other auto-care retailers.
    U should be able to get it for $19 a gallon.
  20. May 26, 2013 at 4:35 AM
    #40
    Oreo5
    Oreo5 Member
    Jersey Shore
    SR5
    Tinting
    What trucks do you have that you use it on?
    If its the 07 TRD sport SR5, I have the same truck and would love to make the switch from Mobil 1.
