Anyone use Shell Rotella T Synthetic
Discussion in 'Technical Chat' started by corrado007, Dec 17, 2009.
  1. May 27, 2013 at 7:37 AM
    #41
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Yes.
    It is the '07 TRD sport.
    T6 keeps the engine clean, & is great for MPG.
  2. Aug 26, 2013 at 11:38 AM
    #42
    Oreo5
    Oreo5 Member
    Jersey Shore
    SR5
    Tinting
    Okay...it's in there... :pray:
  3. Aug 27, 2013 at 6:45 PM
    #43
    Flymaker
    Flymaker Well-Known Member
    Ohio
    SR5 Double Cab
    Bone Stock
    Rotella is great oil.....I work for a major fire truck manufacturer and its what we use....I have used it in my last truck and my bike......I am currently using 5-30 mobil 1 in my Tacoma....but I will make the switch to rotella 5-40 next change.....you may lose a tad in gas mileage but its probably not enough to consider.....its still a 5w so cold starts wont be a issue....don't see any issues with it.
  4. Sep 1, 2013 at 5:22 PM
    #44
    Oreo5
    Oreo5 Member
    Jersey Shore
    SR5
    Tinting
    Excellent, thanks for the reassurance. Where is your fire truck factory? My dad retired as a FF a few years ago in California. The trucks sure have come a long way since 1921. I switched from Mobil 1 5w-30 and lately, maybe just because it's fresh oil, it feels and sounds a lot smoother :cool:
    I'm really peticular when it comes to sounds and can tell when something is off, but in this case it seems better.
    I'm likely wrong here but I thought the second number (30 or 40) was the one that had to do with temperature?
    Thanks again!
  5. Sep 2, 2013 at 4:41 AM
    #45
    Suspiciousmind
    Suspiciousmind Member
    Mark
    NC
    99 Taco 4x4 ext cab
    Both numbers have to do with temperature. Basically, a 5w-40 behaves like a straight 5w when it's cold so it flows well on cold starts. It behaves like a straight 40w at operating temperature.
    That's it in a nutshell...You can research for details but you'll likely get overwhelmed by the details.
    Willbeck likes this.
  6. Mar 5, 2015 at 7:54 AM
    #46
    Manwithoutaplan
    ID
  7. Mar 7, 2015 at 4:42 PM
    #47
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I posted back in 2011 that I was using Shell Rotella T6 5W-40 in dirt bikes, Tacoma and other cars. I still am using this oil in everything except for a new Mini Cooper S. The Cooper has a European spec that requires a BMW oil that is required for warranty.
  8. Mar 7, 2015 at 4:53 PM
    #48
    Manwithoutaplan
    ID
    how many miles you got on the truck? trying to determine if i should run this or not.
  9. Mar 7, 2015 at 5:54 PM
    #49
    BRP27
    04 4X4 Tacoma SR5
    112,000 changing at 10,000 interval
  10. Mar 8, 2015 at 8:22 AM
    #50
    Mad Man Marty
    Marty
    PA
    Run it now.
    It does not matter when you change over to full synthetic.
  11. Mar 8, 2015 at 9:00 AM
    #51
    BRP27
    04 4X4 Tacoma SR5
    X2 Just do it. Its a great synthetic oil. I run it in the Tacoma , Honda Civic Si, CRF250X dirt bike , DRZ125 dirt bike, two CRF50 dirt bikes and a Garden tractor.
  12. Mar 8, 2015 at 12:15 PM
    #52
    Manwithoutaplan
    ID
    Been Running Mobil one since 40K.
  13. Mar 8, 2015 at 2:26 PM
    #53
    BRP27
    04 4X4 Tacoma SR5
    Mobil 1 is good. I run Shell Rotella T because I cant run Mobil 1 in the dirt bikes and its nice to have one oil for (almost) everything
  14. Sep 15, 2015 at 12:54 PM
    #54
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Just ran across this thread again and am about half-way through my first T6 oilchange. I'm planning on going 10,000 miles with this synthetic between changes. I've ran it in my 2004 STI before I sold it and I'm planning on using it in my 2004 TJ (4.0L)
    I witnessed reduced oil consumption with the STI and it tolerated the higher temperatures better than the Mobil 1 I had been using before that.
    For what it's worth I'm doing this for 2 big reasons. It's a single oil I can use for everything from my 4.0L Jeep, 4.0L Taco, 2.5L STI and my dad's 2006 Duramax. It's fairly universal for that reason and appears to actually be a good oil regardless of that multi-purpose use.
  15. Sep 15, 2015 at 12:56 PM
    #55
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I use it and have been for 80k+ miles
    I change it between 6-8k with a new OEM filter.
    1 big 1 small container from walmart.
  16. Sep 16, 2015 at 8:26 AM
    #56
    Jetty Rat
    Jetty Rat Well-Known Member
    South Texas
    2006 Tacoma Prerunner SR5 TRD Offroad
    Rotella T6 is great oil, but Shell no longer recommends it for on road gasoline engines with a catalytic converter.
  17. Sep 16, 2015 at 8:30 AM
    #57
    Jetty Rat
    South Texas
    From Shell's website. "The oil carries both the American Petroleum Institute (API) diesel "C" rating as well as the API gasoline engine "S" rating. Ratings differ based on the oil. Rotella oils like T3 15w-40 meets both the API CJ-4 and SM specifications, and may be used in both gasoline and diesel engines. However, it is formulated specifically for vehicles without catalytic converters, containing phosphorus levels beyond the 600-800ppm range. Therefore, Rotella is not recommended for gasoline vehicles with catalytic converters due to the higher risk of damaging these emission controls."
  18. Sep 16, 2015 at 8:59 AM
    #58
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    My cats have 200k miles and were in perfectly functional shape even after using rotella for 80k of that.
  19. Feb 26, 2017 at 4:29 PM
    #59
    Rooblik
    Rooblik Taxation is Theft.
    Grey 2009 Tacoma DCLB SR5 V6 TRD Sport
    I read on Toyota's website that if you're towing or hauling, a heavier (I think that's the current term) weight oil like 5w40 vs 5w30 could be beneficial. I haven't seen any threads about it though.
  20. Feb 26, 2017 at 4:42 PM
    #60
    Suspiciousmind
    Mark
    NC
    99 Taco 4x4 ext cab
    Key words,..."could be" as Long as no shock loading is involved, as in off-road .
    Xw-30 should be fine.
    I expect the thicker oil might generate more heat,leading to even thinner properties during operation
