Anyone use the auto-transmission to manually shift gears?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma-or-Colorado?, Jan 10, 2017.
  1. Jan 11, 2017 at 4:12 AM
    Tacoma-or-Colorado?
    Tacoma-or-Colorado? [OP] Well-Known Member
    Yeah, I was afraid it would not be just like the BMW's. It's such a fine drive train. But at least the Tacoma's AT sounds like it does give some flexibility. I was mainly wondering if anyone uses the "manual shift option" to negate some of the troubles I hear of with its transmission. Sounds like not every one does that.
  2. Jan 11, 2017 at 8:00 AM
    kerrdog
    kerrdog Well-Known Member
    2016 trdor mgm
    Never use mine for everyday use. If I wanted to shift gears I would have gotten a manual. To me shifting an auto kinda takes away from why I bought an auto in the first place.
  3. Jan 11, 2017 at 8:56 AM
    erok81
    erok81 Well-Known Member
    Imposter
    This for me too. Or sometimes when I'm really bored I'll do all of the shifting. :)
  4. Jan 11, 2017 at 8:58 AM
    erok81
    Imposter
    If I was to trade mine in and get a manual will it make as cool as you?
    SaulGoodman likes this.
  5. Jan 11, 2017 at 9:19 AM
    EnFuego
    EnFuego Member
    2016 Taco TRD OffRoad Inferno
    I absolutely use "S" mode manual shifting when crawling in 4Lo. Other than that I don't have much use for it unless managing speed while traveling down long mountain descents.
  6. Jan 11, 2017 at 12:04 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    . . .and don't forget "no clutch" in crawling traffic. I'm getting too old for that crap. Been there, done that.
    G.
  7. Jan 11, 2017 at 12:58 PM
    BadKitty
    BadKitty Well-Known Member
    Indianapolis
    2017 Black Tacoma TRD-offRoad 6spd
    TRD Intake, TRD exhaust
    Dunno about the "cool" part but you will probably see a 50% decrease in the passive-aggressive baby category. For you, that would probably be a significant enough upgrade to justify the cost.
    Cgullo83 likes this.
  8. Mar 13, 2017 at 8:34 PM
    rainyday128
    rainyday128 New Member
    Gen3 Long Bed Off-Road
    I can't stand the incessant shifting back and forth between 4-5-6 and locked up/unlocked torque converter. I manually shift it sometimes to make it more pleasant to drive. We live in a rural area and will put it in 5th in the "can't be in a higher gear than this" position (labeled as "S") to block 6th for cruising on windy local 45 mph roads. Using "S" won't force an upshift and won't prevent a downshift. "S" position only means it can't be in a higher gear than what is shown.
    Shifting to "S" from D will allways default to 4th which is a pain if you're already in 5th or 6th (it will force the downshift). I wish it would default to whatever gear you are now in.
    That said, I love the really tall gearing. All the new cars are going to more gears and slower rpm in top gear to meet the stringent EPA fuel economy regulations. But the new Tacoma is geared for '40 mph per 1000 rpm' which is taller than any other car I've driven. That's only 1750 at 70 mph. It's very comfortable for cruising on the loop around the city on level ground. But the tall gearing coupled with the low engine torque make it downshift on the slightest grade.
    securekey likes this.
  9. Mar 13, 2017 at 8:41 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    I use s4 for around town, s5 for highway, drive for interstate. I get better mpg using s4 and s5 for town and highway use, and it keeps the tranny from shifting too much at low speeds.
  10. Mar 13, 2017 at 8:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can't speak for the 6 speed Aisin tranny on the 3rd gens, but the Aisin a750e on the 2nd gen's has got to be one of the more solidly built trannies out there. Since 2012 truck brand new I have been slapshifting gears on mine. It gives me something to do while I drive and it gives me a reason to listen to that blower whine. Nothing has failed on mine at all and I'm approaching 80K on it. I should also add that by manually shifting the gears you are allowing better response over just throwing it in D and driving forward like a senior citizen. Many 2nd genner's do it for that very reason. I would imagine the same holds true for 3rd genners.
    You have to remember most Taco owners are city folk who tend to spend a lot of time locked in stop and go traffic trying to get to their jobs so they can pay their shiny pretty truck down to nothing owed to the bank.
    As a disclaimer I literally just modded upgraded the valve body today for more solid and firm upshifting as well as 4-5 shift up flare, but that is a common occurance across a lot if not all Tacoma's out there. Plus the tranny was allowing a lot of power to blow through, so I needed to do that.
    I'm not going to defend anything. I'm just stating what is known and what works out of all the different methods of driving these tanks.
    securekey and Riding Dirty like this.
  11. Mar 14, 2017 at 4:29 AM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    When pulling onto the freeway or interstate I manually shift. I start in S2 and manually shift to S5. I get the best acceleration and power that way. In town I use S4 for everyday driving. S5 for normal freeway or high way driving. And the gas mileage went up 1 to 2 MPG. 6th gear on these trucks is way to high and useless. ETC mode seems to hang too much in gear before shifting. Sometimes I forget and get back to manually shifting.
  12. Mar 14, 2017 at 5:45 AM
    Duff49
    Duff49 Well-Known Member
    Bucks County PA
    17 Sport TRD DCLB Barcelona Red
    100% agree - That's the only way to get on the highway. I also get a jerky acceleration at times. It seems to be a motor thing.
  13. Mar 14, 2017 at 5:59 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    It only really works to limit up shifting and only to a certain extent.
  14. Mar 14, 2017 at 6:11 AM
    Ledfoot 26
    Ledfoot 26 Well-Known Member
    16 TRD OR 4x4 Barcelona Red
    I youse S mode every day around town I tow a 2,600 pound Utility Landscape trailer, it helps save my breakes on the downshifts as well, I'm getting a consistent 15 - 16 miles a gallon towing this way that's pretty dam good in my book lol
    OnHartung'sRoad likes this.
  15. Mar 14, 2017 at 9:16 AM
    #35
    Syncros
    Syncros Well-Known Member
    I used to shift my 4.0L automatic more than I'd like, Living in a mountainous region it seemed like a constant battle. On ascents the transmission would hold gears too long to the point that the engine would knock/ping. On descents the transmission would downshift with brake application per design, but not always, or too agressively.. easing back onto the throttle it would upshift hard with a thump. Annoying behaviour, no TSB or fluid change ever fixed it. Driving it manually would mask the logic issues.
    Back in a manual truck now and couldn't be happier. To be fair I've driven plenty of automatics that worked just fine.
  16. Jan 23, 2018 at 8:06 PM
    #36
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    If you are a motorcycle or bmw person the shifter operates backwards in the sport mode. You have to pull it back to down shift and slam it down to up shift. It will disappoint if Ya are thinking it is like your 328i.
  17. Jan 23, 2018 at 8:09 PM
    #37
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Any time I get a Rental or Loaner I end up getting so extremely bored that I end up shifting the Automatic thru the gears
    CaptainBart45 likes this.
  18. Jan 23, 2018 at 8:35 PM
    #38
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I use it for towing and engine braking only.
  19. Jan 23, 2018 at 8:41 PM
    #39
    OnHartung'sRoad
    Don’t hurt yourself clutching for stop and go traffic. I’ve been copying what the big rigs do for years - shift to 1st or 2nd, let engine idle govern your speed and keep a long opening ahead of you. Then watch idiots pass you and pile on their brakes ahead while you cruise merrily along going your own speed. :)
    RocTaco and CusterFan like this.
  20. Jan 23, 2018 at 8:44 PM
    #40
    CaptainBart45
    Bart
    Work in progress...
    Uh "stop" I am not wrong requires disengagement of the clutch. I mean if Ya want to keep the engine running.
