Anyone use the auto-transmission to manually shift gears?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma-or-Colorado?, Jan 10, 2017.
  1. Jan 23, 2018 at 8:49 PM
    #41
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    What the hell is a “manual “?:notsure::facepalm::rofl:
  2. Jan 23, 2018 at 8:55 PM
    #42
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I have to admit that paddle shifters on my Taco would be awesome in S mode given the transmission shiftiness. And I never thought I'd say that I thought a truck could really use paddle shifters...
    Edit - I am a long time MT only driver. Every vehicle was MT until I stupidly traded in my '09 ACMT with a TRD blower, Icon and Dakar lift, etc. for the lure of a v8 Tundra that I ended up never driving except for towing because it was so big (OK the 4" lift, etc. didn't help).
    Now both the car and the truck are AT. At least the RC isn't shifty.
  3. Jan 23, 2018 at 8:58 PM
    #43
    marjamr
    marjamr Well-Known Member
    Mark
    2017 Silver Tacoma SR
    Western Defender snow plow
    Had a 08 and a 10 Miata. Paddle shifters in a Miata is a crime. Now in a WRX, not so bad.
  4. Jan 23, 2018 at 9:00 PM
    #44
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Paddle shifters for wheeling would be great!
    ksj likes this.
  5. Jan 23, 2018 at 11:20 PM
    #45
    Superman
    Superman Well-Known Member
    Joe
    Michigan
    2017 Quicksand TRD OR DCSB
    Current: Behind rear seat MOLLE panel Softopper Empyre grille insert MesoJDM ultimate red maps MesoJDM ultimate white dome Future: BajaRack roofrack/basket Mobtown bolt-on sliders Mobtown rear plate bumper Mobtown front plate bumper On-board air compressor Ditch lights LED headlights (blacked out) LED taillights (blacked out) LED yellow fog lights Bedrack over softopper Maxtrax
    I used to do this all the time in my camry (B.A. , I know). It didn't have sequential sport shift, but it had "L, 2, D, and O/D".
    I heard engine braking can put unnecessary wear on torque converter, which is expensive and time consuming to replace. Especially when you can just use your -brakes- for braking. But I wore the engine out before the TC had any problems.
    I will likely be nicer to my Tacoma. However, manual shifting/engine braking is always great on snow/ice. It allows much better feel for what your tires are doing, and you don't instantly unleash all hell when one tire starts to spin with an open diff
  6. Jan 24, 2018 at 5:52 PM
    #46
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    I have had cars before which has a slap-auto trans. When I switch to "manual" or 'sport' mode, the car would choose an appropriate gear for the speed which I am driving at. But this is not the case in my 3rd gen taco. It doesn't matter whether I'm driving at 10miles an hour or 90. It always shifts to 4th gear.
    Secondly, when I shift down in manual mode, the response is instant regardless of my speed, the car would engine-break and slows down. This is fantastic (not advisable to do this at high speeds). I used do this all the time, as it allowed me to slow down enough to make turns etc. But on my tacoma, the truck won't allow me. If Im at 3 gear going at 45 and if I desired to go to 2nd gear and if I tap to 2nd, I could count 1 second, 2 second,.. and instead of shifting to 2nd., I get a beep. "Oh, You want to go to 2nd? Haha tricked you. That's not happening today... yep, FU too" :annoyed:.
    The same thing happens on any gear you're on trying when you try to shift down. It won't shift unless you step on the breaks and drop the speed way below the gears minimum cut-off. But it don't have any restrictions to go up. You can drive at 5 miles an hour and still shift all the way to 6. all it does is beep, I hate when it does that.
    Another thing is, this one time when I gave my truck to the dealership for service, they gave me a loaner Corolla. It's a 2017 model sport. It had paddle shifters and automatic slapshift. And the things I mentioned above works fine on this one. I could shift down to slow down enough to make turns without having to step on my brakes, it would shift to an appropriate gear automatically when you switch to 'sport' mode., it has a 'sport-auto' mode where it would shift up or down if you don't do so yourself. So it's not like Toyota doesn't know the concept. It's just that moron Mike Sweers wanted to take an excellent product and bring it down to crap :mad:.
    Superman likes this.
  7. Jan 24, 2018 at 6:47 PM
    #47
    Superman
    Joe
    Michigan
    Yeah, I've noticed that horrible delay as well. Both while shifting up, and down. Letting off throttle a bit helps
    CaptainBart45 likes this.
  8. Jan 24, 2018 at 8:17 PM
    #48
    CaptainBart45
    Bart
    Work in progress...
    I agree. What is the point of having a manual gear selecting device that decides for it's self what gear it should be in?
  9. Jan 24, 2018 at 10:28 PM
    #49
    bacon_st
    San Diego
    16' Taco TRD sport
    This has been asked and answered before. It's for towing apparently. I wouldn't know why because I have no plans to tow anything ever.
  10. Jan 24, 2018 at 11:30 PM
    #50
    Superman
    Joe
    Michigan
    Right, but even then it can be annoyingly slow. I get that the "pcm n pals" (control modules/nanny logic) usually know whats best
    (and let's be honest, sometimes protects the truck from the driver)
    but the gear shifts sometimes feel sluggish like I'm shifting up too early in a manual trans while driving on a steep hill.
    While your towing I get that you dont want to buck the thing while shifting, but you don't want to drop onto the next gear at 1k rpm either
