Anyone use this HO alternator?
Discussion in '1st Gen. Tacomas (1995-2004)' started by License2Ill, May 24, 2012.
  1. May 24, 2012 at 9:19 PM
    License2Ill
    License2Ill [OP] Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    http://www.ebay.com/itm/250714067155?item=250714067155&viewitem=&vxp=mtr
    Fairly affordable. And at 170 amps. Can't really go wrong...
    But problem is; he no speaky ta engly.:rolleyes:
    Me:
    powermaxusa:
    I gist what's he's saying. But any experience anyone? TIA
  2. May 24, 2012 at 9:28 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    It's basically a rebuilt alternator which isn't bad Basically brand new
  3. May 24, 2012 at 9:34 PM
    License2Ill
    Ian
    So u dun gots u one?
  4. May 24, 2012 at 9:40 PM
    BAMFTACO
    Juan
    Kings bruh
    I know this because I've had to replace a alternator on my buddy's first gen we went to an auto parts store (napa)and they told us they don't sell new alternator what they do is just get rebuilt ones
  5. May 25, 2012 at 8:32 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Not used one so can't help there.
    If claim is correct/true then 170 amp at 1200 rpm is at least useable. There are others on eBay that I contacted while looking for a high amp alternator and many would not give the specs and the ones I did have answer gave the rated power being at an engine rpm of 6000!
    Looks like they just modify a standard alternator. As suggested you might be able to get the same thing done locally maybe cheaper. The pully change is going to probably make it spin faster so you bring the power up quicker. Would just wonder about life span on it perhaps.
    When looking around for mine I ended up doing the 130 amp Cadillac swap. Had a 60 amp on from the factory. Not doing winches, but did want more power for an audio system and maybe a few extra accessories. Many will cringe, but I went the junk yard route on mine and got the whole thing done for around $45 if I remember correctly.
    Anyway, best of luck with it and at least a bump for you to get peoples experience on them.
    Cheers
  6. May 25, 2012 at 9:49 AM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
  7. May 25, 2012 at 9:52 AM
    Killer
    Mobile, Al.
    P.S. I don't know the output on the new alternator but, before the lights were dimming with a Alpine PDX-5 600 Watt class D amp.
    Now he is running the same PDX-5 and a old school Orion Extreme 800.4 800 Watt Class A/B amp with no dimming issues.
  8. May 25, 2012 at 10:02 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    LC engineering makes a 160 amp one do the 5vz I believe. That where I would look first. Would you need to upgrade any wiring or stuff like that when you do the swap?
  9. May 25, 2012 at 11:33 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I bought one of the ebay specials...
    think it was a "mechman" rewind.
    So maybe not the same business...
    But this re-builder also a claimed/advertised a 170 amp unit.
    I have yet to install it...
    but I did have it tested...
    and it was found to be rated less then claimed.
    Mine peaked out at around 140(ish) amps @ 1200 rpm
    and delivered an honest 120(ish) amps @ 900 rpm.
    In my communication directly with a reputable business that rewinds these original denso alternators...
    I was told... that 140 - 150(ish) amps were about the max that could be obtained... while still maintaining reliability.
    That's taking into account that it was originally an 80 amp unit.
    So don't be too surprised if the amp rating hype is not what is claimed.
    Regardless... a 140 amp alternator should still be satisfactory for most uses.
    One can only cross their fingers on the reliability factor.
    I'll wish good luck in your decision
  10. May 25, 2012 at 12:03 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Check out the cadillac alternator swap.
  11. May 26, 2012 at 11:27 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Old ambulances have some really stout alternators, but would need some mods to fit a tacoma.
    I don't like the pulley change idea. I think I would just modify a toyota alternator myself or just add a second battery. Adding a second battery would be more useful because you don't need high amperage charging all the time.
  12. May 26, 2012 at 12:04 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  13. May 26, 2012 at 1:22 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I ran one of those that was 130 amp to replace a 70 amp on the 2.4l. It worked fine.
  14. May 26, 2012 at 5:58 PM
    License2Ill
    Ian
  15. May 26, 2012 at 7:07 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'd trust LCE. They've been working Toyotas for a long time.
    Back in the 90s I seriously considered a set of their headers, and even dropping one of their built 22RE's into my '94 when it started showing it's age at 200k... but I decided to upgrade to a Tundra.
  16. May 26, 2012 at 7:27 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    WTF?
    Which one of you assholes gave me a negative rep for that post???? :mad:
  17. May 26, 2012 at 10:38 PM
    License2Ill
    Ian
    :confused:Ain'tz wuz me.
    Maybe remarking about upgrading to a Tundra?:D
  18. May 26, 2012 at 10:51 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Or the eBay seller poked in... but should have dinged my first one.
    And ya... the '03 Tundra absolutely was an upgrade from a '94 5-lug 22RE manual with no power anything except steering and brakes.
  19. May 26, 2012 at 11:01 PM
    tacomafide
    tacomafide Cheese it in there!
    Sean
    Alberta
    '10 DCLB TRD Sport+Leather Pkg.
    de-badged, de-stickered, no jewlery, level kit (removed after second front dif), tint, skid plate (now dented), front tow hook off of Land Cruzer, reciever d hook (cleavis), yellow wire mod, abs kill sw. mod, window visors, stubby antena, anytime reverse lights mod, anytime reverse camera mod, blizzacks on stealies, bed lights mod, weathertec mats allround,
    Can't u see who gave last rep?
    How u know right away?
  20. May 26, 2012 at 11:09 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If they don't leave a name, no way to tell who left it.
    I found it because I use my UserCP to view new posts to my subbed threads and rep is right under the list.
