Anyone used AC "delete" drivebelt if there is such thing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Dec 22, 2022.
  1. Dec 22, 2022 at 5:21 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I am not yet serious about it but would like to maybe just experiment, considering how easy it is to re-install a drivebelt. Is it possible to buy a special, shorter, drivebelt for 1GR-FE that would simply bypass the AC compressor for engine efficiency and gas mileage? If I decide I did want the AC, I can just put the OEM back.
    I've heard of people doing it with other vehicles, not sure about Tacoma.
  2. Dec 22, 2022 at 5:42 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Without the AC running nothing is spinning outside of the pully on some bearings (nill as far as hit on efficiency / mpg). I also dont believe there will be a straight shot from the crank to the alternator without the ac pump
  3. Dec 22, 2022 at 7:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, I posted about it once before.
    You need to bypass the ac/defrost auto-on.
    I’ll see if I can find it later.
    FWIW, there is no way in hell I’d go through the trouble just to improve mpg.
    If the compressor locks up…..maybe.
    doublethebass and foampile[OP] like this.
  4. Dec 22, 2022 at 7:10 PM
    TnShooter
    Deogee
    STOCK
    foampile[OP] likes this.
  5. Dec 22, 2022 at 7:14 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What does that have to do with it?
    Nd4 already answered the question. Better mpg savings from deleting mechanical fan clutch (& maybe power steering hahaha)
  6. Dec 22, 2022 at 7:18 PM
    TnShooter
    Deogee
    STOCK
    I have no idea what it has to do with it?
    I answered the part about the belt.
    Which had absolutely nothing to do with OPs question I guess:rolleyes:
  7. Dec 22, 2022 at 11:10 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    But why
    whatstcp and MR5X5 like this.
  8. Dec 22, 2022 at 11:14 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Due to the alternator location if you wanted to run a belt without a/c you’d need to remove the a/c compressor. The mr2 crowd does it with the 2gr swap. Similar belt layout (minus the p/s belt)
  9. Dec 23, 2022 at 3:57 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    A wise old man once said, "Just because you can doesn't mean you should."
    doublethebass and 6 gearT444E like this.
  10. Dec 23, 2022 at 7:23 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    @foamparty proved the fact that common sense is not so common.
  11. Dec 23, 2022 at 7:39 AM
    ToolCat
    ToolCat Active Member
    Greg
    A more practical way to gain a little MPG is to use all synthetic fluids in your truck: engine, transmission, differentials, transfer case.
    Although I use Mobil 1 or Castrol full-syn 5w-30 in my 4.0 Tundra, Toyota specs 0W-20---which does improve MPG a little bit.
    And I swear by Valvoline Max-Life ATF. It works beautifully in the A750 transmission....even works like a dream in finicky older Honda transmissions!
    I'm a Red-Line man for gear and transfer-case fluids, but Amsoil and others make excellent full-synthetics.
    I like to double-up the anti-rattle springs on my Tundra's front disk brakes (use one at the top and bottom, not just the bottom), as they also act as a retract for the brake pads. If you're lucky this could gain you a tad in MPG.
    Running all-terrain tires and/or larger-than-standard tires will hurt your MPG's (although they look damn good!).
    ToolCat
    6 gearT444E likes this.
  12. Dec 23, 2022 at 8:20 AM
    foampile
    Mid-Atlantic
    giving that up would be more sacrificial than AC
    nd4spdbh likes this.
  13. Dec 23, 2022 at 10:09 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    sack up
  14. Dec 23, 2022 at 10:33 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Warning: this suggestion is brought to you by a arrogant "professional" that only wants to "keep you dependant on my expertise". Proceed with caution
    just pull the mag clutch fuse and the compressor will become nothing more than a idler pulley
  15. Dec 23, 2022 at 11:06 AM
    TnShooter
    Deogee
    STOCK
    It’s foampile.
    Give him the information he needs and nothing else.
    It will be easier for yourself and everyone else.
    I don’t have anything against the guy.
    He’s determined to do “what he wants to do” despite what others think.
    If you notice, he didn’t ask what to do for better MPG. He asked if there was a smaller belt. - I posted the link to the belt.
    What I did NOT do is offer advice. :D
    You guys can keep giving him your advice, but I don’t think he cares for it.
    He will put the smaller belt on before he listens to you.
    I can’t say much. He did manage to rebuild his own engine. So :thumbsup: to him.
    I’ve just learned to give him the information he seeks. And keep advice and opinions out of it. He doesn’t care.
    I keep helping him because he has not managed to insult me enough to ignore.
  16. Dec 23, 2022 at 11:23 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    He reminds me of a house cat. Completely convinced of his own independence.. while being completely dependant on a community he doesn't appreciate or understand
    6 gearT444E and MSgt O like this.
  17. Dec 23, 2022 at 4:54 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    At work we call folks like that askholes.
    Too Stroked likes this.
  18. Dec 23, 2022 at 5:17 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    The fuel savings is negligible because the only thing thats running is a disengaged AC clutch which at that point is just an idler bearing.
