Anyone Used This Method to Replace Coilover's?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Commocean, Jul 28, 2021.
  1. Jul 28, 2021 at 10:29 AM
    Commocean
    Commocean [OP] Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    There's a number of videos that detail installing new coilover's, and most of them involve removing the brackets for the brake and ABS lines, along with releasing the upper ball joint, among other things. This video illustrates that you can replace the coils without those extra steps (only the tie rod end and sway bar end links), which would make it much easier/faster.
    Anyone done it this way (go to 12:32 in the video):
    https://www.youtube.com/watch?v=DU4ufXalBfM
  2. Jul 28, 2021 at 10:37 AM
    mhornco
    mhornco Well-Known Member
    Depends on the truck and amount of lift. I put the Eibach pro trucks (first notch) on my truck and only disconnected the sway bar and end links. It was a tight fit and I had to use a pry bar to push down the lower control arm a little further to pop things in. We did my friends and it was way easier to just pop out the upper ball joint. Took off the nut and a good hammer wack and it was free.
  3. Jul 28, 2021 at 10:44 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    if you drop the lca down you dont have to touch anything. I've done it this way over a dozen times.
    and if your about to say "Well what about the cams" mark them with a sharpie before you start. then tighten everything back up to where it was, gets it close enough to drive to the alignment shop.
    #4TOY4ME, Skydvrr and cgs2k2 like this.
  4. Jul 28, 2021 at 10:45 AM
    cgs2k2
    cgs2k2 old man
    dropping the lower control arm is the real cheat code
    #4TOY4ME likes this.
  5. Jul 28, 2021 at 11:11 AM
    Commocean
    St. Petersburg, FL
    So you didn't even disconnect the tie rod ends?
  6. Jul 28, 2021 at 11:30 AM
    cgs2k2
    cgs2k2 old man
    i did not... maybe coopcooper did
  7. Jul 28, 2021 at 11:36 AM
    coopcooper
    alberta canada
    sway bar links makes it easier for sure but up here with rust the only way your removing those is with a angle grinder. Dropping the lca really is the way to go.
    cgs2k2 likes this.
  8. Jul 28, 2021 at 11:36 AM
    PThy
    PThy Well-Known Member
    Pat
    SoCal
    2020 TRDOR MT
    I disconnected the sway bar and lower control arm. Slid right out, new ones back in. Eibach Pro Truck 2 Coilovers
