Anyone used this on they're auto trannys?
Discussion in '4 Cylinder' started by Rlanier91, Sep 12, 2012.
  1. Sep 12, 2012 at 6:12 AM
    Rlanier91
    Rlanier91 [OP] Member
    Tacoma SR5 4x4
    3" suspension lift, 3" body lift, 35's
  2. Sep 12, 2012 at 6:15 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    I have installed many. This is a shift kit and WILL firm up your shifts. It won't allow the transmission to slip into gears like they all do from the factory. You'll have positive engagements every time. Heres the draw back to your situation. With nearly 200k I would highly discourage this. Unless you have the transmission fully rebuilt. Your stock 190+k transmission will NOT like this.
  3. Sep 12, 2012 at 6:56 PM
    Rlanier91
    Tacoma SR5 4x4
    Well I just serviced it and it didnt look to bad as far as the metal shavings but I know what you mean about the miles. That was one of the concerns I also had about doing it but I would still really like to if it would be possible
  4. Sep 12, 2012 at 7:03 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I've used Trans-Go before. Yes, put it on your "must do" list.
  5. Sep 12, 2012 at 8:57 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    It's a night and day difference. Is that the weakest shift kit they make? I would go to strong on a high mileage transmission
  6. Sep 13, 2012 at 3:02 AM
    Rlanier91
    Tacoma SR5 4x4
    I would go to strong on a high milage tranmission? What was that suppose to mean? But I think that's the only one they offer
  7. Sep 13, 2012 at 4:10 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Wouldn't* sorry on my phone
  8. Sep 13, 2012 at 4:18 AM
    Blackcat10
    Blackcat10 Well-Known Member
    Also be advised,as a former Toyota Tech. I have seen snap ring groves on the clutch pack break due to the high pressure. That's why Toyota went to the mushy or slipping shift. Would not advise it on a high mileage tranny.
  9. Sep 13, 2012 at 6:11 AM
    Rlanier91
    Tacoma SR5 4x4
  10. Sep 13, 2012 at 6:21 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe it's time to buy a core tranny and rebuid it correctly. Do it once, it's cheaper that way.
  11. Sep 13, 2012 at 10:35 AM
    BamaToy1997
    Bill
    Navarre, FL
    Toyota, like other manufacturers, did not go to a "mushy" or slipping shift because of that type of concern. The softer shifts were by design for a more "comfortable" shift for people. All manufacturers have this in their cars and trucks. A hard, solid shift is just generally considered uncomfortable for the most part. Shift adapts have been around for years.
    Though I do agree that on a higher mileage transmission, a shift kit alone is not the best idea.
  12. Sep 14, 2012 at 7:54 AM
    Rlanier91
    Tacoma SR5 4x4
    Well I was actually wantin to put it in there for that reason. In hopes that it would give me firmer shifts (which I know is better for trannys) and reduce the clutch slippage to hopefully extend the life of my trans. Unless that's not the correct way to think about that
  13. Sep 14, 2012 at 9:07 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    This won't extend the life. It's will decrease its life.
  14. Sep 14, 2012 at 9:59 AM
    Rlanier91
    Tacoma SR5 4x4
    Not trying to be smart about it just wanting to learn but what makes you say that? Or actually why would it?
  15. Sep 14, 2012 at 12:46 PM
    Rlanier91
    Tacoma SR5 4x4
    Well im not trying to press my luck but I'm trying to weight the advantages vs the disadvantages. Though I really don't want to be rebuilding a tranny anytime soon
  16. Sep 14, 2012 at 1:01 PM
    BamaToy1997
    Bill
    Navarre, FL
    On a newer transmission, or rebuilt one, putting in a kit would be an advantage, but as mentioned, if you are already having transmission issues, then adding a kit will just make the problem worse.
  17. Sep 14, 2012 at 3:22 PM
    Rlanier91
    Tacoma SR5 4x4
    I'm not having any issues at all right now. My truck is on 35's (soon to be 33s) and will run 80 mph no problem. Probably more but I don't wanna push it that hard. I just want to get away from the slippage and hope that maybe it might help my engine run more efficiently ( putting power to the ground not mpg wise). I had the exact same truck but a 97 with a 5 speed and with 33s on it wouldn't hardly run 75 unless on the interstate going down a hill and wouldn't pull much of a trailer where this truck does great
  18. Sep 14, 2012 at 3:23 PM
    Rlanier91
    Tacoma SR5 4x4
    Gotta be the most true phrase ever!
