Anyone using 2.0 smooth reservoir custom body shocks?
Discussion in 'Suspension' started by bodhi armor, Dec 17, 2016.
  1. Dec 17, 2016 at 3:58 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Ive been looking for fox reservoir shocks that provide 2" of lift but they dont make anything specifically for an 02' tacoma.
    One of the tech guys at Fox told me i would have to get creative. He recommended a universal shock pt# 985-24-051 its a 2" body remote reservoir shocks that require hourglass bushings to work w/ my truck.
    I was also told by Fox that these are for 1/2 ton trucks. My truck i a double cab weighing in at just under 4,000lbs. A single cab f150 from 02' weighs in at 5,400 lbs. I have no experience with Fox shocks and am very concerned they will be too stiff.
    Should i use them or return them for something else?
  2. Dec 19, 2016 at 10:04 PM
    FPpanchhh
    FPpanchhh Well-Known Member
    Francisco
    Los baños CA
    2005 Tacoma RC
    King coilovers, all pro leafs, bilstein 5160
    you can basically use any shock on any car as long as your able to mount it. once you've figured out how to mount it and cycled your suspension then it all comes down to valving. you can get them revalved to fit your need based on the weight of the truck and your driving need. call up downsouthmotorsports theyll anwser any questions you have in terms of valving and get you set up :thumbsup:
