Anyone using a Kenwood Double Din and does NOT have sun washout issues?
Discussion in 'Audio & Video' started by Bmr4life, May 14, 2013.
  1. May 22, 2013 at 3:47 AM
    Bmr4life
    Bmr4life [OP] Member
    I like how your mount places the HU in a vertical position versus at an angle like I've seen in some other pictures.
  2. May 22, 2013 at 7:06 AM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    It's the screen adjustment. That's the most upright setting. Helps with the glare and sure. That metra kit sucks but it's better than others. Still have to adjust it to get the lines cleaner.
  3. May 22, 2013 at 9:34 AM
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    I have an older model Kenwood DNX5120 and it is very hard to read in bright sun.
    My side windows are 40% but it doesn't help much. The map is nice and bright, but if I am on the other screen changing stations/controlling the ipod it is hard to read.
  4. May 22, 2013 at 12:58 PM
    Aw9d
    Aw9d That one guy
    Notice the angle of the screen? Its sitting CORRECTLY and that's why he isn't getting screen washout. If your screen isn't angled pretty much like this you will get wash out really bad. These screens do not have the best viewing angles.
    You can not get a correct angle with stock brackets unless you modify them.
  5. May 22, 2013 at 7:32 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I'm using the Metra kit (same kit) and I have a slight angle.
    Can't use the stock brackets with the Metra... the HU slides in from the front and backs into the small frame on the face.
    The Metra side brackets lock the face frame in place... it won't line up with the dash panel if not used with the Metra brackets.
    Anyways, two posts above, Jumper indicated that is the screen angle adjustment. HU's that are 100% tough screen generally have a vertical angle adjustment. Some will retract to the "factory" position when shut off (the Pioneer I had in my Duramax did), others don't move.
  6. May 22, 2013 at 10:53 PM
    DirtJumper14
    SoCal
    2005 TRD OR
    The sun is actually coming through my side window. The sun was reflecting around the frame which reminded me to take a picture. Even with the screen not vertical the wash out isn't really an issue. It's super bright as mentioned before by a few others and too bright at night. Will try to remember to get a shot of that now.
  7. May 23, 2013 at 3:44 AM
    Bmr4life
    That Kenwood is better than the Kenwood I tested. I bought a DDX470 just to try it out and it has the same washout issue as my X5500.
