Anyone using Mobil 1 ATF vs Toyo WS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ttubb, Nov 15, 2014.
  1. Nov 15, 2014 at 10:39 AM
    ttubb
    ttubb [OP] Member
    Terry
    Tucson/Crested Butte
    Tacoma TRD Off Road 4WD
    If so, what is your experience? How many miles and did you do a full flush?
    Any problems at all?
  2. Nov 16, 2014 at 6:04 AM
    ttubb
    ttubb [OP] Member
    Terry
    Bump
  3. Nov 16, 2014 at 6:26 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    I'm interested as well. Seen some guys posting in other threads that they use mobil 1 ATF but no detailed geedback.
  4. Nov 16, 2014 at 7:06 AM
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    I'm interested too... I used M1 in my 4runner for 19 years and NEVER had an issue. Anyone else running M1 tranny fluid in auto?
  5. Nov 16, 2014 at 7:08 AM
    ttubb
    ttubb [OP] Member
    Terry
    I have used it in my 95 FZJ-80 Landcruiser and it seems to work well for the last five years....
  6. Nov 16, 2014 at 7:42 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I can't directly answer your question but I have been running Valvoline Maxlife atf in my tranny for over 30k miles. Shifts and runs fine. I don't notice a difference from the original fluid. It states on the bottle that Maxlife is a full synthetic and is compatible with Toyota WS fluid. The best part about it is the price, about $15 a gallon. I did a full fluid replacement using the cooler lines.
  7. Nov 16, 2014 at 7:45 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    i also used valvoline maxlife atf, and no problems
  8. Nov 16, 2014 at 8:47 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I went motomaster instead of Toyotas WS. So far no issues shifting. Long term I'll keep the forum posted on.
  9. Nov 16, 2014 at 8:54 AM
    Cactusone
    Cactusone Active Member
    Sonoran Desert
    05 PreRunner Off Road
    BHLM, Sport hood and grill, Deezee side steps painted super white, 5100 w/OME884 and AAL
    maxlife +3
  10. Nov 16, 2014 at 9:11 AM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    Aren't you having trans overheat issues
  11. Nov 16, 2014 at 9:14 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    I ran max life at 30k and 62k miles. I have never had a problem with it. Wal-Mart has the best price on it.
  12. Nov 16, 2014 at 11:36 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Hence why I'll keep you posted as to my results since I just did a Full Tranny Fluid change yesterday. ;)
  13. Nov 17, 2014 at 4:06 PM
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
    So I need to do my first Trans fluid change and rear diff. has anyone used Royal Purple and I know ATF means automatic transmission fluid but what does the WS stand for? I have a 11 TRD sport auto 4.0 Thanks
  14. Nov 17, 2014 at 4:14 PM
    TacomaG26
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    Also my owners guide say it takes11.5 quarts.?. isn't that a lot???
  15. Nov 18, 2014 at 9:05 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    World Standard.
    And yes, it takes 11.5 quarts for a full flush. It's fairly intensive for your casual DYIer but reading the instructions carefully and a couple times you'll be golden.
