Anyone Using Shallow Mounts?
Discussion in 'Audio & Video' started by mistert, Apr 22, 2015.
  1. Apr 22, 2015 at 6:16 AM
    mistert
    mistert [OP] Well-Known Member
    Macon, GA
    07 PreRunner SR5
    Bull Bar with fog lights, Pioneer DVD Stereo, Alpine Type R (front), Kicker 2 way (rear fill), Rockford Fosgate sub, JL Audio 300/4, Kicker 750.1, cheap spacer lift (came with the truck), BF Goodrich tires
    If so, what are your thoughts? I have 2 amps, JL Audio 300/4 pushing the front and rear speakers (Alpine Type R fronts/ Kicker Coaxial rears) a Kicker 750.1 mono amp pushing a single 12" Rockford Fosgate Punch Stage 3 subwoofer in a ported enclosure that sits on the rear seat. I am thinking of getting a pair of JL Audio shallow mount subs for behind the rear seats and relocate the amps to under the front seats so I can utilize my back seat more. Does anyone have any 12-up inch shallow mount subs and how do you like them?
  2. Apr 22, 2015 at 8:53 AM
    Firef4ly
    Firef4ly Member
    Missouri
    Alpine Imprint h650, Alpine PDX 4.150, Alpine PDX 4.100, Hertz HSK all around
    Mistert,
    I've had a JL 13tw5 in my 09 DCSB for about 2 years now. While I am happy with the added base that it gives to my system, I am sometimes left wanting more. If you are somewhat of a bass head, like me, and choose to go the shallow mount way then I would definitely try and squeeze 2 of them behind the seats.
    As you can see my post count in not very high as I mostly troll the forum and read what others have to say. Hopefully someone such as ItalynStylion will chime in and give you his thoughts on the subject.
  3. Apr 22, 2015 at 8:55 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I run 2 13TW5's because of space issues. I used to be a bass nut but have toned it down now. I am happy with the sound quality and bass of my TW5's. And I still have room to put stuff in the rear extended cab.
  4. Apr 22, 2015 at 9:43 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    With minor modification( small spacer ) and some building skills you can get a single shok triton 12 behind the seat of a double cab.
    THE Shok triton 10s are finally due in may, and you can actually fit 2 10s ported behind the rear seats with enough air space but amps would have to go under the seats or another location. IF space is an issue, id suggest 2 8s ported and with the above mentioned mod you can also get the amps back there
  5. Apr 23, 2015 at 9:01 AM
    mistert
    Macon, GA
    07 PreRunner SR5
    I figured I would use one really good sub vs 2 shallow mounts thinking they would give me more bottom end. The JLs look really nice and have rave reviews. I just wonder how they compare to a regular sub or 2 shallows vs 1 midgrade sub like I have. A lot to consider :)
  6. Apr 23, 2015 at 10:02 AM
    ike3000
    ike3000 Well-Known Member
    The 10TW3 I heard was pretty darn good, so I'd imagine the 12TW3 will sound very good, too. I'm satisfied with my Stereo Integrity BM MKIV shallow mount. Sometimes I wish it had more output, but then again it's in a 0.6 ft^3 box. Digs very deep and sounds very smooth. A second one would be perfect.
  7. Apr 23, 2015 at 10:27 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    i don't like shallow mount subs and on a cost basis they cost way more per value.
    The MkIV is a nice speaker, the jl as well but in the end your a 12inch sub ported vs 2 shallow mount sealed...... there is simply no way to compare that and the output will not be comparable.
  8. Apr 23, 2015 at 2:59 PM
    Offroader12
    Offroader12 Well-Known Member
    ID
    Stock
    You should run four PIONEER TS-SW2502S4 10" behind the seats an run the amps under the seats,
    That is my plans any how lol.
  9. Apr 23, 2015 at 3:30 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    GL,
    I personality wouldn't waste my time with these.
    The "specs" on these seem off, their recommendation seems off and generally by the time you paid for 4 of them you can achieve much better results with only 2 quality dvc subs :) anyhow, Gl with the project
  10. Apr 23, 2015 at 4:04 PM
    Offroader12
    ID
    Stock
    The guys at 5 Star Car stereo said they were very impressed with these subs.
    If you want to spend more for better sound Sundown makes really good shallows.
  11. Apr 23, 2015 at 4:27 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    I have heard them and was not impressed at all, sorry. I personally hate shallow mount topology. Digital design has a great one, as well the Stereo Integrity BM MKIV as wicked. Sd subs are solid as well as the JL shallow mount but the problem i have w them they are Huge $$$. Id venture to say that any of the above mentioned would Massively outperform those pioneers.
    now granted,
    The Shok triton 8-12 cannot be beat for $ value to performance :)
    12s are hard to fit but its possible, the 10s are easy and the 8s are easy and fit well.
    A couple members here should have a review of them and a couple more to come :)
