Anyone want to help me mount my wheels and tires
Discussion in 'Arizona' started by Jchavez, May 25, 2013.
  1. May 25, 2013 at 4:41 PM
    Jchavez
    Jchavez [OP] Well-Known Member
    Jesse
    Tucson, AZ
    07 prerunner SR5
    Bilstein 5100s set at 2.5
    Anyone In the Tucson area with a jack want to help me mount my wheels and tires. I don't have a jack and I don't want to spend 40 bucks to have a shop mount them. Help is really appreciated. Ill throw in a six pack.
  2. May 25, 2013 at 4:58 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I'd offer to help you, but last time I did that I pushed other plans aside to make time to help you and then the day before you bailed. So I'm not willing to offer help this time.
  3. May 25, 2013 at 6:32 PM
    Jchavez
    Jesse
    Tucson, AZ
    07 prerunner SR5
    My bad man. Things just came up.
  4. May 25, 2013 at 6:51 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Didn't your truck come with a jack?
  5. May 25, 2013 at 6:52 PM
    Infra
    Az
    If you are on DM just go to the auto shop on base, I think they charge a whopping $6/hr for a bay with a lift
  6. May 25, 2013 at 6:52 PM
    Jchavez
    Jesse
    Tucson, AZ
    07 prerunner SR5
    Yes but idk if I trust that little thing.
  7. May 25, 2013 at 7:54 PM
    4Wheelin4Banger
    Randy
    It works just fine.
  8. May 25, 2013 at 7:54 PM
    Ghostofkrypton
    Ghostofkrypton Active Member
    Tucson, AZ
    10 trd
    Stock
    do you need help to put tires on wheels, or just jack up the car and switch out wheels with tires mounted.
  9. May 25, 2013 at 8:12 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
  10. May 25, 2013 at 8:37 PM
    Jchavez
    Jesse
    Tucson, AZ
    07 prerunner SR5
    Just need to jack my truck up. The wheels and tires are set up.
