anyone who has done a gauge led swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markmatters, Dec 28, 2011.
  1. Dec 28, 2011 at 4:21 PM
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    im currently working on it..and im stuck. anyone know how to remove the needles? i dont want to just pull on them...
  2. Dec 28, 2011 at 4:24 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    ...nevermind. close thread. hah
  3. Dec 28, 2011 at 6:24 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    re open hah..ok guys...i need someone to take a picture of their cluster..specifically the fuel needle..i want to know where it sits when the truck is off..I marked it but I just want to make sure...i searched google and couldnt find a clear one...thx!
  4. Dec 28, 2011 at 6:56 PM
    95Yota4x4
    95Yota4x4 -FURY FROM THE SKY
    J.D.
    Houston, Tx
    Black 95 Tacoma, reg cab, 2.7L 4 cyl, 4x4
    4" lift
    If I were you, to be safe I'd fill up gas tank & place the needle on, set at full. I think that this would be more accurate than placing while it's turned off. When the vehicle is turned off the rotating rod that the needle attaches to, turns further than it's allowed to than it would with a needle attached to it. The needle stops it at it's the lowest point, but if no needle, it can actually turn beyond that spot if no needle on rotating rod. I would fill up & then place needle as close to where it was before when u had a full tank. Oh and do this with vehicle on so that the cluster is actually engaged. That's just how I'd do it though. Operator preference.
  5. Dec 28, 2011 at 8:08 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    i was sitting at 1/4 tank before the mod...after putting everything together i am still at 1/4 tank...but when its off, the needle goes a little further than it used to...ill give it a go...i have to fuel up anyway. thanks!
