Anyone with 255/75/17??
Discussion in 'Wheels & Tires' started by TRDfarmerTN, Apr 3, 2017.
  1. Sep 6, 2024 at 12:31 PM
    #141
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    How do you like these?
    I've been running 255/80r17 ST Maxx for about 80k miles and I just took a 5in spike through one that punctured the belt. I've been debating dropping down to a C rated tired for better on road noise and comfort, but looks like I need to drop down to a 255/75r17 to get out of the E rateds.
    These look like a good option and are also 18lbs lighter than my current coopers.
    BC Hunter likes this.
  2. Sep 6, 2024 at 12:35 PM
    #142
    Admiral Snackbar
    Admiral Snackbar Well-Known Member
    I've been really happy with them. They're good in the rain, quiet enough on road, for the type off roading I usually do they've been great. I'm really happy with them on the sand/beach and they've done well on the mild trails and FSRs around here. I won't have them in the snow for a few more months but I've read good things about them so I'm looking forward to finding out.
    Plus I think they look good too.
    Chase8059[QUOTED] likes this.
  3. Sep 6, 2024 at 12:40 PM
    #143
    Chase8059
    Chase
    ESVA
    Awesome, yes my only offloading is alot of beach driving for fishing. I don't need an E load for that. I was hoping to find something C load in 255/80r17 but looks like I need to downsize.
    Appreciate the info!
  4. Oct 12, 2024 at 9:42 PM
    #144
    Van_island
    Van_island Well-Known Member
    Isaac
    2019 taco
    How did that work for you ? I have SCS ray 10 17×8.5 -10 with a 2" front bilstien and a 1" block in the rear wondering if these tires will rub with that set up!
  5. Oct 12, 2024 at 9:43 PM
    #145
    Van_island
    Isaac
    2019 taco
    Rub?
  6. Oct 15, 2024 at 7:52 PM
    #146
    Van_island
    Isaac
    2019 taco
    Wheel specs?
  7. Dec 24, 2024 at 11:00 AM
    #147
    johnnytwotimes
    johnnytwotimes Well-Known Member
    SoCAL
    2021 TRD OR DCSB
    Went from 265/75/16 wildpeaks to 255/75/17 KO2
  8. Jan 12, 2025 at 8:30 PM
    #148
    johnnytwotimes
    SoCAL
    2021 TRD OR DCSB
    What psi you guys running?
  9. Feb 10, 2025 at 5:24 PM
    #149
    DSLiner
    DSLiner Member
    Donnie
    2022 White Tacoma SR 4x4
    None, yet
    What do you think, going from the 265/75r16’s to the 255/75r17’s? Like looking truck!
  10. Feb 12, 2025 at 3:19 AM
    #150
    DSLiner
    DSLiner Member
    Donnie
    None, yet
    Installed yesterday (2/11) really like the ride and look! Duratrac RT’s 255/75r17 Sport wheels no rub.1A3CDA22-0117-4116-AECF-C81F396B10DB.jpg79C29890-98BF-4EE2-8779-18E9616F0CD8.jpg39125D62-D8F0-4CD8-BCDE-20F900AA3C59.jpg1A3CDA22-0117-4116-AECF-C81F396B10DB.jpg
  11. Feb 12, 2025 at 5:02 PM
    #151
    Admiral Snackbar
    Coming up on a year with these. Firestone Destination XT, 100% would buy again. We got a little ice today.
    476965449_1698179847780414_2787894011690_4bd8dc88bdf4ed557214f5c025a2a1b397898b23.jpg
    476795867_1140825217174938_5065078908365_6c86e67404390bb44351216547c671b809fb6b29.jpg
    C_tanner, johnnytwotimes and DSLiner like this.
  12. Mar 2, 2025 at 6:36 PM
    #152
    4thgenjenny
    4thgenjenny Member
    Blue 2016 Tacoma TRD Sport 2WD
    Has anyone tried this tire size on stock TRD Sport wheels? I know the offset on them is something like +30 so I didn't know if there'd be rubbing issues or anything. Also, new to tires so I'm stumbling along lol
  13. Mar 2, 2025 at 6:46 PM
    #153
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I ran some 255/75s on the 2020-2023 Sport wheels. They look different but are the same dimensions as the 2016-2019 Sport wheels. They’ll fit fine with no rub at all, even on mud flaps.
  14. Mar 2, 2025 at 7:12 PM
    #154
    4thgenjenny
    4thgenjenny Member
    Thanks for the reply! Did you run them with a lift? I'm planning on doing 5100's all the way around with about an inch or so lift in the front.
  15. Mar 2, 2025 at 7:29 PM
    #155
    BLtheP
    Plano, TX
    No lift, all stock OR suspension. Lift really doesn’t do anything to help with tires, but it doesn’t hurt tire clearance either. You’ll be good to go.
  16. Mar 2, 2025 at 7:42 PM
    #156
    4thgenjenny
    4thgenjenny Member
    Well I know where my money is going now... Thanks!
  17. Mar 4, 2025 at 12:37 PM
    #157
    4thgenjenny
    4thgenjenny Member
    Here are the tires! Really appreciate the help, no rubbing at all and they drive real similar to stock. These tires are about 6 pounds heavier each than the stock ones so we'll see if it has much of an effect on the MPGs.
    BLtheP likes this.
  18. Mar 4, 2025 at 1:13 PM
    #158
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    You might have to reword your statement a wee bit. Check out your upper control arm. Appears to have a rub in right hand turns. ??
    Also, your milage calibrations might require compensating for the tire height change - if you changed away from original size. Consider that as well as weight.
  19. Mar 4, 2025 at 4:57 PM
    #159
    4thgenjenny
    4thgenjenny Member
    Good catch, I'll look more into it and see, thanks!
  20. Mar 6, 2025 at 5:43 AM
    #160
    4thgenjenny
    4thgenjenny Member
    Update: I've done a decent bit of mixed driving and have not seen any more tire rub marks, the other side of the vehicle has non at all on the UCA so I'm wondering if that rub was from something beforehand. Anyways, still happy with the tires, but can tell there's a drop in MPG (1-2ish) and power
