Anyone With 35’s running spacers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Edmak, Nov 26, 2023.
  1. Nov 26, 2023 at 11:58 AM
    Edmak
    Edmak [OP] Member
    I was about to order 35’s for my first gen and was wondering if I needed spacers to help with rubbing, I know I’ll need to do some rubbing but was wondering if the spacers would help. Thanks
  2. Nov 26, 2023 at 12:40 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I have 2" spacers on factory 3rd gen wheels and still rub. It's advisable to get wheels with proper backspacing though.
  3. Nov 26, 2023 at 1:41 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    You'll need more than spacer for 35s
  4. Nov 26, 2023 at 2:02 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Depending on where you are concerned of rubbing spacers may just make it worse.
  5. Nov 26, 2023 at 5:39 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Got a 3" lift?
  6. Nov 26, 2023 at 5:40 PM
    Edmak
    Edmak [OP] Member
    I have a 2.5
  7. Nov 26, 2023 at 5:45 PM
    MadNachos
    Where do your tires rub? Fenders?
  8. Nov 26, 2023 at 5:47 PM
    Edmak
    Edmak [OP] Member
    The reason I’m asking is so I knew if I needed to buy spacers, I’m about to order some wheels and tires and wanted to know if I need spacers to help with rubbing.
  9. Nov 26, 2023 at 5:49 PM
    MadNachos
    Gotcha. At 2.5" lift I am not sure of the clearance issues with 35's. I am running 33's with a 3" and it has tons of clearance so you may only need a bit of trimming but others should know for sure.
    Edmak[QUOTED][OP] likes this.
  10. Nov 26, 2023 at 6:24 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    The OP needs to research this deeper. To fit 35's is going to require cutting. A lift and wheel offset is not going to be enough. Not sure why the wheels being used hasn't been posted. The need for wheel.spacers would have some dependence on what wheels are used.
    MadNachos likes this.
  11. Nov 26, 2023 at 6:30 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Cutting, welding, loooooots
    Burro and Gen1andDone[QUOTED] like this.
  12. Nov 26, 2023 at 7:01 PM
    Gen1andDone
  13. Nov 26, 2023 at 7:03 PM
    Edmak
    Edmak [OP] Member
