Anyone With a 6-speed That Actually Upshifts Smoothly to 3rd Gear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco'09, Feb 20, 2015.
  1. Feb 20, 2015 at 11:05 AM
    Taco'09
    Taco'09 [OP] Well-Known Member
    I've been following issues with the 6-speed for years and is numerous parts revisions. Thought that by about 2011 problems with it were pretty much gone and wanted it on my new truck.
    So when I bought my '14 the first thing I noticed from day one was a 3rd gear clunk on the upshift, and if I'm not really careful it can grind. Now at 6,600 miles still the same. This thing has got to be past break-in at his point, no?
    I have owned a least 7 manuals over the years and try to rev match, etc. Right now am trying various gear oils. Checked the clutch adjust and even bled it just for good measure. Talked to a couple of dealers and of course they say its normal or "what's a manual transmission?"
    And yea, there are a million threads on the 6-speed and its problems. I want to know if you have a good one, especially the 3rd gear upshift?
  2. Feb 20, 2015 at 11:17 AM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I've had a '12 6-Speed (totaled) and now drive a '13 6-Speed. Both have never given me any issues and shift beautifully. They've both been smooth, quiet, and really a pleasure to drive.
    I've been driving manual transmissions for more than 15 years and have owned 4 Toyota Pickups: 2 5-Speeds and 2 6-Speeds.
    I've read over all the 6-Speed "Problem" threads and really feel like it's about the person using the clutch and shifting the gears.
  3. Feb 20, 2015 at 11:19 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    MT90 fluid will help some.
  4. Feb 20, 2015 at 11:35 AM
    Taco'09
    Thanks for the responses. I've replaced syncros in a few manuals and they shifted poorly thereafter for a while until broken in and then no problem.
    Sold My Subaru, did you just shift it with out giving it much thought or did you have to focus on shift if you know what I mean?
    Rupp1, MT90 is next on my list to try. So far I have tried the factory = not so good; Amsoil MTG = better maybe little bit better; and the GM Synthetic Manual Transmission Fluid = best so far esp. when cold.
    I also want to try the Ford fully synthetic "Honey" as it was made especially for problem 6-speeds to improve shiftability.
  5. Feb 20, 2015 at 11:54 AM
    Wasatch
    Wasatch Well-Known Member
    Shift around 3-4k, (most people with this observation are trying to shift too quickly in low RPM's). Slow down your shift from 1-2-3-4-5-6 a little bit. Grind/clunk will go away.
    Cars shift faster than trucks.
  6. Feb 20, 2015 at 11:59 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    A Subaru is not a truck and it is not rear drive I don't know why every one says my X shifts better than my 6 spd. of course it does. If you have ever driven a full size pickup with a stick you would say "my Tacoma shifts better than that" I have zero issues with my 6 spd. it does not grind in any gear it does take a bit to get used to it any vehicle does when you switch I will say you need to mat the clutch pedal can't just push it part way down.
  7. Feb 20, 2015 at 12:24 PM
    Jtom05
    Jtom05 Taco or die!
    Jarad
    NorCal
    05 taco Trd sport 6 speed
    All-pro bumper W/full skid plate, Donahue coil overs 2.5, alpro UCAw/uniball, K and N filter, icon 2.0 VS rear shocks, alpro expo +3 leaf springs, timbren rear bumpstops, Michelin ltx ms2, Pioneer AVIC4200
    Only time I have ever had an issue with a grind/clunk, I either had short stroked the clutch or hadn't backed off the throttle enough. I've bone both in 3rd and 5th.
  8. Feb 20, 2015 at 12:31 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Only problem I have with the 6 speed is the stupid rev hang.
    To the op I went to Redline oil and it seemed to smooth things out a bit.
  9. Feb 20, 2015 at 12:34 PM
    phillytaco43
    phillytaco43 New Member
    Jake
    Philadelphia
    13 TRD Sport
    I have a 2013 v6 6-speed (best choice I made on the truck), and never had a problem with grinding when I shift.
  10. Feb 20, 2015 at 12:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Change the oil, always use the clutch, shift carefully... or you'll be rebuilding the transmission.
  11. Feb 20, 2015 at 12:47 PM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Same issue with my 2013 6-speed. I'd grind into 3rd (from 2nd and 4th) on occasion. I also came from a Subaru (2004 STI) and I can tell you the truck transmission is just clunky. It's not made to shift quick and is just a not enjoyable experience because of all it's quirks.... I sold my 2013 6MT for a 2013 5AT within 7 months of buying it.
  12. Feb 20, 2015 at 12:54 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    The wife's 5-Speed VW golf shifts incredibly smooth.
    The 5-Speed Legacy with 4" lift and 28's beater I own has a cable clutch and is on her 4'th transmission and 2'nd rear end. When it comes to shifting that thing it's :burnrubber:
    My '13 Tacoma 6-Speed is damn smooth for a truck. It's a TON smoother than the 5-Speed '09 2500 Power Ram or 5-Speed '94 Toyota I had before her.
    I usually hit my shifts around 2-2.5k unless I'm merging or want to feel like I'm 18 again. I've changed my driving habits significantly since I purchased an UltraGauge but it hasn't changed the manner in which I go: depress clutch, change gear, release clutch. Not much thought required there.
    I've had the TRD shortshifter in both my '12 & '13 so maybe that helps?
  13. Feb 20, 2015 at 1:40 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    I think it's a driving habit. I've had several people complain about their manuals like grinding and not shifting smooth or it doesn't shift into gear right. I've noticed is they shift too fast. It's like you're shifting into gear but your foot on the clutch pedal is not fully engaged.
  14. Feb 20, 2015 at 3:10 PM
    AZRider
    AZRider Member
    Arizona
    13 TRD OR SuperWhite
    Been driving MT since about 1984. Last two cars were a subaru wrx with SS and then a BMW 135i. The BMW was like delicious soft butter with a positive little click at the engagement point. Going from that to the Tacoma was a change for sure but I have had no issues at all with shifting this Taco. Shifts are easy and positive. I usually don't shift above 3k unless I'm freeway on-ramping but even then no problems. It shifts like a truck for sure but I have never had any issues. Weird to hear so many people do have issues.
  15. Feb 20, 2015 at 3:27 PM
    loki750
    loki750 Well-Known Member
    Springfield MO
    Tacoma baja tx
    Mine shifts fine. My last one did too, and the 4 or 5 5 speeds I had before that did too. I don't know what causes people so many issues, I don't have any problems with mine.
  16. Feb 20, 2015 at 3:37 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Here is the bottom line if one person out of ten can operate the 6 spd perfectly there is nothing wrong with the trans.
  17. Feb 20, 2015 at 4:08 PM
    AZRider
    AZRider Member
    Arizona
    Possibly, but as we all know most people only post on the internets when they have a problem. So out of the 100's of 1000's of Taco's sold over the years with MT there are a few people that have issue shifting. Trans problem? User problem? Possibility one of each could be out there. Your mileage may vary.
  18. Feb 20, 2015 at 4:35 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I have not had any issue shifting my 08 into 3rd. Occasionally I need to double clutch on first, but I have have no real complaints about the shifting. Truth is I drive like an old man, rarely in a hurry, and rarely in busy traffic, so the Tacoma 6spd suits me fine.
  19. Feb 20, 2015 at 5:04 PM
    Taco'09
    Hmmm. I've seen this type of comment before. Come to think of it its worse <2,000 rpm. Others here also shifting at the higher revs?
  20. Feb 20, 2015 at 6:02 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I know exactly what you're talking about. I get the occasional grind going into the lower gears, and 3rd is most noticeable. I changed to Redline MT-90 and it does NOT make a difference (I think it's really the placebo effect when people think it helps).
    I've found RPM "sweet spots" that seem to work with no grinding/nicking. Going from 2nd to 3rd at about 30 mph seems to work well.
    Anyway, it doesn't seem like anything major. As long as I'm not having to replace synchros I don't care.
