Anyone With a 6-speed That Actually Upshifts Smoothly to 3rd Gear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco'09, Feb 20, 2015.
  1. Feb 20, 2015 at 6:07 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Yes. Generally higher RPMs do help.
  2. Feb 20, 2015 at 6:22 PM
    Pigpen
    Dan
    Northwest Montana
    I shift around 2k - 2500 and my '12 has been a pleasure since day one. I think the "problem" is a matter of perspective. Most who complain also mention a car they had/ have, usually a sporty one. The other vehicles I drive are a '06 Ram 3500 Cummins MT and a Freightliner. My little 4.0 is like the previously alluded to sporty cars compared to my other options.
  3. Feb 20, 2015 at 6:25 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    The master cylinder tends to get out of wack. The bolt on top of the pushrod slowly works loose and needs to be retightened every once in awhile. Changes how the truck shifts dramatically. Bleed the system a couple times a year.
  4. Feb 20, 2015 at 7:12 PM
    Taco'09
    Taco'09 [OP] Well-Known Member
    TACK if I'm calculating this correctly your 2-3 shift seems to be somewhere between 2,500-3,000 and would thus fall in line with other observations where it is the smoothest.
  5. Feb 20, 2015 at 9:37 PM
    2014 tacoma
    2014 tacoma Well-Known Member
    CO, USA
    14 Access TRD offroad
    I shift smoothly into every gear.. I guess hundreds of thousands of miles of experience driving a manual transmission truck have helped.
  6. Feb 20, 2015 at 9:50 PM
    TSJESME
    TSJESME Well-Known Member
    James
    Maui
    14 TRD SPORT A/C 4X4 M/T
    Funny. 2nd 6sp, 2nd gen for me, no issues. I think that if I say what I really feel the problem is, I could be banned. Most who cannot, have issues with 3rd & 5th. Loved the thread on what gear to use for 6 mph.
  7. Feb 21, 2015 at 12:24 AM
    RevoTaco
    RevoTaco Well-Known Member
    SoCal
    Sold - 08 6SP 4x4 AC TRD Off-Road
    TRD Shortshifter. Go get one. Seriously.
    You'll be SO surprised how many problems it solves.
  8. Feb 21, 2015 at 5:13 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If I had a problem I might consider $300 for a shifter. My wife has a Scion it shifts easier than the Tacoma but that transmission wouldn't last a day in the Tacoma. My Kubota has a hydrostat transmission that's easier than an automatic. One summer I ran a crane truck it was a Mac with a triplex transmission if you were heading up hill and missed a shift the only way out of it was to come to a dead stop and start over. The comparisons to other transmissions has little merit. Hopefully this will rattle some cages my wife all 5’ of her drives my truck occasionally her complaint? “this thing is big" she has no problems shifting it except she often forgets it’s a 6 spd.
  9. Feb 21, 2015 at 5:29 AM
    ChollosWorld
    ChollosWorld Member
    South Louisiana
    11 TRD Off-Road 4x4
    I have noticed the issue before when trying to shift too fast into 3rd. I have also had many manual trannys in the past and some have been worse some have been better. Overall, I haven't had any major issues with my 2011 6 spd and it shifts smoothly unless I do something to make it not shift smoothly.
  10. Feb 21, 2015 at 7:37 AM
    Taco'09
    Part of the reason I started this thread was because unfortunately if you read many of the older threads you might get the impression that the 6-speed was junk and to avoid it like the plague...but there is always the other side...those that have had no problems. I happen to like it and would not have it any other way...for mine it just sounds like I need to refine the 3rd gear upshift technique a bit
    Was also sort of hoping some with very high miles, like qnala, would chime in.
  11. Feb 21, 2015 at 1:23 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Had people I know say its their transmission. When I test drive it, turns out to be the driver. Have someone other than you drive it and see what they think.
  12. Feb 21, 2015 at 1:46 PM
    Taco'09
    Very good point. The wifey has zero issues with it, and can even float every last gear flawlessly, not that is a good idea.
    Funny thing, many years ago a friend wanted to teach me how to double clutch. He had a restored Ford Model "A" used in parades and such and that is what I learned on. They had no syncros at all and required double clutching up and down....
    But I digress...
    Silly as it may seem I think it is very possible to learn to drive and develop poor shifting habits early on and many of the manuals have just been very forgiving transmissions.
  13. Feb 21, 2015 at 4:53 PM
    Midship909
    Midship909 Well-Known Member
    SocaL
    13 MGM 4x4 OR 6speed
    My 6speed shifts great even better after 20k miles and i didnt buy a short shifter or change fluid.
  14. Feb 21, 2015 at 5:59 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    3rd is actually one of my best (smoothest) shifts.
  15. Feb 21, 2015 at 6:35 PM
    #35
    Rosesplus
    Rosesplus Well-Known Member
    42K miles on my 2012 and the shifts have been fine.
  16. Feb 21, 2015 at 7:07 PM
    #36
    gearcruncher
    Canadain bumper technician
    I still think that small problems are popping up because the pilot bearing has been omitted from the rear of the crankshaft . Thats rite folks , if you have the 6 speed , you no longer have a pilot bearing . With this said , every time your clutch disc moves away from the flywheel at high rpm , the input shaft and input bearing now take on the additional task of supporting that radial load . A clutch disc doesnt weigh much when you are holding it in your hand but imagine trying to hold the weight of that clutch disc spinning at 3000 rpm . I can see this additional rotating mass having some effect on the input shaft synchronizers when end play tolerances are not set to perfection .
  17. Feb 21, 2015 at 7:35 PM
    #37
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    The 6spd transmission is still a good transmission. You just have to know how to drive it, and like any other manual vehicle, it may have it's quirks. Cold weather can make it temperamental (so i've read) and short stroking the clutch is a big problem with this transmission i feel. Some of use like to shift really quick or at an odd RPM range, and in turn, we don't fully use the clutch. I also change my fluid every 30k with Redline MT-90 as added help. It isn't the best transmission in the world, but i would definitely not say its junk.
  18. Feb 22, 2015 at 4:26 AM
    #38
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  19. Feb 22, 2015 at 5:08 PM
    #39
    gearcruncher
    Glad you pointed that out . Now you got me wondering why the FSM doesnt show a pilot bearing for the input shaft .
    Check out page 3 of 16 http://www.customtacos.com/tech.old...6toyrm/06toypdf/06rmsrc/rm2006ta/03200510.pdf
    Seen countless images of members here who did clutch jobs and no pilot bearing shown .
    Maybe some members can chime in with some answers . Anyone ever change a pilot bearing on your 2005 and up Tacoma with the 6 speed ?
    Might be year specific , I dunno :confused:
  20. Feb 22, 2015 at 7:41 PM
    #40
    Space Junk
    Space Junk Flight Ready
    Silicon Valley
    2013 Tacoma access Cab TRD Off Road
    I had a couple quarts or Redline laying around and decided to try it it in the Tacoma. Definitely shifts smoother and quieter.
