Anyone with a one piece drive shaft?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dtavares, Nov 8, 2020.
  1. Nov 8, 2020 at 10:44 AM
    dtavares
    dtavares [OP] Member
    Dylan
    Oregon
    2020 White Double Cab Limited
    6” BDS Bilstein 5100 cranked up one notch 305/55r20 20x12 -44
    Was thinking about getting a one piece built. Anyone else here got one? My 2020 limited is lifted 6” and I’ve got some vibration. Pros and cons?
  2. Nov 8, 2020 at 11:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    A major con would be the need for a second custom one should the first fail, assuming you didnt retro to a 2 piece.
    2nd is a loss of ground clearance in the center of the truck. But your DB lift has already kept you restricted at the axle lines, so maybe that's a non issue?
    3rd for some folk is price.
    Do you know for sure the DS is the issue? That's a lot of money to be guessing about.
  3. Nov 8, 2020 at 11:47 AM
    TacomaBeast67
    TacomaBeast67 Well-Known Member
    Calgary, Alberta
    2017 TRD Sport, Dbl Cab, Manual
    K&N Cold Air Intake, N-Fab Rock Rails, Removeable Steps, BAC Revolver X2 tonneau, 265/70/17, engine bay LED’s, Amber/clear strobes
    This guy did one. I’ve asked how it did for him a while back and never got a response. There’s other ways of researching this.
    https://youtu.be/fsNB0HQPxvw
  4. Nov 8, 2020 at 1:17 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Single or double cardan? Double cardan requires a zero working angle at the pinion...could starve the pinion bearings.
    Reduced critical speed due to increased tube diameter.
