Anyone with the 2.7L run E load rated tires? How bad will it be?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by barch88, Jan 25, 2024.
  1. Jan 25, 2024 at 8:42 AM
    barch88
    barch88 [OP] Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    Anyone with the 2.7L run E load tires?
    I just picked up at set of Method 703’s in 17”. They are 2.8lbs lighter per wheel than my stock steelies. I was really torn between BFG K02 tires in C load (265/70r17), or Toyo AT3 in C load.
    I ordered the C load Toyos but after checking the spec sheet, the Toyo C loads are actually 50lbs per tire and their E load of the same tire is only 48lbs per tire. Not entirely sure if this is 100% accurate for the C load weight, but I did confirm the E loads are 48lbs each. Tirerack told me the C rated ones are backordered 90+ days. I paid the difference and changed my order to the E load. I didn’t want SL or P metric because the sidewall isn’t nearly as aggressive looking and I live in a very rural area where I go down lots of gravel roads. I’ve had terrible luck with tire punctures over the years so I wanted something strong.
    How much worse off will I be with the E rated tires? I tried to do some quick math, between the weight savings with the new wheels and the added weight from the new tires, I should be around ~50lbs total heavier than my previous setup (total, not per tire).
    I doubt I’ll feel 50lb difference overall, but I know tires can be weird how you feel the rolling resistance. Anyone run E load tires with the 2.7? How bad is it?
    I called Toyo and they told me to run 38psi in the E load tires for my truck. What does everyone else run?
    Thanks guys. First big upgrade on my taco and it should really transform the look.
    Junkhead likes this.
  2. Jan 25, 2024 at 8:50 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    FWIW i wouldnt run E's on a mid size truck, but thats just me.
  3. Jan 25, 2024 at 9:14 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I feel it depends on where you live.
  4. Jan 25, 2024 at 9:19 AM
    barch88
    Michigan, USA
    Michigans upper peninsula. Rocky, woodland area. No crazy mountain passes but the trails and backroads consist of old logging roads, very gnarly sharp rocks and things of the sort. Figured E toughness would pay off in return for poor acceleration and worse braking performance. Luckily I don’t daily commute the truck as I work from home. It’s mostly used for fun and running errands, so I want something that’ll last awhile
    Junkhead, TartanEagle and Steves104x4 like this.
  5. Jan 25, 2024 at 9:25 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    I spend a lot of time around sharp objects, so this truck has always had E rated for that reason. That said, in March I'm going to see how XL rated tires do on the volcanic rock in the Parashant National Monument. I finally got tired of the rough ride after 35 years...
    barch88[OP] likes this.
  6. Jan 25, 2024 at 9:27 AM
    barch88
    Michigan, USA
    It’s the 2.7L? I know this truck already struggles a bit on inclines, gotta put my foot down a bit. How much worse is the acceleration and braking?
  7. Jan 25, 2024 at 9:27 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Junkhead and barch88[OP] like this.
  8. Jan 25, 2024 at 9:30 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    I feel tire size, more than weight affect performance of acceleration and braking. The stiffer sidewalls are what make it harsh on pavement, but a godsend on the sharp rocks.
  9. Jan 25, 2024 at 9:31 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Harsh. Good.
    Junkhead and Bikinaz[QUOTED] like this.
  10. Jan 25, 2024 at 9:36 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Ya, that’s a little much.
  11. Jan 25, 2024 at 9:39 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    38PSI sounds a bit high to me. I'd lower that a bit if you hate the ride. Obviously, it could be right for your tires. I run my E-load Duratracs anywhere between 33 and 35, but my truck is constantly using about 1000 pounds of it's payload with all the sliders, bumpers, and such. When I throw the camper on I bump it up to around 55-60. It's just about undriveable at those pressures without the camper, hahaha.
  12. Jan 25, 2024 at 9:57 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    I run around 35ish psi with maybe 6000ish pounds. I do like feeling more confident aired down to 15 psi on Es. We'll see how the XLs feel aired down this weekend. I'll start at 18 and see how it goes.:fingerscrossed:
    Edit; My Yokohamas from last week supposedly weighed 50 pounds. My new tires supposedly weigh 45.
    COOPER
    DISCOVERER RUGGED TREK
    265 /70 R17 116T XL RBL
    YF_Ryan[QUOTED] likes this.
  13. Jan 25, 2024 at 9:59 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I have STT Pro mud tires on my 4cyl auto. They are heavy, and slow on the road braking suffers. It's not terrible, might be worth the trade off if I ever took the truck off road.
  14. Jan 25, 2024 at 9:59 AM
    barch88
    Michigan, USA
    I’ll start with maybe 33 and go from there. What would be the minimum psi to safely run E load tires without doing much sidewall damage? I imagine anything below 30 would cause the tpms to go off? I know certain situations like airing down for rocks and snow etc is normal, but I’m talking about for daily driving
  15. Jan 25, 2024 at 10:00 AM
    barch88
    Michigan, USA
    Those are even heavier- what size do you run?
    batacoma[QUOTED] likes this.
  16. Jan 25, 2024 at 10:01 AM
    batacoma
    batacoma Truck Wars
    265 75 16, so not that large but still heavy.
  17. Jan 25, 2024 at 10:08 AM
    YF_Ryan
    Kent, WA
    I'd start with what they suggested and go from there. Once you find the pressure you like, you should reset your TPMS to that pressure. I'm assuming you can do that on the 3rd gen like you can on the 2nd gen, but I don't know how for you. On the 2nd gen, there's simply a button under the steering column, but the 3rd gen has an improved TPMS system.
    barch88[QUOTED][OP] likes this.
  18. Jan 25, 2024 at 10:12 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Also a pretty safe rule is the more aggressive the tires look the heavier they'll be respective to their weight rating.
    Edit; Before it starts... usually, but nothing is "always."
    YF_Ryan likes this.
  19. Jan 25, 2024 at 10:13 AM
    YF_Ryan
    Kent, WA
    I aired down to 35 or so at ~7000 pounds to drive out onto the sand to get to camp, and it worked pretty well. I unloaded the camper, forgetting to air down again, grabbed my trailer and drug it out on the sand and did NOT make it very far. My wife was like, "you didn't air down again, did you?". Dropped to around 17 and it worked great (after digging myself out and dropping maxtrax).
    barch88[OP] and Bikinaz[QUOTED] like this.
  20. Jan 25, 2024 at 10:14 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    37 is what the converted pressure comes to when converting from stock. Go with that.
