Anyone with Toytec C/O and TC UCA and 285/75/16
Discussion in 'Wheels & Tires' started by ComaTosin, Mar 16, 2009.
  1. Mar 16, 2009 at 6:49 PM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    if so what wheels (and tires) are you running and what is the backspacing and offset? I had no rubbing when i had the spacer lift but now that i have switched to "real" lift it has pulled the wheels under the truck and caused rubbing. i have the C/O up to about 3" lift at this point.
    pics would be great too. thanks.
    wondered if i need more or less backspacing? currently 4.5
  2. Mar 17, 2009 at 5:52 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    bump.... nothing?
    anyone, anyone............ Bueller?
  3. Mar 17, 2009 at 6:01 AM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    I'm running the Moto Metal 955's 16x8, Backspace 4.50 in, Offset = 0 mm, 285/75-16 and I have no issues. Check my gallery out for pics
  4. Mar 17, 2009 at 6:12 AM
    jolayiv
    Jim
    New Bern NC
    BTW what type/where of rubbing are you talking about?
  5. Mar 17, 2009 at 10:45 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    are you running stock UCA? i am talking about rubbing on the frame and some on the front plastic. I was all clear with toytec C/O at 2.5" (just like my daystar spacers) until i put on the UCA which pulled the wheel under the truck more and then started rubbing.
  6. Mar 17, 2009 at 11:23 AM
    jolayiv
    Jim
    New Bern NC
    No I'm running the TC UCA's. As far as the rubbing on the frame, you are most likely rubbing on the body mount and for the plastic you need to trim out your fender wells some.
  7. Mar 17, 2009 at 11:38 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    yeah. i said frame but i guess it is really the body mount brace. I guess i should just crank up the C/O to 3" and see what happens then. just trying to keep it level without messing with the rear right now.
    thanks
