Anyone's 2009 Tacoma Access Cab Sr5 Come Pre-wired for Fog Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C17Guy, Feb 7, 2010.
  1. Feb 7, 2010 at 8:10 PM
    C17Guy
    C17Guy [OP] Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    I have a 09 Tacoma, 2.7L, Access Cab Sr5 and was curious if I would have the pre-wire for foglights? Any ideas? Thanks!
  2. Feb 7, 2010 at 8:24 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    I don't think 2.7s are. Just go out and take off the cap for the fog lights and see if there is a wire and plugged taped up in there.
  3. Feb 7, 2010 at 11:11 PM
    C17Guy
    Dennis
    Could they be taped any where else, I had to replace a bumper about 2 weeks ago, at a shop, and wasn't able to look under.
  4. Feb 8, 2010 at 3:10 PM
    topgun155
    Zack
    I think the only place they put them is right there. If you feel around those caps there is a tab you push in and it comes right out. Then grab a light and look around in there you will see it. If you have it.
  5. Feb 8, 2010 at 3:36 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    the 2.7's are not prewired, i believe the v6's are but don't quote me on that.
  6. Feb 8, 2010 at 3:39 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    This is true for 08s, so I'd assume it's the same on 09s.
  7. Feb 8, 2010 at 3:44 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    i had to wire my foglights, its not hard at all, i wired it into a factory switch, looks oem all the way down to the taped wire loom running to everything.
  8. Dec 21, 2012 at 10:05 PM
    gnarcal
    gnarcal Active Member
    Max
    Washington State
    '09 Tacoma 4x4
    Bilstein 5100's SPC Performance upper control arms Diff drop 1.5° shims Carrier bearing drop 1" AL blocks in rear
    Hey "Top gun 55" you must be a lighting expert. My 09 taco is pre wired for fog lights but did not come with with fog lights. Now I'm trying to install my new fogs.
    If I add the fog relay, the oem switch and plug the fogs into the existing plugs located behind the empty fog sockets... should that work?
    Right now its not working but I'm not 100% sure I have the correct relay. The correct relay will be delivered soon but in the meantime I'm left to wonder.
    Pls help
