anyone's 2012 Tacoma have steering wheel vibration?
Discussion in 'Technical Chat' started by TacoTitan11, Jun 6, 2012.
  1. Jun 6, 2012 at 6:14 PM
    TacoTitan11
    TacoTitan11 [OP] Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    i noticed on my 2012 double cab with 3700 miles that sometimes once i hit 65 to 70 mph, i notice a slight vibration from the steering wheel. But its weird because it doesnt do it all the time, just randomly here and there. Not sure how to handle this one. I figured if it was an alignment issue then it would be doing it continuously. Any suggestions? :facepalm:
  2. Jun 6, 2012 at 7:48 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Check your wheels for mud build up next time it happens.
  3. Jun 7, 2012 at 4:01 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    i dont really do any off roading or anything where mud would get in and around my wheels
  4. Jun 7, 2012 at 4:03 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    have the balance checked
  5. Jun 7, 2012 at 4:05 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    would it be doing it randomly though if it was a balance issue?
  6. Jun 7, 2012 at 4:13 PM
    Blueburner
    Blueburner New Member
    Fort Worth, Tx
    Prerunner SR5 TX Edition
    Stock for now
    Mine does it, but it's not a real big deal, figured I have them rebalanced at the first oil change.
  7. Jun 7, 2012 at 4:25 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    its weird man, like i said, does it only at around 66-70 mph. and its random, not everytime
  8. Jun 7, 2012 at 4:51 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Mine does the same thing on my 08.. Clearly a toyota issue that will never be fixed
  9. Jun 7, 2012 at 5:05 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Are you running aftermarket wheels with different offset than stock? You will get more steering vibration with 0mm offset wheels because the scrub radius is larger (i.e. the contact patch has more leverage over the steering axis).
  10. Jun 7, 2012 at 5:12 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    i have stock Dunlop AT20 tires and factory steel wheels....so this is pretty common huh?
  11. Jun 7, 2012 at 5:19 PM
    KenLyns
    Belly of the Beast
    Check the wheel balance. A wheel weight could've fallen off. There could be some interaction with the pavement texture that makes the behavior inconsistent.
  12. Jun 7, 2012 at 5:20 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I had the same issue. Got mine rebalanced at my first oil change and it went away for good.
    I think it seems random because you're not always accelerating at the same rate. it would only vibrate on mine when I pick up speed pretty slow and steady, if I got on it i didn't feel them
  13. Jun 7, 2012 at 5:34 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    you think toyota will cover the balance since i have only 3700 miles on it?
  14. Jun 7, 2012 at 5:39 PM
    KenLyns
    Belly of the Beast
    You can probably negotiate it to have the balancing covered. Balancing two front wheels isn't expensive (~$25).
  15. Jun 7, 2012 at 5:40 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    i gotcha, ok, cool. maybe i need to go ahead and just get me some new wheels and tires,, hahahaha
  16. Jun 7, 2012 at 5:48 PM
    Patrobs
    Patrobs Well-Known Member
    Patrick
    New Hampshire
    2012 Dbl Cab Short bed TRD Offroad
    Same thing with mine. I just went over 1k miles, the vibration doesnt seem as bad but it is still there between 65-70
  17. Jun 7, 2012 at 5:58 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    yeah, totally weird, always around the 65-70 mph range, and its not all the time !!!! :(
  18. Jun 7, 2012 at 6:04 PM
    KenLyns
    Belly of the Beast
    Driver faster than 70 mph. :cool:
    "On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit.' As soon as you touch this limit, something happens and you suddenly can go a little bit further." - Senna
  19. Jun 7, 2012 at 6:28 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    speed baby !
  20. Jun 7, 2012 at 6:32 PM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    I had a similar problem back in the 1970s. Seems the belts in early tire designs had a tendency to 'walk around' the tire as it was driven, thus altering the balance. The shop manager could feel the belt shift on the suspect tire. (factory origonal) When I got a set of Michelin tires the problem was gone forever. Might not be your issue, but just throwing the idea on the table.
