anything difficult regarding changing 2016 front/rear differential fluid?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SMT, Dec 28, 2019.
  1. Dec 28, 2019 at 9:55 PM
    SMT
    SMT [OP] New Member
    Scott
    Anything difficult in changing front/rear differential fluid on 2016 Tacoma 4x4?
  2. Dec 28, 2019 at 10:07 PM
    Bishop84
    Bishop84 Well-Known Member
    Quality 3/8" 10mm allen key is critical for the front. If the drain is super tight, simply hit it with a hammer flat faced and try again.
    Rear is 24mm or 15/16" and is harder to strip.
  3. Dec 28, 2019 at 10:11 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Always make sure you can loosen the fill plug before you drain it.
    Raeburn, wahoobie, Bleep100 and 2 others like this.
  4. Dec 29, 2019 at 6:35 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Make sure to replace the crush washers... Don't reuse them, it's not worth it.
  5. Dec 29, 2019 at 7:10 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I would say for the front only use a 10mm allen, 3/8" is ever so slightly smaller and more likely to strip.
    I'd also recommend using an allen socket on a ratchet or breaker bar, that way one hand can keep it straight in the drain plug while you loosen.
  6. Dec 29, 2019 at 7:13 AM
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    What tooling are folks using to fill? Is there any special tooling required due to low clearance? I have a tool that resembles a syringe with a rubber hose on the end, that's what I was planning on using.
  7. Dec 29, 2019 at 7:15 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Always super easy for me. I just let the dealer do it. No muss, no fuss. Any fuck-ups are on them.
    G.
  8. Dec 29, 2019 at 7:23 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    And you pay 3x what people who do it themselves.
    I'm not sure how people fuck that job up.
  9. Dec 29, 2019 at 7:28 AM
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    75/90 full synthetic gear oil
  10. Dec 29, 2019 at 7:46 AM
    DTaco18
    I used Redline GL-5 75w-85 just to match Toyota viscosity recommendation.
    You can get a quart bottle pump on Amazon for around $5. I have used Plews 55001 many times with good luck.
  11. Dec 29, 2019 at 7:54 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Make sure you have a decent oil pump. I bought the syringe style and what a mess. The Stalube pump that screws on the bottle is the one to get.
    I also second Redline, but fuck Amazon I found it cheaper on eBay shipped
    shakerhood and mrCanoehead like this.
  12. Dec 29, 2019 at 7:59 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I got this off of Amazon, worked pretty well but did not screw onto amsoil bottles.
    mrCanoehead[QUOTED] likes this.
  13. Dec 29, 2019 at 8:10 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    There's a whole thread on detailed instructions for this, read it.
    As for oil, opinions are quite varied. I settled on Redline 75w-85 after reading every thread I could find discussing oil type. Ebay is the best place to buy.
    Most difficult aspect is breaking loose the fill and drain plugs. Long breaker bar or impact wrench needed. I had to use a breaker bar and floor jack in combo to remove rear fill plug.
    https://www.tacomaworld.com/threads/3rd-gen-diy-maintenance-quick-reference.406712/
    https://www.tacomaworld.com/threads...-manual-transmission-6mt-fluid-change.481719/
  14. Dec 29, 2019 at 8:43 AM
    Bishop84
    3/8" drive bro.
