Anything else I should change with timing belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NWOmessiah, Feb 2, 2024.
  1. Feb 2, 2024 at 2:55 PM
    NWOmessiah
    NWOmessiah [OP] Member
    2004 Silver Sky Metallic Double Cab PreRunner V6
    canoe rack
    I bought my 2004 3.4L in 2016 w/ 120k miles and it has about 230k now. I paid a shop to replace a head gasket when I first bought it....since then I've done all the work myself on it with no major problems, although I may be burning a bit of oil recently, or have a slow leak I can't identify from where just yet(I end up topping off the oil once or twice between oil changes).
    I've replaced spark plugs, wires, and one ignition coil, brakes and rotors, routine oil changes, and a coolant flush recently that seemed to clear up some weird gurgling noises (the coolant was pretty low by time I noticed, and was very dirty)....truck never over heated tho, and seems to be running fine.
    I have no idea when the last time the timing belt was changed, and I haven't done it myself and have put 110k on the truck...so I figured it prob will be time soon.
    What else should I go ahead and do along with the timing belt? I'll be attempting all of these on my own.
  2. Feb 2, 2024 at 3:07 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    If I remember right, thermostat and water pump, while you're already in there.
    rocknbil likes this.
  3. Feb 2, 2024 at 4:27 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    You can buy the whole toyota kit with the idlers and belt and WP and tensioner and cam/crank seals.
    The Driver and TnShooter like this.
  4. Feb 2, 2024 at 10:38 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  5. Feb 2, 2024 at 11:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Where's the coolant going? If you can't find any external leaks it kinda sounds like a head gasket
    Laxtoy likes this.
  6. Feb 7, 2024 at 12:18 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Buy the complete set from "aircabinman". Do a search in this forum for details. And you'll need a torque wrench that will handle at least 250 foot-pounds (or more, check the torque spec) to torque the crankshaft pulley bolt, and maybe a $15 seal remover.
    leid likes this.
  7. Feb 7, 2024 at 12:23 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    get some good hose clamps on there.
  8. Feb 8, 2024 at 9:22 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    You said dirty coolant, like black/residue in the coolant overflow tank? Losing oil/coolant with no identifiable leak, gurgling coolant, that’s typical of a head gasket failure, black is from oil/gases getting into the coolant passage. Might try a leak down test.
  9. Feb 8, 2024 at 9:25 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    All this plus valve cover seals.
