Anything special needed to change the CV axles?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 3.4PDM, Apr 22, 2010.
  1. Apr 22, 2010 at 9:09 PM
    3.4PDM
    3.4PDM [OP] Well-Known Member
    Im thinking of doing this myself to save a couple of dollars... Im quite good mechanically but Im not sure what needs to be done to get the axles out in the easiest way...
    97 4x4 with auto hubs
    Any suggestions?
    thanks
    peter
  2. Apr 22, 2010 at 9:23 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    the axle nut is a 30 mm i believe. other than that i think u need a 14, 17 19 socket and wrench and def a hammer and prybar to punch the cv's out. and a torque wrench to torque the axle nut back down. i can get u specs if u want them. i just replaced mine....
  3. Apr 22, 2010 at 9:28 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I haven't done it on a Tacoma but I hear slide hammers are easier to use than pry bars to get it out. Supposedly the trick is to hose clamp the slide hammer claw in place. Autozone loans them with a deposit.
  4. Apr 22, 2010 at 9:28 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    yep...that axle nut is the only thing you need a "special" tool for
    i forget the size...30mm may be correct but im not gonna run out to my truck to check
  5. Apr 22, 2010 at 9:33 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    a three foot pry bar and a hammer. they come out every time....
  6. Apr 22, 2010 at 9:35 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I heard a 1 3/8" socket works which would be closer to 34 or 35 mm but again, I haven't done it so I'm not sure. I would like to know for sure so I can go buy the socket and keep it ready to go.
  7. Apr 22, 2010 at 9:38 PM
    JimBeam
    JB
    2015 Tundra
    youre correct...its a 35mm
    http://www.4x4wire.com/toyota/maintenance/cv_axle/
  8. Apr 22, 2010 at 9:56 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    i just asked another buddy he said either 32 or 36.
