Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Mar 4, 2021 at 7:02 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Science. I’ve had so many people show up with half the amount we agreed on and still expect me to let them take it. “ATM would only let me take out x amount” is the usual excuse. Not my problem.
    Wyoming09 and gpb[QUOTED] like this.
  2. Mar 5, 2021 at 1:31 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    For the majority of the welding I do .023 wire works just fine I like the better control. Being able to do body panels to 1/4"
    Small jobs can get stick welded. Being it is all for fun and not paying bills .
    If I need to get serious it only takes a Set of Drive Rolls Swapped and gun change to go to .052 I really Don`t miss rebuilding 5 yard Buckets .
    0xDEADBEEF[QUOTED] likes this.
  3. Mar 5, 2021 at 1:54 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    There was never a Machine Torch Option for the ICE 40C torch I am not sure if anything else will work.
    If your interested I can ask of the brain Trust those discussions that should be billed at $600.00 an hour.
    koditten[QUOTED] likes this.
  4. Mar 5, 2021 at 5:14 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Thanks, Craig, I'm good. I got enough money wrapped up in this thing.
  5. Mar 5, 2021 at 6:06 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I have the Primeweld Cut 60amp and my compressor seems to keep up okay. I've made some 8' cuts on 3/8" plate when cutting 4'x8' sheets down and I didn't have any issues with pressure drop.
    @gpb I am pretty confident in the sale because the guy is my former boss, and he has been after me for several years about when I am going to sell him the Harley. He already bought my Yamaha. Only reason he would back out is I have a 1982 shovelhead. He has a late model Harley and the ride is completely different. He says he wants "an older bike", but we'll see. He is supposed to come ride it in the next week or so. He definitely has the money.
    Edit: and BTW, no matter how big of a garage a guy has, he's always gonna want more space. :) It just takes a little longer to over-fill the darned thing.
    Shmellmopwho[QUOTED] and gpb like this.
  6. Mar 5, 2021 at 8:19 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    Hell Yah it is!
    I replicated a few pictures on TW with it and ended up with this Skid Plate
    ACtC-3fNRtS9thPtAFprYwOXawNMY94rDpsqEj6x_72314d6e9e15a7beaaa942f6494568731eeed310.jpg
    ACtC-3eHz0M5AZdxIJbttzYO-SageJu80Hl55WB2_2887107d0217dcda0d5623d4a78dd5ead631f285.jpg
    this is something a friend dropped off, its a 2nd gen Radio mounting thingy we're messing with.
    Two of these will slide between the dash and the radio giving you some "ears" to mount stuff to like a Radio, or something to mount a GPS to etc..
    ACtC-3eLAdryyR6V9DcOfXiH_9Guplg_J95hM90x_804488030fbad1d895512e2edb088575a5c13db0.jpg
    I took a picture of the cardboard, then imported it into Fusion, did some scaling and some "tracing" and volia. I have a working CAD file I can tweak and hopefully cut out of sheet metal.
    and its free!
    such a cool program.
    JMcFly and koditten[QUOTED] like this.
  7. Mar 5, 2021 at 8:40 AM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    I've used Fusion to design and produce a few parts that I sell to help fund the hobbies.
  8. Mar 5, 2021 at 9:52 AM
    koditten
    Kirk
    Central Michigan
    I'm just now learning scaling. Yes, this is going to open up lots of new roads.
    mjbtaco, Pyrotech and 0xDEADBEEF like this.
  9. Mar 5, 2021 at 11:22 AM
    Pyrotech
    Pyrotech Well-Known Member
    I am looking at the same machine when I build my table and I was wondering what size compressor your using with your cut60
  10. Mar 5, 2021 at 2:45 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Rate my weld... :D
    via TacomaWorld Welcome To Florida... 115969
    six5crèéd likes this.
  11. Mar 5, 2021 at 2:51 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No welding but thought I’d share anyways since I played with my plasma and it’s fabrication.
    Why do stupid little brackets like these always seem to take forever?! I guess it’s from all the fitment checking and measurement taking. Took like 90 min to make these. Cut out with the plasma and bent in my vice with a 3lb hammer.
    672DFC43-72AB-459A-AC63-2F50659850C8.jpg 6057860C-D915-40DD-90AC-12F5C2F7FE79.jpg
  12. Mar 5, 2021 at 7:24 PM
    Wsidr1
    Indiana
    Just using as a hobbyist, never had any issues with this Cambell-Hausfield compressor keeping up. As I said in previous post, I have single cut 8' of 3/8" plate without issue. Not sure what you plan to cut as far as length and thickness, but this is working for me so far.
    Here is what the Primeweld manual shows for PSI for different material types. It has no SCFM requirements.
    1st category is mild steel. Cut off the title when cropping.
    Pyrotech[QUOTED] likes this.
  13. Mar 6, 2021 at 2:53 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    80'x 80' but for a small office and living quarters .
    The Tool boxes sit in what may be a Living Room if the body does not quit .
    Far to many Projects not enough time.
    Wsidr1[QUOTED] and Pyrotech like this.
  14. Mar 6, 2021 at 3:31 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Well this was a frustrating and difficult lesson on working with sheet metal on the truck bed. The hardest part is the metal is not consistent because it was originally cut and bashed with a hammer by me to fit something into the space back in 2017. Now I wanted to seal it back up.
    Started here:
    I used the tack/cool method to build little bridges over the gaps, and then had enough material where I could do long sweeps back and forth between each side:
    Then I cut a filler piece and welded it in:
    My next step was going to go back over all of it to try to fill in the gaps I missed but then I burnt through on the top corner and spent 45 mins chasing my tail try to fill it back in. I should have let it cool instead of kept trying to go at it. Definitely not into body work on bent and rusty metal lol. I think a resto job is not something I would ever attempts
    Tacman19, GHOST SHIP and gpb like this.
  15. Mar 6, 2021 at 7:22 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    If you could get under that piece Aluminum or Copper used as A heat sink works wonders .
    It can save your butt often I know it has mine I always had something to use in the truck .
    WarrenG likes this.
  16. Mar 6, 2021 at 9:36 AM
    koditten
    Kirk
    Central Michigan
    I'm glad I build these things knowing I may have to take it apart.
    Owner decided to try his hand at fabbing, by adding 3' to the rear of the frame. Trailer was untowable being ass heavy. Tapped out and called me to see if I could move the axle back. I'll never be without my portable band saw.
    D2., Pyrotech, EatSleepTacos and 4 others like this.
  17. Mar 6, 2021 at 10:03 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not everyone thinks things through.
    I wonder why they just did not get a longer trailer to start?
    How much did you move it back gotta be real close then to the tongue being to heavy unless one is careful how things get loaded.
  18. Mar 6, 2021 at 10:20 AM
    koditten
    Kirk
    Central Michigan
    This trailer has an extra heavy tail gate. Moving the axle back 12" should be about right.
    Wyoming09 likes this.
  19. Mar 6, 2021 at 10:54 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Do you mean you’re moving it 12” off center to the back?
  20. Mar 6, 2021 at 10:54 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Welded some chains on the bushhog.
