Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Feb 28, 2022 at 3:27 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Pretty !! Really once you know what your looking at to me all the processes just need a little adjustment between them.
    I love Tig welding but the prep work takes forever !
    Kwikvette[QUOTED] likes this.
  2. Feb 28, 2022 at 3:37 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    That's fair. If you need to take the bed off for other stuff midaswell weld the towers on when it's off. It will make things easier, it's just not worth all the hassle to ONLY do shock towers.
    Out of curiosity what did accutune recommend that changed your mind on the shock relocation?
    wi_taco[QUOTED] and Bivouac like this.
  3. Feb 28, 2022 at 4:01 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Well basically today they started selling the Fox Performance Elite series which are full aluminum body 2.5 shocks. Better corrosion resistance which is great for me up here in Rustville. Based on my weight/configuration they said doing 2.0 mid travel rears are not going to last as long between rebuilds even on the street and might have sway issues (their opinion but makes some sense). They suggested I stick with stock shock location and do the 10” travel 2.5 shocks since it’s my DD and mostly on the road.
    It’s the smart move and they are right mostly. Wish I could do 2.5 mid travels but I don’t want to start screwing with spacers/backspace/cutting/rubbing for now. Maybe in the future, figure I’ll run the 10” for now until either they need rebuild or I start wheeling harder and they hold me back which I don’t expect any time soon unless my other plans in life to move out west change first.
  4. Feb 28, 2022 at 4:35 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I’ve always built my own adjustable feet for things but these weld-nuts really speed up the process. Can’t find them in bulk for less yet though. Kind of spendy.
  5. Feb 28, 2022 at 4:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  6. Feb 28, 2022 at 4:43 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Do you mind sharing what your rough total materials cost was for this?
    backcountryj likes this.
  7. Feb 28, 2022 at 5:28 PM
    koditten
    Kirk
    Central Michigan
    Somewhere around $1500.
    I actually thought about posting all the expenses and the list of parts and demensions. I've had requests, so I think I'll list everything once I'm done.
    I've got an hour of touch up tomorrow. I'll do it after that.
    0xDEADBEEF, dk_crew, Bivouac and 6 others like this.
  8. Feb 28, 2022 at 5:33 PM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    I look forward to it!
  9. Feb 28, 2022 at 5:36 PM
    koditten
    Kirk
    Central Michigan
    Me too!
    I need to have a good, smudge free copy for myself!
    It's about time a had one posted to the 'net.
    Prices won't remain valid, but the parts won't change.
    Pyrotech, Bivouac, Drainbung and 4 others like this.
  10. Feb 28, 2022 at 5:49 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welders are like a Tacoma - if it is kept in good condition there is always a market for it. When you outgrow your first welder there will be another guy starting out just like you were looking for one.
    wi_taco[QUOTED] likes this.
  11. Feb 28, 2022 at 5:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Please tag me when you do so!
    It'll be my first project once the house is built, and a utility trailer will be a godsend.
    0xDEADBEEF and koditten[QUOTED] like this.
  12. Feb 28, 2022 at 5:58 PM
    koditten
    Kirk
    Central Michigan
    I'll try to remember. I'm sure others watching will as well.
    RustyGreen and Kwikvette[QUOTED] like this.
  13. Feb 28, 2022 at 8:26 PM
    plurpimpin
    PDX
    That’s why I’m running the Archive trail series 2.0” relocation kit. Without spacers it clears my 285s on 4.30" backspace -10mm offset ray 10s with room to spare.
    Most of my wheeling is slow and tight, I'm not much of a high speed desert guy so I don’t really need the extra cooling capacity of 2.5” shocks. I still got way more droop with the 12” smooth bodies. Now I can clear obstacles with both tires on the ground and the rear diff open that I used to lift a tire on and have to use the locker.
  14. Feb 28, 2022 at 8:39 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Bunch more fittings for work to build more portable blue screens. 60 T’s and 12 Corners
  15. Feb 28, 2022 at 8:40 PM
    wi_taco
    Adam
    That was my exact plan and I have the same SCS -10mm offset wheels, but Accutune basically talked me out of it. I'm going to sleep on it because I can't decide yet. Tired of thinking on it for today. I'll PM you later to pick your brain if I go the MT route.
    Back to talk about angry pixies melting heavy metal. Sorry I brought so much suspension chatter to your welding thread lol.
  16. Mar 1, 2022 at 6:07 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, that kind of info is better shared publicly really.
    Plus, not every welder runs at the same heat and/or travel speed so settings are only guidelines. Sometimes ability isn't up to par with needed travel speeds and so one would run a tad colder, or with less wire speed.
    Bivouac likes this.
  17. Mar 1, 2022 at 7:57 AM
    Bivouac
    have you Checked McMaster-Carr they are pretty much my go to for things like that.
  18. Mar 1, 2022 at 8:06 AM
    Bivouac
    I can understand wanting to build your own trailer but I am lucky there always seems to be one close to what i want for just about scrap price .
    New Tires Fix or install new lights maybe some gussets to improve strength and fresh paint .
    My one friend and I bought and refurbished Horse Trailers as well as fixed them up for owners back in the day .
  19. Mar 1, 2022 at 8:15 AM
    Bivouac
    Very well stated!!!
    Input voltage variations !! just from location or time of day.
    The very Popular 100' extension cord on 120VAC machines
    The plus or minus 10% and still be in factory specs
  20. Mar 1, 2022 at 10:19 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Nevermind machine set ups, how do you remove paint from tight places? Like under the motor mount for the gusset kit install. I did what I could with a small wire brush but still didn’t weld worth a crap. My welder (Millermatic 220?) doesn’t like paint.
